  3. OpenLuup unavailable
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
88 Posts 6 Posters 60.2k Views 6 Watching
  • M mrFarmer
    Aha, ok. The Ezlo json responses include the word error even is there is none, so I was wondering why I am seeing so many hits on that.
    @mrfarmer said in OpenLuup unavailable:
    What does one of those responses actually look like (around the part that says error.). I could search for just an isolated word...
    M 1 Reply Last reply
      #35
      I too am now seeing the following syntax being counted as an error from the sonos speakers through the UPnP proxy:
      TVConfigurationError="0"
        mrFarmer
        @akbooer it looks like this: { "api":"1.0","error":null,"id":......}
          #37
          OK. Latest development version v21.3.23 has refine the search to isolated occurrences of the word error.
          This should accomodate both @mrFarmer and @rafale77.
          Adding colour to the log itself is a bit of a pain since, actually, the whole thing is in a single preformatted block.
            #38
            Working great! Thanks for the quick turnaround.
            Something very strange is going on though. Without the MQTT server enabled at all, I have observed the same problem as @ArcherS twice today. The only major change I made was to enable the LuaUPnP proxy for the sonos app. Prior to this, I have had no memory of openLuup hanging this way for quite some time, probably a year. Looked at the logs and found nothing useful. I seem to remember having some strange problems with the luasocket the last time I had seen this while trying to get fix another plugin. I will keep an eye on this.
            The only errors I am currently seeing look like this:
            openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x7f49d5fe98f8
            Whereby it seems like openLuup is trying to send bytes to an incoming tcp connection which has been closed by the client. I have several such servers sending http commands to openLuup.
            Link to the previous thread about it https://smarthome.community/topic/105/openluup-hangs
              Thanks for raising this issue... I nearly missed it because you edited a previous post rather than started a new one.
              We need to nail down this issue, which is clearly genuine, but infrequent and difficult to replicate at will. It’s good to note that it’s not apparently connected with MQTT. The strange thing is that, with very minor exceptions, none of the major server modules have been changed for over a year. Are we all just stressing our system a bit more these days?
              I have introduced some extra socket checks specifically into the MQTT code, so my first line of attack will be to retrofit these to HTTP transactions. This gets me thinking again that it would be great to use a real HTTP server, rather than one I have written myself. But it’s a bit daunting to consider the installation and configuration needed to do that. Ideally, I’d need something that supports the WSAPI CGI interface. Apache does, as, I believe, does lighttpd.
                #40
                @rafale77
                The latest development version v21.3.24 has the extra socket send check in place for every send done on an openLuup server (HTTP, MQTT, SMTP, POP3.)
                Let's see if that helps anything.
                A 2 Replies Last reply
                  mrFarmer
                  Hi AK,
                  No longer seeing the high error count, great work as always.
                  What I notice is that the longest gaps are always for a poll to one of my Vera's even though that is set for async poll (running on Debian PI cone VM). I do not see that on my main V20.4.30 running on a PI3 with Debian.
                    @rafale77
                    ArcherS
                    @akbooer I have have the system up and running over two nights in a row without doing any changes and without any crashes. Today at approx 12:24 the system however crashed again. I think it is no single device that causes the crash but instead that a socket overload or something similar.
                    The current setup I have for the sensors pushing data via http adds up to quite a lot of http requests, since one sensor can update a number of OpenLuup devices (approx foru to eight) at one occation. Mqtt will reduce this quite a lot since all data for that sensor will be in one message.
                    I will install v21.3.24 and see if anything changes.
                    When looking in the log a few minutes before the crash I can see the following in the log, don't know if this could give more clues.
