  3. Recover an ‘assumed bricked’ Vera Secure
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
45 Posts 5 Posters 21.5k Views 5 Watching
  • D Offline
    D Offline
    destination
    wrote on last edited by destination
    Is it means you use vera3_recovery_tool for recovery not TFTP? If it is yes, vera3_recovery_tool does not works at vera secure for me.
      Under the hood, the recovery tool is using TFTP... I just used it and didn't really bother to inquire deeper as to how one would reproduce what it does.
      And as far as I know it should work for the vera secure as well (I tested on both the plus and the edge) since all three are based on the same platform. I just don't have a firmware image for the secure.
      • D Offline
        D Offline
        destination
        Thanks @rafale77. After using that tool, i still have the warning at the firmware upgrade page.
        cat: can't open "etc/cmh/PK_AccessPoint' No such file or directory cat: can't open "etc/cmh/PK_AccessPoint' No such file or directory. Manually upgrade the firmware to the latest release.
        Do you have any idea about that warning?
        alt text
          #21
          Yes, This file may not be present in the image you just uploaded to the vera and is unique to each unit. It contains the unique ID which is used by the vera cloud server to identify vera units and normally is retained between firmware upgrades. If you can SSH into you unit, you can create a new file there and/or ask for support to give you that ID for your unit. I don't remember having had this problem myself except when I created my vera emulator in a virtual machine.
          It is also that I ran my unit entirely "off the grid" for many years and never cared for the cloud service. If all you are trying to do is to run a firmware update, a dummy number in that file may be enough. You may also find that number somewhere in the logs uploaded in the vera cloud if you can find those.
            The value is also written to NVRAM and may be still be there. Try: nvram get serial_no
            • D Offline
              D Offline
              destination
              #23
              @rafale77 and @toggledbits ,thanks both of you for this wonderful informations. What should I get when returning this nvram get serial_no code? I already have another (new unit) tried that code but no return any output. Maybe tomorrow I will need to ask support for that file
                You should be getting the serial number of your unit which should also be the content of your missing file.
                You can then just create that file and insert that serial number in it using a text editor. I believe the vera only has "vi" installed but I had installed "nano" on mine which I vastly prefer.
                • D Offline
                  D Offline
                  destination
                  I will ask support tomorrow I hope I get a positive feedback.
                    #26
                    If the serial number is on the label of the unit, all you need to do is create the file with that number in it.
                    If you scratch it down on a piece of paper, do this to avoid the editor:
                    cat >/etc/cmh/PK_AccessPoint
                    That will just sit there doing nothing waiting for you to type. Type in, carefully the serial number from the label, then hit ENTER once, then hit CTRL-D once. You should get the shell prompt again. You can then confirm the file exists and has the right content.
                    • D Offline
                      D Offline
                      destination
                      Thank you @toggledbits . I will try your advice tomorrow and see the result.
                      • D Offline
                        D Offline
                        destination
                        #28
                        Here is the result.
                        • D Offline
                          D Offline
                          destination
                          #29
                          And here extra screenshots.
                          Can you comment for me ?
                            #30
                            The error from your screenshot is pretty explicit... You are missing the libjson library for some reason. It looks like your firmware image was incomplete and was missing a lot of stuff.
                            run
                            opkg update
                            opkg install libjson
                            You likely will have other errors and will have to complete installation of dependencies.
                            D 1 Reply Last reply
                              run
                              opkg update
                              D Offline
                              D Offline
                              destination
                              #31
                              @rafale77 said in Recover an ‘assumed bricked’ Vera Secure:
                              run
                              opkg update
                              Thanks @rafale77. Thats solve curl :(7) Failed to connect to 127.0.0.1 port 3480: Connection refused error but aftre I noticed that when trying upgrade the firmware manually I see that
                              cp -af PK_AccessPoint HW_Key HW_Key2 zwave_locale cmh.conf servers.conf users.conf services.conf user_data.json.lzo /etc/cmh/
                              cp: can't stat 'HW_Key': No such file or directory
                              cp: can't stat 'HW_Key2': No such file or directory
                              cp: can't stat 'zwave_locale': No such file or directory
                              cp: can't stat 'users.conf': No such file or directory
                              cp: can't stat 'services.conf': No such file or directory
                              errors at the very long upgrating scripts. It seems installing new bin file is hardware based at vera secure, maybe i need HW_Key and HW_Key2 files
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #32
                                Looking in the newmios-hooks.sh, file there is a line in there that says
                                PRESERVE_CMH_FILES="PK_AccessPoint HW_Key HW_Key2 zwave_locale cmh.conf servers.conf users.conf services.conf user_data.json.lzo"
                                Which I assume means it expects them to be present, and to remain ?
