  3. Apple Homepod mini
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
Apple Homepod mini
62 Posts 8 Posters 32.0k Views 7 Watching
    How would I know? I’m accessing it through the Home app on the iPad.
      Go to [Homebridge docker IP]:8581, if there is a Homebridge page you can configure it from UI. You need to install the old Vera plugin from damianxd https://github.com/damianxd/homebridge-vera and configure it, either from UI or console.
      akbooerA therealdbT 2 Replies Last reply
        @crille said in Apple Homepod mini:
        Ah, that was the bit I was missing. Thanks.
          Speaking of it, maybe someone wants to embark into a rewrite, because it's not really supporting every device out there...
            ronluna
            wrote on last edited by ronluna
            #51
            @akbooer get the latest copy directly from github at https://github.com/damianxd/homebridge-vera as npm is not current/synced with the github repo. In other words, install the plugin through the homebridge plugin section and then replace all the files located at "/usr/lib/node_modules/homebridge-vera/" with the latest on github.
              @therealdb said in Apple Homepod mini:
              ...actually, I see now that there is an Homebridge/MQTT bridge
              https://www.npmjs.com/package/homebridge-mqttthing
                #53
                @akbooer
                Trying to be more explicit here:
                The very old VeraHomeKitBridge still works great. I forked it to make it support more devices and is similar to the alexa habridge. It just doesn't need to emulate a hue hub and doesn't have all the discovery problems the amazon system has. This is kind of the (my) lazy way... It has no UI but since I am using homekit as the highest level of abstraction and control, I am only publishing the devices I want to voice control. I have been catching myself not using Homewave anymore and most of the time using the iOS Home app when I want manual actuation which is extremely rare.
                GitHub - rafale77/VeraHomeKitBridge
                Contribute to rafale77/VeraHomeKitBridge development by creating an account on GitHub.
                Homebridge is a much better choice as it has a UI and offers bridging many other platforms through plugins. It's purpose is to publish these platforms to Homekit. Once installed, you indeed need to also install the vera bridge plugin for openLuup. Like its predecessor above, it is a one way bridge: Homekit will see, and control openLuup devices, not the other way around. There is nothing to do on openLuup.
                @ronluna's plugin bridges the other way, publishing homekit devices back into openLuup and is therefore an openLuup plugin.
                  @akbooer
                  #54
                  Thanks for that explanation. The weak link, as far as openLuup is concerned, is the Vera bridge plugin, because it (obviously) relies on the rather inefficient Luup status request. Indeed, it uses it very inefficiently:
                  2021-04-06 14:46:46.215 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c8914c8f68
                  2021-04-06 14:46:47.204 openLuup.io.server:: HTTP:3480 connection from 172.16.42.10 tcp{client}: 0x55c892db3648
                  2021-04-06 14:46:47.206 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55c892db3648
                  2021-04-06 14:46:47.216 openLuup.server:: request completed (51616 bytes, 4 chunks, 10 ms) tcp{client}: 0x55c892db3648
                  2021-04-06 14:46:47.217 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c892db3648
                  2021-04-06 14:46:48.206 openLuup.io.server:: HTTP:3480 connection from 172.16.42.10 tcp{client}: 0x55c89288ad88
                  2021-04-06 14:46:48.207 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55c89288ad88
                  2021-04-06 14:46:48.217 openLuup.server:: request completed (51616 bytes, 4 chunks, 10 ms) tcp{client}: 0x55c89288ad88
                  2021-04-06 14:46:48.218 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c89288ad88
                  2021-04-06 14:46:49.207 openLuup.io.server:: HTTP:3480 connection from 172.16.42.10 tcp{client}: 0x55c891f01508
                  2021-04-06 14:46:49.208 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55c891f01508
                  2021-04-06 14:46:49.219 openLuup.server:: request completed (51616 bytes, 4 chunks, 10 ms) tcp{client}: 0x55c891f01508
                  2021-04-06 14:46:49.219 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c891f01508
                  ...it doesn't even use the syntax for incremental changes from last time, and, although it's not fatal, this increases my CPU from 0.2% to 2.7% 😧
                  I've also had problems with it not coping with duplicate device names, and Homebridge has also mapped my Hue devices twice – one directly and once via openLuup. So there's a few thing to think about and work through here, from a configuration point of view.
                  One voice-actuated 'gotcha' I've found already is that "Hall" sounds very much like "All", but means something very different!
                    #55
                    @akbooer said in Apple Homepod mini:
                    Interesting... I have not tested homebridge myself but don't seem to have this problem with my older version of the bridge.