                    2021-03-24 12:21:22.883   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=181&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=11.1 HTTP/1.1 tcp{client}: 0x557824e372d8
                    2021-03-24 12:21:22.883   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=183&id=variableset&serviceId=urn:micasaverde-com:serviceId:LightSensor1&Variable=CurrentLevel&Value=1181 HTTP/1.1 tcp{client}: 0x5578241755b8
                    2021-03-24 12:21:22.883   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=182&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=48.9 HTTP/1.1 tcp{client}: 0x5578246d66f8
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=180&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=0.7 HTTP/1.1 tcp{client}: 0x557825862ea8
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=184&id=variableset&serviceId=urn:micasaverde-com:serviceId:GenericSensor1&Variable=CurrentLevel&Value=1006.9 HTTP/1.1 tcp{client}: 0x557824e808c8
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=152&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=12.6 HTTP/1.1 tcp{client}: 0x5578254dba88
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=153&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=44.7 HTTP/1.1 tcp{client}: 0x557824553b88
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=173&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=14.7 HTTP/1.1 tcp{client}: 0x557825687348
                    2021-03-24 12:21:22.884   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=188&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=23.0 HTTP/1.1 tcp{client}: 0x557825adb228
                    2021-03-24 12:21:22.885   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=154&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=0.9 HTTP/1.1 tcp{client}: 0x557824a5b168
                    2021-03-24 12:21:22.885   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=151&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=11.5 HTTP/1.1 tcp{client}: 0x557823bcd248
                    2021-03-24 12:21:22.885   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=175&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=45.0 HTTP/1.1 tcp{client}: 0x5578255cb878
                    2021-03-24 12:21:22.885   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=189&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=29.7 HTTP/1.1 tcp{client}: 0x55782415ca68
                    2021-03-24 12:21:22.885   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=150&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=41.8 HTTP/1.1 tcp{client}: 0x557824fdc308
                    2021-03-24 12:21:22.886   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=174&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=2.9 HTTP/1.1 tcp{client}: 0x55782411d778
                    2021-03-24 12:21:22.886   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=190&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=2.7 HTTP/1.1 tcp{client}: 0x5578243ea368
                    2021-03-24 12:21:22.886   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=149&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=-1.1 HTTP/1.1 tcp{client}: 0x557824eed778
                    2021-03-24 12:21:22.886   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=164&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=8.5 HTTP/1.1 tcp{client}: 0x5578249a9f38
                    2021-03-24 12:21:22.887   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5578245a37b8
                    2021-03-24 12:21:22.887   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5578245a37b8
                    2021-03-24 12:21:22.887   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x5578245a37b8
                    2021-03-24 12:21:22.887   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x5578245a37b8
                    2021-03-24 12:21:22.887   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x5578245a37b8
                    2021-03-24 12:21:22.887   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x557824be7628
                    2021-03-24 12:21:22.887   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x557824be7628
                    2021-03-24 12:21:22.887   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x557824be7628
                    2021-03-24 12:21:22.887   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x557824be7628
                    2021-03-24 12:21:22.887   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x557824be7628
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824e372d8
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578241755b8
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578246d66f8
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557825862ea8
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824e808c8
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578254dba88
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824553b88
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557825687348
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557825adb228
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824a5b168
                    2021-03-24 12:21:22.928   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557823bcd248
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578255cb878
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55782415ca68
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824fdc308
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55782411d778
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578243ea368
                    2021-03-24 12:21:22.929   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824eed778
