  3. Ezlo to openLuup to Homebridge
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
15 Posts 3 Posters 1.9k Views 3 Watching
    @mrFarmer I'm trying to add my Ezlo devices to Homebridge via openLupp Ezlobridge using the Vera plugin for Homebridge.
    Do you or anyone else know why they are ignored. My devices provisioned by Verabridge is visible in Homebridge but not those from Ezlobridge.
      mrFarmer
      Hi Crille,
      I assume the devices from the Elzo show on openLuup, right? Then it is a question for the HomeBridge why it is not picking up those devices. Maybe there is some check build the HomeBridge plugin. I do not use HomeBridge.
        Yes, everything works perfect in openLuup, great plugin!
        I'll dig deeper into the Homebridge plugin or hoping someone smarter than me had the same problem 🙂
          It was as simple as missing category_num's for the bridged Ezlo devices.
            @mrFarmer category_num is not persistent on Luup reload, is this a bridge or openLuup behavior?
              This is very odd. My category_num are persistent. So I a must assume that it is a bridge behavior? I have not seen this on the z-way bridge. What do they reset to?
                @rafale77 They are resetting to empty.
                My virtual HTTP devices are persistent so I’m guessing a bridge issue.
                  mrFarmer
                  Hi @Crille ,
                  There was a discussion on the category_num attribute not getting set by openLuup when a device is created. I thought that got changed some releases back. However, just as you I see that the category_num gets wiped after a reload. The VeraBridge does not look to have that problem, so it must indeed be something I do different. I will have a look.
                    mrFarmer
                    Found the issue. Fixed version 2.2 is in the ALTUI App store.
                    CrilleC 2 Replies Last reply
                    • M mrFarmer
                      @mrfarmer Thank you very much!
                      • M mrFarmer
                        @mrfarmer The changed category_num seems to be overwritten with what the plugin gets from the Ezlo controller?
                        So if I want to change a dimmable light to a switch, category_num 3 (reason: bad integration on Ezlo side) instead of 2 it's overwritten back to 2 on reload. Is it possible to make it respect the custom category_num?
                          mrFarmer
                          Hi @Crille
                          Yes, it is now using the value based on a mapping table. To keep a changed value I would have to make some changes yes. I will let you know.
                            mrFarmer
                            Hi @Crille
                            Can you try with the V2.3 release?
                            • M mrFarmer
                              Hi @Crille
                              @mrfarmer Yep, that seems to do the trick. Thank you!
                              Another issue is that Humidity sensors show NaN %
                              AltUi or bridge issue?
                              Edit: I guess it's because the device has the variable "Humidity" instead of "CurrentLevel"?
                                mrFarmer
                                Yes, that was it. V2.4 has a fix
                                  3.5k
                                  3.1k
                                  446
                                • Self test
