  3. Plugins
  4. openLuup: Tasmota MQTT Bridge
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
127 Posts 5 Posters 81.3k Views 4 Watching
    B A 5 Replies Last reply
      I’m entirely dependant now on openLuup’s MQTT server, and it seems to be performing flawlessly for me under Synology docker and Homebridge.
      ArcherS
      @akbooer I have now set up a clean install of OpenLuup on my Pi running Zway bridge and two Tasmota devices reporting over Mqtt. The Zway bridge links "165 vDevs, 64 zNodes". No Veras linked. No errors in the log file.
      This is the traffic after approximately 6 hours:
      We will see how it goes, so far it looks ok. At the moment I have not installed lua-cjson. CPU load is staying slightly above 10%, i.e. quite high.
      Running OpenLuup v21.4.8d and Zway bridge v21.1.19.
        Has the Tasmota bridge appeared as a device? At the moment it’s just an empty shell.
          ArcherS
          @akbooer yepp it is there. 🙂
            OK, which two devices are you using? I"ll try and implement them first.
              ArcherS
              @akbooer a suitable type of Tasmota device to test with would be an AM2301 device reporting temp and humidity:
              tele/tasmota_7FA953/SENSOR = {"Time":"2021-04-13T21:18:28","AM2301":{"Temperature":15.6,"Humidity":44.7,"DewPoint":3.6},"TempUnit":"C"}
              I have a few of these that I could use for testing the bridge.
              The ones I have set up now are two devices each containing a BME280 sensor (temp, hum, air pressure) and a MHZ19B sensor (CO2):
              tele/TasmotaCO2An/SENSOR = {"Time":"2021-04-13T21:17:20","BME280":{"Temperature":22.1,"Humidity":41.5,"DewPoint":8.4,"Pressure":1017.5},"MHZ19B":{"Model":"B","CarbonDioxide":806,"Temperature":46.0},"PressureUnit":"hPa","TempUnit":"C"}
              I could test with these also.
              (The temp value of the MHZ19B is rubbish, I think it is the internal temp in the sensor or something, so I do not use it.)
                @ArcherS
                I've set this up as a new openLuup topic. The latest development version v21.4.14 has filled in some of the Tasmota infrastructure so that tele/# topics should force the creation of new devices and the variables will be extracted from the JSON message.
                This needs further work to create standard serviceId/variables and possibly specific child devices, but I'd be interested in how it looks for a start (again, I currently have no Tasmotas, but MQTT makes it easy to pretend!)
                therealdbT A 3 Replies Last reply
                  @ArcherS
                  @akbooer I've already sent a couple of announcements in the other post. IMHO discovery messages should be preferred.
                  tasmota/discovery/ABC/sensors
                  {"sn":{"Time":"2021-04-05T11:49:16","DS18B20":{"Id":"3C01D6070BEA","Temperature":15.1},"SR04":{"Distance":58.456},"TempUnit":"C"},"ver":1}``
                  tasmota/discovery/ABC/config
                  {"ip":"192.168.1.53","dn":"tasmota-watertank","fn":["tasmota-watertank",null,null,null,null,null,null,null],"hn":"tasmota-watertank","mac":"ABC","md":"Generic","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"9.3.1","t":"tasmota-watertank","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":1,"lt_st":0,"sho":[0,0,0,0],"ver":1}
                  As you could see, the config will send all the supported commands, topics, sw version, etc.
                  Moree info here: https://tasmota.github.io/docs/MQTT/#mqtt-topic-definition
                    Yes, thanks. I'm not precluding anything, but just started with the telemetry, since that's where the updates are.
                      @ArcherS
                      ArcherS
                      @akbooer I installed v21.4.14 and it looks really nice, well done. 🙂
                      At first I did not find the two Tasmota devices, but then I found them in the room "Tasmota" that I already had made!
                      The devices seem to behave as they should, I will check over time.
                      Combined with the GUI in the Virtual Sensor plugin from @toggledbits it is now really easy to link the desired variables to a virtual sensor.
                      In total a really user friendly setup without any coding required. 🙂
                      The system load stayed the same as when I had the devices mapped via luup handlers, which I assume is expected. On my Pi that also has a Zway bridge on it the cpu load without cjson is approx 10.5%. I think the Zway bridge is costing a bit of cpu actually, it is quite active.
                      I will add some more Tasmota devices and see how it works.
                        @ArcherS
                        ArcherS
                        @akbooer I have set up seven Tasmota devices reporting various data and it seems to work.