                    2021-03-24 12:21:22.930   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x557823c0f808
                    2021-03-24 12:21:22.930   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x557823c0f808
                    2021-03-24 12:21:22.930   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax/# tcp{client}: 0x557823c0f808
                    2021-03-24 12:21:22.930   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x557823c0f808
                    2021-03-24 12:21:22.930   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax_fb/# tcp{client}: 0x557823c0f808
                    2021-03-24 12:21:22.971   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578249a9f38
                    2021-03-24 12:21:23.001   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:21:23.002   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:21:23.002   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:21:23.004   openLuup.mqtt:: TasmotaCO2Ax SUBSCRIBE to cmnd/TasmotaCO2Ax/# tcp{client}: 0x55782502f428
                    2021-03-24 12:21:23.004   openLuup.mqtt:: TasmotaCO2Ax SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55782502f428
                    2021-03-24 12:21:23.005   openLuup.mqtt:: TasmotaCO2Ax SUBSCRIBE to cmnd/TasmotaCO2Ax_fb/# tcp{client}: 0x55782502f428
                    2021-03-24 12:21:23.005   openLuup.mqtt:: TasmotaCO2An SUBSCRIBE to cmnd/TasmotaCO2An/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:21:23.006   openLuup.mqtt:: TasmotaCO2An SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:21:23.006   openLuup.mqtt:: TasmotaCO2An SUBSCRIBE to cmnd/TasmotaCO2An_fb/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:21:23.020   openLuup.io.server:: HTTP:3480 connection from 192.168.1.53 tcp{client}: 0x557824728c98
                    2021-03-24 12:24:27.723   openLuup.io.server:: HTTP:3480 connection from 192.168.1.54 tcp{client}: 0x5578254b0b78
                    2021-03-24 12:24:27.723   openLuup.io.server:: HTTP:3480 connection from 192.168.1.54 tcp{client}: 0x557824f80ef8
                    2021-03-24 12:24:27.723   openLuup.io.server:: HTTP:3480 connection from 192.168.1.51 tcp{client}: 0x557824f83988
                    2021-03-24 12:24:27.723   openLuup.io.server:: HTTP:3480 connection from 192.168.1.54 tcp{client}: 0x557824df10c8
                    2021-03-24 12:24:27.723   openLuup.io.server:: HTTP:3480 connection from 192.168.1.51 tcp{client}: 0x557824fb0048
                    2021-03-24 12:24:27.724   openLuup.io.server:: HTTP:3480 connection from 192.168.1.54 tcp{client}: 0x557824fb21e8
                    2021-03-24 12:24:27.724   openLuup.io.server:: HTTP:3480 connection from 192.168.1.51 tcp{client}: 0x557824e52928
                    2021-03-24 12:24:27.724   openLuup.io.server:: HTTP:3480 connection from 192.168.1.54 tcp{client}: 0x557824fd5f48
                    2021-03-24 12:24:27.724   openLuup.io.server:: HTTP:3480 connection from 192.168.1.52 tcp{client}: 0x557824fd7ff8
                    2021-03-24 12:24:27.724   openLuup.io.server:: HTTP:3480 connection from 192.168.1.52 tcp{client}: 0x5578241ee5a8
                    2021-03-24 12:24:27.725   openLuup.io.server:: HTTP:3480 connection from 192.168.1.55 tcp{client}: 0x557824d0f778
                    2021-03-24 12:24:27.725   openLuup.io.server:: HTTP:3480 connection from 192.168.1.52 tcp{client}: 0x557824d11828
                    2021-03-24 12:24:27.725   openLuup.io.server:: HTTP:3480 connection from 192.168.1.55 tcp{client}: 0x5578251ff6f8
                    2021-03-24 12:24:27.725   openLuup.io.server:: HTTP:3480 connection from 192.168.1.55 tcp{client}: 0x557825201b18
                    2021-03-24 12:24:27.726   openLuup.io.server:: HTTP:3480 connection from 192.168.1.50 tcp{client}: 0x55782562a688
                    2021-03-24 12:24:27.726   openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x5578257d3ec8
                    2021-03-24 12:24:27.726   openLuup.io.server:: MQTT:1883 connection from 192.168.1.61 tcp{client}: 0x5578257d5f78
                    2021-03-24 12:24:27.727   openLuup.io.server:: MQTT:1883 connection from 192.168.1.62 tcp{client}: 0x5578252531e8
                    2021-03-24 12:24:27.728   luup_log:0: 50Mb, 2.1%cpu, 2.0days
                    2021-03-24 12:24:29.281   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=181&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=11.3 HTTP/1.1 tcp{client}: 0x5578254b0b78
                    2021-03-24 12:24:29.281   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=183&id=variableset&serviceId=urn:micasaverde-com:serviceId:LightSensor1&Variable=CurrentLevel&Value=1125 HTTP/1.1 tcp{client}: 0x557824f80ef8
                    2021-03-24 12:24:29.282   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=173&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=14.8 HTTP/1.1 tcp{client}: 0x557824f83988
                    2021-03-24 12:24:29.282   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=182&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=49.3 HTTP/1.1 tcp{client}: 0x557824df10c8
                    2021-03-24 12:24:29.282   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=175&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=45.0 HTTP/1.1 tcp{client}: 0x557824fb0048
                    2021-03-24 12:24:29.283   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=180&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=1.0 HTTP/1.1 tcp{client}: 0x557824fb21e8
                    2021-03-24 12:24:29.284   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=174&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=3.0 HTTP/1.1 tcp{client}: 0x557824e52928
