  3. Plugins
  4. openLuup: Tasmota MQTT Bridge
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
Plugins
AltUi
Plugins
127 Posts 5 Posters 104.7k Views 4 Watching
    @archers said in openLuup: Tasmota MQTT Bridge:
    This is what I get in the log when changing the temperature of the device (no 50):
    Looking at the logs, you're setting the temperature while the heater is off, so it's skipped. Do you want to turn it on if the temperature is below the target?
    ArcherS
    @therealdb said in openLuup: Tasmota MQTT Bridge:
    I created a new device just to start from fresh:
    When I try to change the dropdown from "off" to "Heat" it reverts back after I e.g. change rooms or reload the browser. The same thing when changing the temperature. Should it not stay at the value I set? I may be missing something obvious here on how the heater controller works, since it is the first time I play around with one.
    These are the attributes:
    and the variables:
    The current temp was at 2000 when the device was created, tried changing it to e.g. 20, but makes no difference.
    Some log entries from when changing the values:
    2021-05-11 16:04:04.239   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=52&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=21 HTTP/1.1 tcp{client}: 0x2697800
    2021-05-11 16:04:04.242   luup.call_action:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint
    2021-05-11 16:04:04.243   openLuup.server:: request completed (44 bytes, 1 chunks, 2 ms) tcp{client}: 0x2697800
    2021-05-11 16:04:09.775   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/dimmable_light_30.png HTTP/1.1 tcp{client}: 0x2697800
    2021-05-11 16:04:09.777   openLuup.server:: request completed (938 bytes, 0 chunks, 0 ms) tcp{client}: 0x2697800
    2021-05-11 16:04:16.134   openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x2697800
    2021-05-11 16:05:43.757   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=741810207&Timeout=60&MinimumDelay=1500&_=1620741805209 HTTP/1.1 tcp{client}: 0x2882ed8
    2021-05-11 16:05:45.244   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=52&serviceId=urn:upnp-org:serviceId:HVAC_UserOperatingMode1&action=SetModeTarget&NewMode=HeatOn HTTP/1.1 tcp{client}: 0x2d32838
    2021-05-11 16:05:45.246   luup.call_action:: 52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.SetModeTarget
    2021-05-11 16:05:45.247   openLuup.server:: request completed (39 bytes, 1 chunks, 1 ms) tcp{client}: 0x2d32838
    2021-05-11 16:05:53.818   openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x2d32838
    Log from when the device was created:
    2021-05-11 10:05:35.089   luup.create_device:: [52] D_VirtualHeater1.xml / I_VirtualHeater1.xml / D_Heater1.json   (urn:schemas-upnp-org:device:Heater:1)
    2021-05-11 10:05:35.099   openLuup.server:: request completed (6440 bytes, 0 chunks, 34 ms) tcp{client}: 0x1c6c030
    2021-05-11 10:05:35.099   openLuup.scheduler:: [52] VirtualHeater2 device startup
    2021-05-11 10:05:35.099   luup_log:52: VirtualHeater starting...
