  3. Recover an ‘assumed bricked’ Vera Secure
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
45 Posts 5 Posters 21.5k Views 5 Watching
    You should be getting the serial number of your unit which should also be the content of your missing file.
    You can then just create that file and insert that serial number in it using a text editor. I believe the vera only has "vi" installed but I had installed "nano" on mine which I vastly prefer.
    • D Offline
      D Offline
      destination
      I will ask support tomorrow I hope I get a positive feedback.
        #26
        If the serial number is on the label of the unit, all you need to do is create the file with that number in it.
        If you scratch it down on a piece of paper, do this to avoid the editor:
        cat >/etc/cmh/PK_AccessPoint
        That will just sit there doing nothing waiting for you to type. Type in, carefully the serial number from the label, then hit ENTER once, then hit CTRL-D once. You should get the shell prompt again. You can then confirm the file exists and has the right content.
        • D Offline
          D Offline
          destination
          Thank you @toggledbits . I will try your advice tomorrow and see the result.
          • D Offline
            D Offline
            destination
            wrote on last edited by destination
            #28
            Here is the result.
            • D Offline
              D Offline
              destination
              #29
              And here extra screenshots.
              Can you comment for me ?
                #30
                The error from your screenshot is pretty explicit... You are missing the libjson library for some reason. It looks like your firmware image was incomplete and was missing a lot of stuff.
                run
                opkg update
                opkg install libjson
                You likely will have other errors and will have to complete installation of dependencies.
                D 1 Reply Last reply
                  run
                  opkg update
                  D Offline
                  D Offline
                  destination
                  #31
                  @rafale77 said in Recover an ‘assumed bricked’ Vera Secure:
                  run
                  opkg update
                  Thanks @rafale77. Thats solve curl :(7) Failed to connect to 127.0.0.1 port 3480: Connection refused error but aftre I noticed that when trying upgrade the firmware manually I see that
                  cp -af PK_AccessPoint HW_Key HW_Key2 zwave_locale cmh.conf servers.conf users.conf services.conf user_data.json.lzo /etc/cmh/
                  cp: can't stat 'HW_Key': No such file or directory
                  cp: can't stat 'HW_Key2': No such file or directory
                  cp: can't stat 'zwave_locale': No such file or directory
                  cp: can't stat 'users.conf': No such file or directory
                  cp: can't stat 'services.conf': No such file or directory
                  errors at the very long upgrating scripts. It seems installing new bin file is hardware based at vera secure, maybe i need HW_Key and HW_Key2 files
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #32
                    Looking in the newmios-hooks.sh, file there is a line in there that says
                    PRESERVE_CMH_FILES="PK_AccessPoint HW_Key HW_Key2 zwave_locale cmh.conf servers.conf users.conf services.conf user_data.json.lzo"
                    Which I assume means it expects them to be present, and to remain ?
                    I’m not very good at understanding the linux BASH/Shell language, but here looks to be the part where it’s used.
                    mios_pre_firmware_upgrade()
                    	log "Running: mios_pre_firmware_upgrade"
                    	case $1 in
                    		backup_cmh_files)
                    			log "[MH]BACKUP CMH FILES: $PRESERVE_CMH_FILES in : $BACKUP_CMH_DIR"
                    			rm -rf $BACKUP_CMH_DIR
                    			mkdir -p $BACKUP_CMH_DIR
                    			cd ${CMH_DIR}/
                    			cp -af $PRESERVE_CMH_FILES ${BACKUP_CMH_DIR}/
                    			cd -
                    		restore_cmh_files)
                    			log "[MH]RESTORE CMH FILES: $PRESERVE_CMH_FILES from : $BACKUP_CMH_DIR"
                    			[ -d "$BACKUP_CMH_DIR" ] && {
                    				cd ${BACKUP_CMH_DIR}/
                    				cp -af $PRESERVE_CMH_FILES ${CMH_DIR}/
                    				cd -
                    			} || log "[MH]BACKUP_CMH_DIR ($BACKUP_CMH_DIR) NOT FOUND. Unable to restore cmh files"
                    			log "[MH]Deleting version dependent files from /etc/cmh: $DELETE_CMH_FILES"
                    			cd /etc/cmh/
                    			rm $DELETE_CMH_FILES 2>/dev/null
                    			cd -
                    The above refers to this location
                    BACKUP_CMH_DIR="/tmp/backup_cmh_dir"
                    Can you see what’s in the above /tmp/backup_cmh_dir ?
                    Do you have a ‘backup’ file - if not in there perhaps one stored outside - you may be able to request it from Vera ?