                        I do however get the following errors in the log:
                        2021-04-14 19:39:10.020   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                        2021-04-14 19:39:10.020   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaTest/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                        2021-04-14 19:39:10.071   luup.watch_callback:: 20004.AM2301.Humidity called [9]virtualSensorWatchCallback() function: 0xb1cf28
                        2021-04-14 19:39:10.072   luup.variable_set:: 28.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 40.7 now: 40.5 #hooks:0
                        2021-04-14 19:39:10.072   luup.variable_set:: 28.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 40.5 now: 40.4 #hooks:0
                        2021-04-14 19:39:10.072   luup.variable_set:: 28.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 40.5 now: 40.4 #hooks:0
                        2021-04-14 19:39:10.073   luup.variable_set:: 28.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 40.7 now: 40.5 #hooks:0
                        2021-04-14 19:39:10.073   luup.variable_set:: 28.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1618421890 now: 1618421950 #hooks:0
                        2021-04-14 19:39:10.073   luup.watch_callback:: 20004.AM2301.Temperature called [9]virtualSensorWatchCallback() function: 0xb1cf28
                        2021-04-14 19:39:10.074   luup.watch_callback:: 20004.TasmotaTest.Time called [9]virtualSensorWatchCallback() function: 0xb1cf28
                        2021-04-14 19:39:10.465   openLuup.server:: request completed (3239 bytes, 1 chunks, 2133 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:10.477   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/humidity_sensor_default.png HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:10.477   openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:10.592   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018566&Timeout=60&MinimumDelay=1500&_=1618416957720 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:12.814   openLuup.server:: request completed (1210 bytes, 1 chunks, 2221 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:12.933   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018568&Timeout=60&MinimumDelay=1500&_=1618416957721 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:15.631   openLuup.server:: request completed (1210 bytes, 1 chunks, 2697 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:15.757   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018570&Timeout=60&MinimumDelay=1500&_=1618416957722 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:18.080   openLuup.server:: request completed (1210 bytes, 1 chunks, 2322 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:18.202   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018572&Timeout=60&MinimumDelay=1500&_=1618416957723 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:20.463   openLuup.server:: request completed (1210 bytes, 1 chunks, 2261 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:20.576   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018574&Timeout=60&MinimumDelay=1500&_=1618416957724 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:23.362   openLuup.server:: request completed (1210 bytes, 1 chunks, 2785 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:23.490   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018576&Timeout=60&MinimumDelay=1500&_=1618416957725 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:25.785   openLuup.server:: request completed (1210 bytes, 1 chunks, 2295 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:25.903   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018578&Timeout=60&MinimumDelay=1500&_=1618416957726 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:28.206   openLuup.server:: request completed (1210 bytes, 1 chunks, 2303 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:28.327   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018580&Timeout=60&MinimumDelay=1500&_=1618416957727 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:30.474   openLuup.server:: request completed (1210 bytes, 1 chunks, 2146 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:30.597   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018582&Timeout=60&MinimumDelay=1500&_=1618416957728 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:32.848   openLuup.server:: request completed (1210 bytes, 1 chunks, 2250 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:32.977   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018584&Timeout=60&MinimumDelay=1500&_=1618416957729 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:34.831   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                        2021-04-14 19:39:34.831   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaUterum/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                        2021-04-14 19:39:34.841   luup.watch_callback:: 20003.AM2301.Humidity called [9]virtualSensorWatchCallback() function: 0xb1cf28
                        2021-04-14 19:39:34.842   luup.variable_set:: 26.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 38 now: 38.1 #hooks:0
                        2021-04-14 19:39:34.843   luup.variable_set:: 26.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 38.1 now: 38 #hooks:0
                        2021-04-14 19:39:34.843   luup.variable_set:: 26.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 38.1 now: 38 #hooks:0
                        2021-04-14 19:39:34.844   luup.variable_set:: 26.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 38 now: 38.1 #hooks:0
                        2021-04-14 19:39:34.844   luup.variable_set:: 26.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1618421706 now: 1618421974 #hooks:0
                        2021-04-14 19:39:34.844   luup.watch_callback:: 20003.AM2301.Temperature called [9]virtualSensorWatchCallback() function: 0xb1cf28
                        2021-04-14 19:39:35.152   openLuup.server:: request completed (2848 bytes, 1 chunks, 2175 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:35.168   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/humidity_sensor_default.png HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:35.169   openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:35.387   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018598&Timeout=60&MinimumDelay=1500&_=1618416957730 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:35.493   openLuup.server:: request completed (1210 bytes, 1 chunks, 105 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:35.615   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018600&Timeout=60&MinimumDelay=1500&_=1618416957731 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:37.882   openLuup.server:: request completed (1210 bytes, 1 chunks, 2266 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:38.002   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018602&Timeout=60&MinimumDelay=1500&_=1618416957732 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:40.289   openLuup.server:: request completed (1210 bytes, 1 chunks, 2286 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:40.402   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018604&Timeout=60&MinimumDelay=1500&_=1618416957733 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:42.661   openLuup.server:: request completed (1210 bytes, 1 chunks, 2259 ms) tcp{client}: 0xe227b0
                        2021-04-14 19:39:42.770   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=420018606&Timeout=60&MinimumDelay=1500&_=1618416957734 HTTP/1.1 tcp{client}: 0xe227b0
                        2021-04-14 19:39:44.412   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                        2021-04-14 19:39:44.412   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaCO2An/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                        The errors come in pairs, two for each Tasmota device continuously with other entries in between.