    2021-05-11 10:05:35.100   luup_log:52: VirtualDevices[3.0-beta2@52]:Plugin starting
    2021-05-11 10:05:35.100   luup.device_message:: device=52, status=4, message=Starting..., timeout=5, source=VirtualDevices
    2021-05-11 10:05:35.100   luup_log:52: VirtualDevices[3.0-beta2@52]:Child #52 - "VirtualHeater2"
    2021-05-11 10:05:35.101   luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.DebugMode was: EMPTY now: 0 #hooks:0
    2021-05-11 10:05:35.101   luup.variable_set:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1.CurrentSetpoint was: EMPTY now: 18 #hooks:0
    2021-05-11 10:05:35.102   luup.variable_set:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: EMPTY now: 18 #hooks:0
    2021-05-11 10:05:35.102   luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.TemperatureDevice was: EMPTY now: 0 #hooks:0
    2021-05-11 10:05:35.103   luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.SetPowerURL was: EMPTY now: http:// #hooks:0
    2021-05-11 10:05:35.103   luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.SetPowerOffURL was: EMPTY now: http:// #hooks:0
    2021-05-11 10:05:35.103   luup.attr_set:: 52.subcategory_num = 2
    2021-05-11 10:05:35.106   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeTarget
    2021-05-11 10:05:35.108   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeStatus
    2021-05-11 10:05:35.111   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1.CurrentSetpoint
    2021-05-11 10:05:35.113   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint
    2021-05-11 10:05:35.116   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature
    2021-05-11 10:05:35.116   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.Configured was: 0 now: 1 #hooks:0
    2021-05-11 10:05:35.116   luup.set_failure:: status = 0
    2021-05-11 10:05:35.117   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
    2021-05-11 10:05:35.117   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0
    2021-05-11 10:05:35.117   openLuup.scheduler:: [52] VirtualHeater2 device startup completed: status=true, msg=Ready, name=VirtualDevices
    2021-05-11 10:05:35.626   openLuup.server:: request completed (4456 bytes, 1 chunks, 8545 ms) tcp{client}: 0x20a2fc0
    2021-05-11 10:05:35.714   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=679125970&_=1620678904534 HTTP/1.1 tcp{client}: 0x20a2fc0
    2021-05-11 10:05:36.145   openLuup.server:: request completed (764639 bytes, 48 chunks, 429 ms) tcp{client}: 0x20a2fc0
    2021-05-11 10:05:38.584   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=679159576&Timeout=60&MinimumDelay=1500&_=1620678904535 HTTP/1.1 tcp{client}: 0x20a2fc0
    2021-05-11 10:05:41.932   openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x1c6c030
      @Buxton
      @akbooer said in openLuup: Tasmota MQTT Bridge:
      Some work required on the HIstorian filename handling...
      ...now done in latest development version v21.5.11.
      B Offline
      B Offline
      Buxton
      @akbooer No historian errors and all "checked" variables are publishing to my InfluxDB server.
        That's great. The next release will have a new openLuup > Historian > Rules page so that you can see what patterns are being used to match variables for archiving. Not yet editable, but that may come in future. Feel free to ask for more/better rules and I can put them into another release, or tell you how to add them in Lua Startup.
        B 1 Reply Last reply
          B Offline
          B Offline
          Buxton
          @akbooer Cool. Making the checklist active would be great as there are some oddball variables that I'd like to incorporate, and creating wsp files by hand, while not super difficult--I have several-- is not exactly easy either....
          • B Buxton
            @buxton said in openLuup: Tasmota MQTT Bridge:
            ...trivial to add with a custom rule.
              @Buxton
              ArcherS
              Installed and it seems to work as it should. Next step is to upgrade on my main OpenLuup server after some runtime on the test server.
              • A ArcherS
                and the variables:
                #100
                This is by design. As you can see, you've not set SetPowerURL and SetPowerOffURL to anything significant, like the mqtt message, so it's not sending anything, and it's acting with the default behavior: if you're not replying with 200-ish HTTP response, it will not change variables. When using mqtt:// prefix, it will update immediately.
                I'll work on this anyway, since it's not sending temperature command at the moment, but I think it's a good addition in your use case - and to other people as well.
                Please try with mqtt commands and let me know, because I have it working good.
                EDIT: it's done, just set SetSetpointURL variable to
                mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":%s,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                (notice the %s). it's sending the temperature that's set. it's beta3 on GitHub, from master branch.
                  ArcherS
                  #101
                  @therealdb my feeling was that I had missed something.
                  Yes I think it could be a good usecase.
                  Edit: I got to send the Mqtt message a few times, but not every time. Not sure why it does not send every time though. Does it matter if it is "off" or "heat"?
                  Edit 2: It seems as if it works! 🙂 Mode "off" and then the set temp sends the Mqtt message. Maybe if was a poll delay or something. I will test some more.
