  2. Hardware
  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
119 Posts 7 Posters 73.2k Views 5 Watching
    I don't even get an error. Might it be because I don't have the Simon Says skill?
    Would be interested in understanding how to use some of the audio effects if anyone might have suitable syntax? Also anyone got a list of commands?
    @catmanv2 Here is a link to the amazon SSMl mark up syntax
    Speech Synthesis Markup Language (SSML) Reference | Alexa Skills Kit
    You can use Speech Synthesis Markup Language (SSML) in your output speech response to control how Alexa generates the speech. For example, you can add pauses and other speech ef...
      @pabla said in Vera Alexa Plugin 7.32:
      @librasun I am probably the least qualified person on this thread to answer this question but I will give it a try. Maybe confirm that your Living Room Alexa device isn't called Living Room Echo or something, cause that will be the name you'll have to use.
      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "Say", {Text="Hello from Vera Alexa", Volume=10, GroupZones="Living Room" }, 344)
      Funny, I've tried precisely that command before (and just tried again for the 10th time), and it always produces a spoken error response:
      "Sorry, I'm having trouble using the Simon Says skill right now." (or something very similar)
      I am also getting the feeling that GroupZones are somehow different from -d (Device), but I have no GroupZones set up. Only a bunch of Echo devices with names like "Living Room", "Master Bedroom", "Hall Bathroom", etc.
      Will continue reading docs and these replies to learn more.
      THANKS FOR THE HELPING HAND!
      @librasun said in Vera Alexa Plugin 7.32:
      Well, say is just a shortcut for a generic command. It's strange say it's not working, since it's basically sending -e speak:'%s' -d %q, where %s is the text, %q is the device.
      • ElcidE Elcid
        @elcid said in Vera Alexa Plugin 7.32:
        Ta. I've tried I really have 🙂
        ElcidE 1 Reply Last reply
          BONUS If we play our cards right, and nail down all the options, we could beg @toggledbits to create a "Notify" template on MSR specifically for VeraAlexa. 🙂
          Heh. I've not looked at MSR yet, but the Alexa action in Reactor works like a charm...
            @catmanv2
            When i tried SSML, I seem to remember it only worked with announcements.
              #48
              @therealdb I've been meaning to toss you some cappuccino money for a while now, to thank you for your vast efforts in support of the Vera community.
              Think I found you on PayPal under your @<your-full-name>, would that be the right and best place? (And are Euros better than USD?)
                @librasun thanks, but I have a job (well, I’m joking with my colleagues that I’m probably doing 6-7 jobs at once) and I’m doing this for the pleasure to give back and find new friends (and because I used to travel a lot and this year I had a lot of free time). So, as I’ve already said to others (@Pabla is here too) I’d appreciate if you could donate to groups trying to create a more inclusive environment, ie promoting a dev career for girls or minorities. Thanks 👍
                • ElcidE Elcid
                  @catmanv2
                  @catmanv2
                  Maybe, I have it with conversional accent and I’m loving it. It’s very natural.
                    So I've got this working:
                    luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Kendra"><lang xml:lang="en-AU">Hello from Vera Alexa</lang></voice>', Volume=40,GroupZones="Living Room dot"}, 22)
                    But can't for the life of me get the sound effects:
                    <audio src="soundbank://soundlibrary/animals/amzn_sfx_bear_groan_roar_01"/>
                    </speak>
                    For example. Also does anyone have a list of the available voices?
                    TIA
                    therealdbT LibraSunL 2 Replies Last reply
                      </speak>
                      TIA
                      @catmanv2 it’s in the Amazon doc I linked in readme. Also, sounds are very specific and you could send them but not in the same command with voice.
                        </speak>
                        TIA
                        @catmanv2 said in Vera Alexa Plugin 7.32:
                        Funny, that's one thing I've got working no problem:
                        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e sound:amzn_sfx_trumpet_bugle_04 -d 'Living Room'"}, 344)
                          #54
                          @therealdb said in Vera Alexa Plugin 7.32:
                          Thanks. I did look, I promise. I'll look again!