                    2021-03-24 12:24:29.284   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=184&id=variableset&serviceId=urn:micasaverde-com:serviceId:GenericSensor1&Variable=CurrentLevel&Value=1006.8 HTTP/1.1 tcp{client}: 0x557824fd5f48
                    2021-03-24 12:24:29.285   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=188&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=23.9 HTTP/1.1 tcp{client}: 0x557824fd7ff8
                    2021-03-24 12:24:29.285   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=189&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=29.2 HTTP/1.1 tcp{client}: 0x5578241ee5a8
                    2021-03-24 12:24:29.286   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=151&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=11.7 HTTP/1.1 tcp{client}: 0x557824d0f778
                    2021-03-24 12:24:29.286   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=190&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=2.9 HTTP/1.1 tcp{client}: 0x557824d11828
                    2021-03-24 12:24:29.287   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=150&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=41.5 HTTP/1.1 tcp{client}: 0x5578251ff6f8
                    2021-03-24 12:24:29.287   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=149&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=-1.0 HTTP/1.1 tcp{client}: 0x557825201b18
                    2021-03-24 12:24:29.288   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=152&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=12.9 HTTP/1.1 tcp{client}: 0x55782562a688
                    2021-03-24 12:24:29.289   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x557825ca05a8
                    2021-03-24 12:24:29.289   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x557825ca05a8
                    2021-03-24 12:24:29.289   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:24:29.289   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:24:29.289   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x557825ca05a8
                    2021-03-24 12:24:29.290   luup_log:203: VirtualBinaryLight[2.40@203]:[updateMeters] KWH Path "meters[1].total" - Raw Value: 2805119 - Transformed Value: 4852230.7604
                    2021-03-24 12:24:29.290   luup.variable_set:: 203.urn:micasaverde-com:serviceId:EnergyMetering1.KWH was: 4852184.0084 now: 4852230.7604 #hooks:0
                    2021-03-24 12:24:29.291   luup_log:203: VirtualBinaryLight[2.40@203]:[updateMeters] Watts Path: "meters[1].power" - Value: 0
                    2021-03-24 12:24:29.291   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55782502f428
                    2021-03-24 12:24:29.291   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55782502f428
                    2021-03-24 12:24:29.291   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax/# tcp{client}: 0x55782502f428
                    2021-03-24 12:24:29.291   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55782502f428
                    2021-03-24 12:24:29.291   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax_fb/# tcp{client}: 0x55782502f428
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578254b0b78
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824f80ef8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824f83988
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824df10c8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824fb0048
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824fb21e8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824e52928
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824fd5f48
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824fd7ff8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578241ee5a8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824d0f778
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557824d11828
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5578251ff6f8
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557825201b18
                    2021-03-24 12:24:29.367   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55782562a688
                    2021-03-24 12:24:29.368   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=164&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=8.6 HTTP/1.1 tcp{client}: 0x5578249f1658
                    2021-03-24 12:24:29.368   luup.variable_set:: 164.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 8.6 now: 8.6 #hooks:0
                    2021-03-24 12:24:29.368   openLuup.server:: request completed (2 bytes, 1 chunks, 0 ms) tcp{client}: 0x5578249f1658
                    2021-03-24 12:24:29.371   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5578247df8a8
                    2021-03-24 12:24:29.371   openLuup.mqtt:: closed tcp{client}: 0x5578247df8a8
                    2021-03-24 12:24:29.371   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:24:29.371   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:24:29.371   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x5578247df8a8
                    2021-03-24 12:24:29.371   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/tasmota_test/POWER : closed
                      I have been searching around and it appears to be a common yet infrequent problem reported for the luasocket. For good measure I updated my version of luasocket again to the latest development version (scm-2) but given how stagnant the development has been, I am wondering whether this would be the time to look for a different library... I have tinkered with libcurl in the past but I think it is only for POSIX platforms. I am sure there is a better lua library out there.