                    Yes... this where one needs to make choices. I have the same problem and decided to not bridge my hue devices through openLuup.
                    😲 I never had this problem even with my French accent (we tend to forget to pronounce the "h" because this letter is mute in french). Maybe use "hallway"?
                      Yes, very good plan.
                        OK, I’m a Homebridge convert. With it running in a Docker, and using just a few Homebridge plugins (MQTT in particular, also Netatmo) and the Home app on an iPad, I can do just about everything I need. Amazingly, I now see this as a viable replacement for my beloved Zwave Minimotes (I have nine of them, strategically placed.). This means that every Zwave device I had, except for two pulse meter readers, can be replaced by Hues, Shellies, and Homebridge. Not much further need for Vera or ZWay. Of course, openLuup is still central, especially for data archiving with Historian, but UI access to it is rare.
                        Perhaps I do just need a HomePod Mini (or two) to complete the experience...?
                          ronluna
                          #58
                          @akbooer That's right... and just like that... apple is taking over then entire home automation industry.... too bad there is no Home app for Android. Well Front end and first layer voice control related...
                          • R ronluna
                            @ronluna said in Apple Homepod mini:
                            Not sure I would call that a takeover quite yet. Homekit is not the panacea when it comes to automation but it certainly does a lot of things better than others. It's certainly taken a long time for them to come up with a device like this. The original HomePod was just too expensive for this application. My original idea for the homekit bridge was to use an iPad as a console by the front door on which I could use siri. This was 5 years ago in my previous house. I more or less shelved Homekit until this past month seeing that thread on the hubitat forum.
                            I just read this for the first time today and I completely agree with the vision:
                            Paulus Schoutsen  /  Jan 18, 2016
                            Perfect Home Automation
                            A breakdown of what the perfect home automation should consist of.
                            It is 5 years old and am pretty sad with the obsession of all these companies with the cloud, wanting to get our data in it. Sadly Apple is the only one of the bigs offering complete local processing and is why I switched over. It has enabled finally completed my vision of full cloud independence: TTS is local through macOS, voice control is local through siri, the only house control app, I will end up having is likely going to be the iOS home app... But the automation still is on openLuup and a large number of integrations on Home Assistant with z-way still controlling a large zwave network.
                              @rafale77
                              A good article!
                              It reminds me of this (written over 100 years ago) ...
                              The Machine Stops
                                Yup,
                                I just received my HomePod mini and I have to say the migration of the voice command from alexa to siri resembles in some ways to my migration from vera to z-way. I can't get over how much faster it is. There are some pros and cons though.
                                1. Homekit's use of device grouping and rooms is much better used than on Alexa. I can walk to any room ask it to turn lights on and it won't ask me which ones, it will just turn the ones in the room and is able to either recognize group of device types.
                                2. The darn thing works without cloud at all and so the HomePod doesn't go crazy jumping from wifi AP to another when the internet connection drops like the echo devices.
                                3. The sonos integration in homekit seems to be useless. I am going through home assistant's homekit component to control them now but still can't control the volume using voice like I used to with alexa/habridge.
                                4. It is the size of an echo dot with the sound quality of a full size echo.
                                5. Locking down to apple music is the part I don't like and won't use. I will stick with sonos for music.
                                6. It is fast... Did I say that again? The echo didn't feel slow... 1-2s response time is not bad but it was inconsistent and occasionally would act up with some long delays. So far, the HomePod has been instantaneous. Yup I can't get over how fast it is.
                                This was the last frontier on my installation to full cloud independence and I have looked left and right at DIY localized home assistance and never found anything cost/effort effective. This is the best compromise and quite a leap. I am trading in a bunch of echos... shipped 8 out already.
                                My setup:
                                Z-way + home assistant -> openLuup -> HomeKitBridge -> Homekit
                                Replacing habridge ->AmazonCloud/Alexa
                                My setup:
                                and all I'm doing now is:
                                openLuup <--> MQTT <--> Homebridge (using homebridge-mqttthing)
                                with both openLuup and Homebridge directly connecting to Philips Hue hubs for Zigbee.
                                  My Homepod mini arrived today. Very slick setup using an iPad. Happily discovered the Homebridge running in my Synology Docker, and all the configured devices (including my new Shelly Button 1!)
                                  The revelation here is that the Homepod solves the remote access issue for openLuup, in that all the devices exposed (via MQTT) to the Homebridge are fully functional.
                                  Love it! Thanks for the initial recommendation @rafale77 .
                                    158.7k
