  3. How do you post images on this forum from a smart device?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
6 Posts 4 Posters 1.1k Views 4 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Is there a guide somewhere on how to submit images/attachments from a smart device ?
    As someone who accesses this forum from an iPad/iPhone, I don’t have the ability to drag / drop images into any posts.
    What are other people doing (who are not using a traditional PC/MAC) ?
      If you use the blue REPLY button at the top of a post, rather than the link at the bottom, you get an form with a number of icon buttons, one of which is an image which enables you to upload.
      • parkercP Offline
        parkercP Offline
        parkerc
        Hey @akbooer
        All the drop down from the top right blue Reply button gives me is “REPLY AS TOPIC" I don’t get anything else ?
          Don't use the drop down... just click on the reply button.
          • parkercP Offline
            parkercP Offline
            parkerc
            Thanks @rafale77
            Interesting...
            When I hit REPLY to an existing thread, the options are there at the top of the new “replying to’ window.
            But when I click to do a NEW TOPIC, the options are not there.
              That's right. When you begin a new topic you don't get any formatting tools for some reason. That's why I always start with a basic introduction paragraph and then do the meat and potatoes in the subsequent replies.
                98.0k
              • Next Release?
                1.0k
