  2. Hardware
  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
119 Posts 7 Posters 73.2k Views 5 Watching
    OK that's odd
    Even though the device is called Living_Room_dot the command expects 'Living Room dot' shrug
      Does it matter that I see you typed "uup" instead of "luup" at the beginning of your trial command?
        @librasun said in Vera Alexa Plugin 7.32:
        Quoting error. It would have mattered 🙂
          If this helps you feel less alone, I get an "Sorry, I'm having trouble running the Simon Says command on your Echo" (or some such spoken error message) when I attempt:
          luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Kendra"><lang xml:lang="en-US">Hello from Vera Alexa</lang></voice>', Volume=50, Repeat = 1}, 344)
          ...lifted almost verbatim from DB's docs.
            #29
            Can anybody help me modify this statement in such a way that the spoken volume is lowered to 10 (from the default of 50)?
            luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand", {Command="-e speak:'Hello from Vera Alexa' -d 'Living Room' "}, 344)
            THANKS! The documentation I'm reading here and here leaves a lot to the imagination, I'm sorry to admit.
            PablaP 1 Reply Last reply
              @librasun I am probably the least qualified person on this thread to answer this question but I will give it a try. Maybe confirm that your Living Room Alexa device isn't called Living Room Echo or something, cause that will be the name you'll have to use.
              luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "Say", {Text="Hello from Vera Alexa", Volume=10, GroupZones="Living Room" }, 344)
              LibraSunL 1 Reply Last reply
                This still is hacky, because it's based on unsupported feature, but me and many others have it running since 3+ years. The point is to
                • ensure you could get a cookie. If not, the best thing to do is to install on a pi or similar and use via oath tool and openluup
                • use exact names for devices, because it's case sensitive
                • avoid groups, unless you have announcements enabled
                • avoid complex voices, unless you have announcements enabled
                • try with debugmode set to 1 and looking at live logs
                I'm always open to PRs for docs and a UI, if anyone wants to contribute. I've not invested so much into a proper UI because I still think it's not really necessary, but it doesn't mean that one of you could not step in and do it 😁
                  If only one of us was qualified 😄
                    Does there not need to be an Echo device specified in there? Doesn't work for me either, yet.
                      @catmanv2 you need announcements on. Do you have them enabled?
                        @therealdb said in Vera Alexa Plugin 7.32:
                        Aye. UseAnnouncements = 1 (And I get lovely synced announcements across the house) 😉
                          @pabla said in Vera Alexa Plugin 7.32:
                          Funny, I've tried precisely that command before (and just tried again for the 10th time), and it always produces a spoken error response:
                          "Sorry, I'm having trouble using the Simon Says skill right now." (or something very similar)
                          I am also getting the feeling that GroupZones are somehow different from -d (Device), but I have no GroupZones set up. Only a bunch of Echo devices with names like "Living Room", "Master Bedroom", "Hall Bathroom", etc.
                          Will continue reading docs and these replies to learn more.
                          THANKS FOR THE HELPING HAND!
                            I don't even get an error. Might it be because I don't have the Simon Says skill?
                            Would be interested in understanding how to use some of the audio effects if anyone might have suitable syntax? Also anyone got a list of commands?
                            ElcidE 1 Reply Last reply
                              #38
                              It's just odd to me that the "RunCommand" version (with "Speak") - works great for me! - works better than the purpose-built "Say" approach - produces seemingly unrelated verbal error I can't follow.
                              All I really need is for someone smarter than me to spell out clearly (like for a kindergartner) HOW the command strings are composed. Normally, I can work from examples, and DB's docs contain plenty, but none of them seem to fit my intentions (i.e. use MSR to run Lua on Vera to say something through a specific Echo at a specified volume, which seems so simple and straightforward).
                              Maybe as a group we should focus our attention, as DB suggests, on crafting a workable set of documentation so we're all clear.
                                Same here 😄
                                  BONUS If we play our cards right, and nail down all the options, we could beg @toggledbits to create a "Notify" template on MSR specifically for VeraAlexa. 🙂
                                  • toggledbitsT Online
                                    toggledbitsT Online
                                    I think @therealdb or someone should port that plugin's approach into an MSR Notifier, which could then be used universally and without the Vera dependency. It's probably the easiest extension API in MSR: "I'm here, and here's the data I need from the UI" and "here's the data you asked for and the configuration file data, send a notification". One JavaScript class, two methods, and you're done.
                                    But for now, is there something missing from the default entity that you might need?
                                      @toggledbits OK for me. I don't think it's a lot of work to do, considering that you just need to execute a bash script with the right parmaters passed in 🙂
                                      In fact, as I said, I'm running into my own system, and the vera is sending the request via UDP (and HTTP before) and it's working perfectly. But since a lot of people asked for it in the Vera OS, I tried to port it anyway and it's working, even if I didn't spend a lot of time into the Vera UI, because I'm not that proficient and because it was considered legacy 2 years ago...
                                      Again, happy to make it user-friendly and MSR-integrated.
                                        @catmanv2 Here is a link to the amazon SSMl mark up syntax
                                        Speech Synthesis Markup Language (SSML) Reference | Alexa Skills Kit
                                        You can use Speech Synthesis Markup Language (SSML) in your output speech response to control how Alexa generates the speech. For example, you can add pauses and other speech ef...
                                          Well, say is just a shortcut for a generic command. It's strange say it's not working, since it's basically sending -e speak:'%s' -d %q, where %s is the text, %q is the device.
                                            165.2k
