  4. Home Remote dashboard app and MSR HTTP API
16 Posts 5 Posters 3.9k Views 5 Watching
    I am not using any of Home Remotes own internal scenes / logic, I couldn't see the point of that
    For me all logic should be done from one master controller which is MSR.
    Once I have moved my remaining Vera scenes that have logic (LUA code) to MSR then MSR will be doing everything. As you know I am no longer using PLEG.
    Home Remote for me is just that a dashboard remote control app.
    Home Remote is connected to my Vera Plus hub and Philips Hue Bridge, so all those devices and scenes I can control in the Home Remote dashboard.
    I am not grouping any lights really nothing to speak of other than my side table lamps.
    I have two in my lounge room for example and I created a "Master" virtual dimmer device in Vera and then a rule with an expression in MSR that groups the control of the two lamps.
    So when I turn On / Off or Dim the "Master" virtual dimmer device, then both real lamp devices follow suit etc.
      Now, here comes my essential question: How does Home Remote "know" to update its dashboard symbol for LIGHT A after you've tapped its button on the screen? Does it receive an update (via HTTP I presume) from Vera letting HA HR know that "It's on now"?
      I guess I could ask more simply, "How does HA HR stay 'in sync' with devices on Vera?"
        I don't know exactly how Bill is doing the Vera integration with Home Remote.
        However I do know he is using the SDATA output stream from Vera
        http://Vera-IP:3480/data_request?id=sdata
        So presumably it's the status of devices from SDATA, that updates the icons / states of the devices in the Home Remote GUI.
        As for control I assume he is using the Vera HTTP API (Luup Requests).
        As for what I am doing here creating buttons in Home Remote to run MSR actions (scenes), I don't really need any status feedback, they are just manually initiated scenes for basic things.
          The light icons update for Vera device objects.
          If I went to the wall switch and turned off the Lounge Main Light the icon and state of the device in the app would change to being OFF
            Okay, roger that, and thanks. It's great that HR (I think I called it HA for some odd reason earlier, sorry) and Vera "talk" that way. I'm now recalling that the lengthy tutorial I watched of his -- where the user had to essentially "code" all the feedback from actual devices -- involved a WiFi-connected amplifier. Unlike Vera, that device didn't "push" updates to HR in real time, so it had to be polled on every change.
            PablaP 1 Reply Last reply
              @librasun A lot of plugins have been integrated in the app where you no longer have to code anything really to control supported receivers etc. It's a pretty highly integrated app!
                I am using Group pages in HR rather than building my own custom pages from a blank slate.
                Group pages are auto generated for you. You just create a Windows Explorer folder like structure in the designer application, for your desired menu structure / layout and add Vera devices and scenes to them from the list it already imported.
                Doing it that way I haven't needed to manually code anything for device Status feedback it just happens.
                Have a look at my HR thread on the Vera forum, I covered the basic concept of using Group pages in HR.
                Creating your own custom pages looks much more involved like what @Tarkus has done and his project looks amazing but beyond my skills I think.
                  This is how my dashboard looks
                  Nov 13, 2020
                  CW's Version 1.0 dashboard based on "Groups"
                  Hi Here is my first attempt at an Imperihome app dashboard replacement using Home Remote, I still have some small glitches and issues, but overall its finished ish… For reference here was my Imperihome dashboard. I have used the Groups pages, as that seemed like the quicker way to get up and...
                    Thanks, guys, this has me excited to try something with HR (or, later MSR's own Dashboard) which completely sidesteps Vera. Namely, creating "virtual devices" that live entirely on MSR (probably as Expressions at first, but conceivably as fully-blown Rules standing in place of virtual devices).
                    I'd love to have a Group page in Home Remote, where each square represents a corresponding entity on MSR. As @cw-kid proposes above, the back-and-forth could be wired up entirely via HTTP requests.
                    (My next question was going to be, "Does anyone have HR running in a Docker container?" I recall it runs on various platforms.)
                    cw-kidC T 2 Replies Last reply
                      Home Remote the designer application is Windows only. This is the application used to create your project.
                      The front end dashboard apps are Android, iOS and Windows.
                      Once you have created your project file you can publish it. I publish my project file to my internal ftp server then every mobile device phones and tablets look at that location for any new project file updates.
                      So the mobile apps just auto update to the latest version of my project when the app is launched on that device.
                      So no more running round to each mobile device to update it like with Imperihome.
                      No need for Docker.
                        @librasun said in Home Remote dashboard app and MSR HTTP API:
                        Your the expressions expert, I wouldn't know where to start! 😉
                        But virtual devices on MSR could be a good idea.
                          Tarkus
                          @librasun here is a demo I put together on Home Remote utilizing my personal project. I also use MSR for a majority of the conditional logic. The demo runs about 9 minutes.
                          Home remote 3.0 Demo
                            Awesome, will check it out! Meanwhile, here's @toggledbits ' official stance on "Virtual Devices on MSR".
                            • T Tarkus
                              MikeReadingtonM Offline
                              MikeReadington
                              @tarkus very nice!
                              Yep, I will be looking into this for sure.
                                142.7k