                    • D Offline
                      D Offline
                      destination
                      #33
                      There is nothing at /tmp/backup_cmh_dir. But I already have ha-gateway-backup_XXXXXXXX_1.7.XXXX_2020-09-25.tgzbackup file. The vera restore page is not work also other interfaces too. What sould I do to restore the tgz backup file from ssh? How can I do that?
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        This is all new ground to me, but if you can I’d have a look in the .tgz (compressed/zipped) file and see what’s in there.
                        Redirect Notice
                        • D Offline
                          D Offline
                          destination
                          #35
                          Matther is not how to decompress .tgz file. How to restore with ssh? I hope @rafale77 or @toggledbits or another experienced user read here and teach us.
                            #36
                            tgz files are very easy to decompress. I think it stands for tar-gzip. You can just untar it. (it's a standard linux tool)
                            tar -xzf ***.tgz
                            These decompress automatically on macOS.
                            You will likely find a few files including the user-data.json. I wrote a script back in the old times to manually backup and recover these files and I think one such automated script is in the vera firmware. It should help you move the files to the right folders. Unfortunately it's been a long while since I last tinkered with the vera.
                              You can put the file up on your Vera using scp (or a tool like WinSCP if you are starting from Windows). I would put it into /storage for the time being. Then run this:
                              tar -C /tmp -x -v -z -f /storage/backup-file-full-name-here.tgz
                              This will de-tar the backup file into /tmp, in a subdirectory called etc (so full path is /tmp/etc/). You'll find several subdirectories within that (cmh, cmh-lu, and so on). You can copy the files you think you need one at a time, just make sure you copy them to the right place.
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #38
                                I finally got around to connecting my PC to the VeraSecure via usb tty, to see what I could do - and I’ve posted some photos on the Vera forum - https://community.ezlo.com/t/can-the-veraplus-be-unbricked/204485/42
                                Currently I can’t seem to get a network connection, no IP address being provided to allow me to connect to anything, such as a tftp server, but..
                                Based on what I’ve posted, looking in the root of Vera, I have the following under storage, is this of any potential use ?
                                root@MiOS_5510000:/storage# ls -l
                                drwxr-xr-x    2 root     root             0 Jun 17  2018 cmh-backup
                                drwxr-xr-x    5 root     root             0 Jun 17  2018 cmh-firmware
                                cmh-backup was empty, but in cmh-firmware, i can see the following
                                drwxr-xr-x    2 root     root             0 May 22  2018 1.7.3062
                                drwxr-xr-x    2 root     root             0 Jun 17  2018 1.7.3535
                                drwxr-xr-x    2 root     root             0 Jan  1 00:00 1.7.3832
                                -rw-r--r--    1 root     root           156 May 22  2018 error.log
                                -rw-r--r--    1 root     root           162 Jun 17  2018 latest_firmware.conf
                                Within the error.log, it seems to only say...
                                2018-05-22_15:12:38 - ERROR: Failed to copy MiOS Squashfs MD5SUM into jffs2 partition
                                2018-05-22_15:12:38 - ERROR: Mismatched md5sum of new Firmware Script
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Hi all,
                                  Can anyone think of anything I should try to reinstall/restore the firmware?
                                  As I don’t have access to it via an IP address on the network, I potentially could plug in a USB key to transfer or run any files ?
                                  • parkercP parkerc
                                    Hi all,
                                    @parkerc have you just pinged Vera's support? I think level 2 support could help.
                                    • parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      Hi @therealdb - yep and they finally got back to me..
                                      It seems according to their records, the controller I picked up 2nd hand was declared defective and replaced a while back. And when this happens, and the hardware is not returned, a call is sent to the unit to deactivate it and it gets permanently banned from their servers. This means the controller will not connect anymore so it won’t pick up an updates and they are not allowed/able to provide support...
                                      As I have command like access to it, I’m wondering what I can still do with it.
                                      Any ideas anyone ?
                                        #42
                                        That makes sense. One thing you can do with it is to not use it as a vera anymore and "nuke" it... Turning it into a zwave and zigbee radio host for another controller (homeseer, home assistant, domoticz). It is very likely that it was bricked due to a flash memory failure which is a sign that it would not have run reliably with any vera firmware anyway. You can look up my nuke vera script here:
                                        GitHub - rafale77/Nuke-Vera: Script to neuter the vera and broadcast its zwave and zigbee serial ports
                                        Script to neuter the vera and broadcast its zwave and zigbee serial ports - rafale77/Nuke-Vera
                                        I have run this way for quite sometime using the vera's zigbee hardware as a zigbee stick for home assistant's ZHA component and the same can be done with zwave using any other controller software.
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          Nice idea - can any other controller software be installed directly on the Vera ?
                                            162.9k