                          <edit> Got it, eventually! Thanks.
                            Ahh per the Guru's words. Won't work with the speech. Thanks 🙂
                              #56
                              I did some more digging, and discovered that:
                              WHEN I RUN THIS LUA
                              luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e speak:'what is the temperature outside' -d 'Living Room'"}, 344)
                              Alexa speaks the sentence and VeraAlexa shows this LastResponse: "sending cmd:speak:what is the temperature outside to dev:Living_Room"
                              WHEN I RUN THIS LUA
                              luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "Say", {Text="what is the temperature outside", Repeat = 1}, 344)
                              Alexa DOES NOT speak the sentence and VeraAlexa shows this LastResponse: "sending cmd:speak:<s>what is the temperature outside</s><break time="0s" /> to dev:Living_Room "
                              Instead she utters, "Sorry, I'm having trouble accessing the Simon Says ??? Skill right now." then a bong tone sounds. Weird!
                              Thus, I'll continue using the 1st construct to have Alexa speak sentences.
                              INSIGHT: I honestly believe the "Simon Says ???" Alexa mentions has to do with an error parsing <SSML> tags!!
                                #57
                                If I use 'SAY' I need to specify a groupzone....
                                luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Raveena">Hello from Vera Alexa</voice>', Volume=40,GroupZones="Living Room dot"}, 22)
                                  I tried to run that command verbatim(!) -- changing only my device # -- and get the same spoken "Sorry..." error as always. Really driving me bonkers!! Would love to use SSML in my workflow, but until this gets resolved, no go. Thanks for the suggestion(s), of course. I'm sure it's ME, not ALEXA. 🙂
                                    Fun times. I took my own advice and completely removed VeraAlexa plug-in from my Vera Plus (making sure there were no hidden devices lurking, then executing a device > remove command via HTTP request in my browser). Rebooted, restarted MSR (so it would forget about deleted Entity), copied ZIP from Github, loaded files onto Vera, restarted Luup engine, created Device (it starts hidden!), restarted Luup engine again, see device in UI (no name), restart Luup yet again, see "Alexa" device, says "Configured=1" (yay!), update its "DefaultEcho" variable, etc., restart MSR in Docker, hard refresh all browsers.
                                    And I'm back. Now HERE is the fun part... SOME of the "Say" commands work now, some ALMOST do, and others still do not.
                                    WORKS // says "Hello from Vera Alexa"
                                    luup.call_action("urn:micasaverde-com:serviceId:Sonos1", "Say", {Text="Hello from Vera Alexa"}, 345)
                                    ALMOST WORKS // says "Domain" and stops
                                    luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<amazon:domain name="conversational">Hello from Alexa</amazon:domain>',   Volume=10, Repeat = 1}, 345)
                                    DOES NOT WORK // says "Sorry..." error message
                                    luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Raveena">Hello from Vera Alexa</voice>', Volume=40,GroupZones="Living Room"}, 345)
                                    I must be a bad person.
                                    PablaP CatmanV2C 2 Replies Last reply
                                      wrote on last edited by Pabla
                                      #60
                                      @librasun For the last command have you tried using the Sonos service ID instead? I find it odd how some commands work and some dont
                                        #61
                                        Yep, tried that. Changed GroupZones= to "Sonos Beam" (name of my Alexa-enabled Sonos device also known as "Living Room"), and still... silence.
                                        But thanks for the tip to try!
                                        Oh wait! You're saying try piping the command to the SONOS service instead of the 'bochicchio' one... hold on... gonna try.
                                        Answer: NOPE. Still same "Sorry, I'm having trouble accessing ___ skill right now."
                                        PablaP 1 Reply Last reply
                                          @librasun I will try to get logged in later today to try these commands and see if I can reproduce these issues
                                            165.2k