                        @rafale77
                        ArcherS
                        #44
                        @akbooer After I installed v21.3.24 AltUi does not load.
                        The Console loads as it should but AltUi just tries to connect.
                        Is there an easy way of downgrading to v21.3.23?
                          OK, that was clearly a BAD IDEA.
                          2021-03-24 14:49:58.979   openLuup.server:: GET /J_ALTUI_verabox.js HTTP/1.1 tcp{client}: 0x1cb6160
                          2021-03-24 14:49:58.982   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x1cb6160' sending 2 bytes to tcp{client}: 0x1cb6160
                          2021-03-24 14:49:58.982   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x1cb6160' sending 6 bytes to tcp{client}: 0x1cb6160
                          2021-03-24 14:49:58.982   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x1cb6160' sending 97222 bytes to tcp{client}: 0x1cb6160
                          2021-03-24 14:49:58.983   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x1cb6160' sending 5 bytes to tcp{client}: 0x1cb6160
                          I've reverted that commit, so simply updating to development again (from the console!) should fix that.
                            ArcherS
                            @akbooer now it works again! 🙂
                              I've pushed a new v21.3.24b release which includes the new checks, but, hopefully, without the deleterious effect on AltUI (or anything else.)
                              To make it easy to revert, I've also tagged the v21.3.23 version, so you can always revert to that by typing it into the update box.
                              rafale77R A 2 Replies Last reply
                                @akbooer
                                Have not upgraded to 24b yet but this is what I am seeing:
                                2021-03-24 12:36:01.348   openLuup.io.server:: HTTP:3480 connection from 192.168.0.55 tcp{client}: 0x7fb153b396c8
                                2021-03-24 12:36:01.350   openLuup.server:: GET /data_request?id=variableset&serviceId=urn:upnp-org:serviceId:VSwitch1&Variable=Text2&DeviceNum=22&Value=10 HTTP/1.1 tcp{client}: 0x7fb153b396c8
                                2021-03-24 12:36:01.350   luup.variable_set:: 22.urn:upnp-org:serviceId:VSwitch1.Text2 was: 9 now: 10 #hooks:0
                                2021-03-24 12:36:01.351   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x7fb153b396c8
                                2021-03-24 12:36:01.351   openLuup.server:: ...only 0 bytes sent
                                2021-03-24 12:36:01.351   openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x7fb153b396c8
                                2021-03-24 12:36:01.351   openLuup.server:: request completed (2 bytes, 1 chunks, 1 ms) tcp{client}: 0x7fb153b396c8
                                2021-03-24 12:36:01.351   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x7fb153b396c8
                                I am nearly 100% convinced that the hangs are due to luasocket error or timeout handling. You can see here that likely the client which here is home-assistant sending an http call to update a device on openLuup, apparently closed the tcp connection to which openLuup is trying to send something. As a result, I am getting an error. The humor is that both home assistant and openLuup are on the same machine. I am seeing this type of errors a few times a day but have not had a hang up since my previous post (I have updated luasocket and luasec since by the way) so I don't know if they are related to this error. However my previous experience from last year seem to indicate a bug in luasocket causing it to hold up the entire lua thread.
                                  ArcherS
                                  @akbooer Upgraded to v21.2.24b, it works as supposed so far.
                                  Also I modified my strategy a bit. I have now turned off the http reporting from the sensors. They generate quite a lot of http calls, the screenshot below is from approx 13:00 to 22:00.
                                  Worth noting is that they have been doing this http reporting for a few months without any stability problems, the traffic they generate could however be part of seeing the problems on my particular server perhaps.
                                  The three test devices reporting over Mqtt are left on, we will see what happens.
                                  • A ArcherS
                                    ArcherS
                                    Today at 12:08 it crashed again.
                                    Not many Mqtt calls since the restart yesterday evening.