                                I’m not very good at understanding the linux BASH/Shell language, but here looks to be the part where it’s used.
                                mios_pre_firmware_upgrade()
                                	log "Running: mios_pre_firmware_upgrade"
                                	case $1 in
                                		backup_cmh_files)
                                			log "[MH]BACKUP CMH FILES: $PRESERVE_CMH_FILES in : $BACKUP_CMH_DIR"
                                			rm -rf $BACKUP_CMH_DIR
                                			mkdir -p $BACKUP_CMH_DIR
                                			cd ${CMH_DIR}/
                                			cp -af $PRESERVE_CMH_FILES ${BACKUP_CMH_DIR}/
                                			cd -
                                		restore_cmh_files)
                                			log "[MH]RESTORE CMH FILES: $PRESERVE_CMH_FILES from : $BACKUP_CMH_DIR"
                                			[ -d "$BACKUP_CMH_DIR" ] && {
                                				cd ${BACKUP_CMH_DIR}/
                                				cp -af $PRESERVE_CMH_FILES ${CMH_DIR}/
                                				cd -
                                			} || log "[MH]BACKUP_CMH_DIR ($BACKUP_CMH_DIR) NOT FOUND. Unable to restore cmh files"
                                			log "[MH]Deleting version dependent files from /etc/cmh: $DELETE_CMH_FILES"
                                			cd /etc/cmh/
                                			rm $DELETE_CMH_FILES 2>/dev/null
                                			cd -
                                The above refers to this location
                                BACKUP_CMH_DIR="/tmp/backup_cmh_dir"
                                Can you see what’s in the above /tmp/backup_cmh_dir ?
                                Do you have a ‘backup’ file - if not in there perhaps one stored outside - you may be able to request it from Vera ?
                                • D Offline
                                  D Offline
                                  destination
                                  #33
                                  There is nothing at /tmp/backup_cmh_dir. But I already have ha-gateway-backup_XXXXXXXX_1.7.XXXX_2020-09-25.tgzbackup file. The vera restore page is not work also other interfaces too. What sould I do to restore the tgz backup file from ssh? How can I do that?
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    This is all new ground to me, but if you can I’d have a look in the .tgz (compressed/zipped) file and see what’s in there.
                                    Redirect Notice
                                    • D Offline
                                      D Offline
                                      destination
                                      #35
                                      Matther is not how to decompress .tgz file. How to restore with ssh? I hope @rafale77 or @toggledbits or another experienced user read here and teach us.
                                        #36
                                        tgz files are very easy to decompress. I think it stands for tar-gzip. You can just untar it. (it's a standard linux tool)
                                        tar -xzf ***.tgz
                                        These decompress automatically on macOS.
                                        You will likely find a few files including the user-data.json. I wrote a script back in the old times to manually backup and recover these files and I think one such automated script is in the vera firmware. It should help you move the files to the right folders. Unfortunately it's been a long while since I last tinkered with the vera.
                                          You can put the file up on your Vera using scp (or a tool like WinSCP if you are starting from Windows). I would put it into /storage for the time being. Then run this:
                                          tar -C /tmp -x -v -z -f /storage/backup-file-full-name-here.tgz
                                          This will de-tar the backup file into /tmp, in a subdirectory called etc (so full path is /tmp/etc/). You'll find several subdirectories within that (cmh, cmh-lu, and so on). You can copy the files you think you need one at a time, just make sure you copy them to the right place.
                                            162.9k