                          Would love to test Tasmota, but my devices are in working state, and connected to a mosquitto server. I was wondering if MQTT openLuup can be bridged?
                          • ElcidE Elcid
                            @elcid yes you can. I’ve bridge it with my own mqtt server and it’s working ok.
                              wrote on last edited by Elcid
                              Well I tried a simple bridge in the mosquitto config file with no luck. What did i miss?
                              connection bridgemqtt1
                              address 192.158.0.40:1884
                              topic # both 0
                              [edit] Nevermind i failed to restart using -c mosquitto.conf
                              • A ArcherS
                                @archers said in openLuup: Tasmota MQTT Bridge:
                                Do you have it running in asynchronous mode? Do you have CJson installed yet?
                                OK, I'll take a look. Do you have an example of the message posted which causes the error?
                                Otherwise, things seem to be going fairly well...
                                This is really good news, and perhaps means that I don't need to refine the variables further or create any child devices?
                                  ArcherS
                                  @akbooer I have "AsyncPoll" true on the Zway Bridge, I assume that means that it is in asynchronuous mode? Or should I check something else?
                                  No, I have yet to install cjson. This was actually intentional since I wanted to test it without this first and see if it works. On my main OpenLuup server that has experienced crashes I have cjson installed so I wanted to test without cjson first. But I should test this later on and see what happens to the cpu load.
                                  Regarding cpu load it has not gone up that much when comparing running one Tasmota vs running seven which is promising.
                                  I am not sure what message that causes the error, do you have any ideas what I should look for in the log or elsewhere? It mentions "TasmotaBridge.Lua:188 table index is nil" in all errors for the devices.
                                  The errors always says:
                                  2021-04-14 21:19:10.214   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:19:10.214   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaTest/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  and it seems to cycle through my Tasmota devices reporting the same two rows but for each device:
                                  2021-04-14 21:35:10.064   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:10.065   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaTest/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:42.864   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:42.865   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaUterum/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:44.637   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:44.637   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaCO2An/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:44.844   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  2021-04-14 21:35:44.844   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaCO2Ax/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                                  Yes I agree, it seems to be going well. 🙂
                                  No, I think it is quite good the way it is, creating Virtual Sensors and then linking them to the devices/variables is very easy. It only takes a few minutes to add a new Tasmota device from scratch without any coding at all.
                                  In fact I think it is better this way since typically you do not want all of the reported values as a child device, e.g. you do not want "Dew point" or "Time", the useless MHZ19B temperature etc. This way you can select only what you want, not getting OpenLuup cluttered by a lot of "useless" child devices.
                                    @akbooer, I have bridged the 2 brokers but not seeing any Tasmota bridge I see the mosquitto bridge in the openluup log no errors. My topics are tasmota/stat/devicename/POWER The devices are sonoff mini's flashed with tasmota-lite.bin. Any ideas?
                                    • ElcidE Elcid
                                      @elcid said in openLuup: Tasmota MQTT Bridge:
                                      So, at the moment, I have only subscribed to tele/#, so that's why you're not seeing anything.
                                      I can make this configurable, but what does a message look like with this topic?
                                      ElcidE 1 Reply Last reply
                                        @akbooer
                                        Ask the device for status
                                        cmnd/tasmota_switch/Power ←     // an empty message/payload sends a status query
                                            ↳ stat/tasmota_switch/RESULT → {"POWER":"OFF"}
                                            ↳ stat/tasmota_switch/POWER → OFF
                                        We can see that the switch (devices relay) is turned off.
                                        Send a command to toggle the relay~
                                        cmnd/tasmota_switch/Power ← "TOGGLE"
                                            ↳ // Power for relay 1 is toggled
                                            ↳ stat/tasmota_switch/RESULT → {"POWER":"ON"}
                                                ↳ stat/tasmota_switch/POWER → ON
                                        I have appended th tasmota at the start of the topic in my tasmota device settings.
                                          ATM the bridge doesn't solicit any response from the devices. Indeed, it would have to discover them first in order to do so. So at this time, if the device does not sent regular tele/ updates, then it won't be seen. This is early days for the bridge.
                                            MikeReadington
                                            112.2k
                                          • Integrations and 'Loaded'
                                            1.0k