                                    Also very few http server sockets:
                                    Log file errors before the crash:
                                    2021-03-25 12:05:33.879   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca4502428
                                    2021-03-25 12:05:33.879   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x563ca4502428
                                    2021-03-25 12:05:33.879   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x563ca4502428
                                    2021-03-25 12:05:33.879   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x563ca4502428
                                    2021-03-25 12:05:33.879   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x563ca4502428
                                    2021-03-25 12:05:33.891   openLuup.mqtt:: TasmotaCO2An SUBSCRIBE to cmnd/TasmotaCO2An/# tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:05:33.894   openLuup.mqtt:: TasmotaCO2An SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.921   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.921   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.921   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.921   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.921   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x563ca41ea188
                                    2021-03-25 12:08:44.925   openLuup.server:: request completed (11424 bytes, 1 chunks, 3813 ms) tcp{client}: 0x563ca3ebc488
                                    2021-03-25 12:08:44.935   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca3b9d058
                                    2021-03-25 12:08:44.935   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x563ca3b9d058
                                    2021-03-25 12:08:44.935   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca3f8a488
                                    2021-03-25 12:08:44.935   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x563ca3f8a488
                                    2021-03-25 12:08:44.938   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca47549f8
                                    2021-03-25 12:08:44.938   openLuup.mqtt:: closed tcp{client}: 0x563ca47549f8
                                    2021-03-25 12:08:44.938   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x563ca47549f8
                                    2021-03-25 12:08:44.938   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x563ca47549f8
                                    2021-03-25 12:08:44.938   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x563ca47549f8
                                    2021-03-25 12:08:44.938   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/tasmota_test/POWER : closed
                                    2021-03-25 12:08:44.939   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x563ca428dc98
                                    2021-03-25 12:08:44.939   openLuup.mqtt:: closed tcp{client}: 0x563ca428dc98
                                    2021-03-25 12:08:44.939   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax/# tcp{client}: 0x563ca428dc98
                                    2021-03-25 12:08:44.939   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x563ca428dc98
                                    2021-03-25 12:08:44.939   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax_fb/# tcp{client}: 0x563ca428dc98
                                    2021-03-25 12:08:44.939   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/TasmotaCO2Ax/POWER : closed
                                      #51
                                      The log sequences for MQTT seem normal, simply denoting that a connection has been dropped by the client, so then it's unsubscribed. A while later, presumably in the bits you've edited out, it reconnects. Might be interesting to know if there were any successful transactions going on in between. What's the KeepAlive configured as on your clients?
                                      But I'm thinking this is not a very fruitful way forward. I am really, really struggling to think what may have changed, other than the fact that there is simply more I/O going on in the system. I tend to agree with @rafale77 above.
                                      I have not fully run out of options with the LuaSocket library, so there will be a bit more experimentation. I'm hoping that a eureka moment will strike and I realize that this is something stupid that I've done (wouldn't be the first time.)
                                        @akbooer
                                        Just loaded 3.25b and will continue to test. I have not had any other crash myself but again, I have not been using the MQTT server on my "production" system. I continue to suspect as I had evidence of last year that the lua thread hangs when luasocket tries to send too many packets into a closed connections and certainly the MQTT broker running in the same lua instance as openLuup increases that probability. For me it was homewave making http polling calls which suddenly went unanswered. Maybe @ArcherS, could try updating the luasocket version to the development version? It helped for me. Another idea might be to run the MQTT server on a separate lua instance? I am getting the idea from the UPnP proxy plugin which technically is really a separate server on another lua instance launched by the plugin device.
                                          #53
                                          3.25b has yet more checking, so it's worth a go.
                                          The thing about the openLuup MQTT implementation is that it is a server, not a client. What this means is that instead of messages going from:
                                          client A --> PUBLISH over TCP --> server --> PUBLISH over TCP --> client B
                                          You get:
                                          If client A is running on openLuup
                                          client A --> server --> PUBLISH over TCP --> client B
                                          or if client B is runing on openLuup
                                          client A --> PUBLISH over TCP --> server --> client B
                                          or both under openLuup (less likely)
                                          client A --> server --> client B
                                          The conclusion is that splitting the server to a separate machine actually generates more TCP traffic, not less.
                                            165.6k