                  I tried to add the above mqtt:// into the SetSetpoint URL but nothing seems to be sent, i.e. nothing is appearing in the Tasmota Console.
                  This is what I see in the log (device no 52):
                  2021-05-12 20:18:02.023   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=843427346&Timeout=60&MinimumDelay=1500&_=1620843427214 HTTP/1.1 tcp{client}: 0x1b09e50
                  2021-05-12 20:18:14.970   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=52&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=19 HTTP/1.1 tcp{client}: 0x2204008
                  2021-05-12 20:18:14.972   luup.call_action:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint
                  2021-05-12 20:18:14.973   openLuup.server:: request completed (44 bytes, 1 chunks, 2 ms) tcp{client}: 0x2204008
                  2021-05-12 20:18:20.877   openLuup.server:: GET /console?page=log.1 HTTP/1.1 tcp{client}: 0x2204008
                  2021-05-12 20:18:20.981   openLuup.server:: request completed (185478 bytes, 0 chunks, 102 ms) tcp{client}: 0x2204008
                  2021-05-12 20:18:21.107   openLuup.server:: GET /favicon.ico HTTP/1.1 tcp{client}: 0x2204008
                  2021-05-12 20:18:21.107   openLuup.servlet:: file not found:favicon.ico
                  2021-05-12 20:18:21.108   openLuup.server:: request completed (126 bytes, 0 chunks, 0 ms) tcp{client}: 0x2204008
                  2021-05-12 20:18:21.108   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x2204008
                  2021-05-12 20:18:23.314   openLuup.io.server:: HTTP:3480 connection from 192.168.1.145 tcp{client}: 0x1c7ed70
                  2021-05-12 20:18:23.316   openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x1c7ed70
                  I also tried with a number, e.g. "20" instead of %s but no difference.
                  Startup log, it seems as if I have the right version:
                  2021-05-12 20:29:18.833   luup_log:52: VirtualHeater starting...
                  2021-05-12 20:29:18.834   luup_log:52: VirtualDevices[3.0-beta3@52]:Plugin starting
                  2021-05-12 20:29:18.834   luup.device_message:: device=52, status=4, message=Starting..., timeout=5, source=VirtualDevices
                  2021-05-12 20:29:18.834   luup_log:52: VirtualDevices[3.0-beta3@52]:Child #52 - "VirtualHeater2"
                  2021-05-12 20:29:18.835   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeTarget
                  2021-05-12 20:29:18.837   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeStatus
                  2021-05-12 20:29:18.838   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1.CurrentSetpoint
                  2021-05-12 20:29:18.840   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint
                  2021-05-12 20:29:18.841   luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature
                  2021-05-12 20:29:18.841   luup.set_failure:: status = 0
                  2021-05-12 20:29:18.841   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                  2021-05-12 20:29:18.842   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                  2021-05-12 20:29:18.842   openLuup.scheduler:: [52] VirtualHeater2 device startup completed: status=true, msg=Ready, name=VirtualDevices
                  • A ArcherS
                    @archers temp is sent for set target only, but I could add easily to power on/off.
                      ArcherS
                      Thanks for all the effort! It could be a useful addition for a more generic usecase, i.e. to have the posibility to add on/off in the same way as for temperature with a vaiable similar to %s.
                      I tested on my Fujitsu and "Power":"On" resp "Power":"Off" in the Mqtt message turns it on and off so it seems quite straight forward.
                      For my particular usecase I may go in a slightly different direction. My idea is to put the Tasmota IR so that it can both send commands to the HVAC and also that it can capture commands from the remote via Mqtt and IrReceived.
                      I have tested this a bit and it seems to work quite well. I setup at Reactor pulling the data sent from the remote to the HVAC and also sending data to the HVAC, so far only when changing the temp, but I may add e.g. fan speed.
                      • A ArcherS
                        @archers heater is a bit behind the others, where I’m already supporting mqtt messages to update values. I could add it easily over the weekend. You’ll find two variables to update. Send me your messages, so I could try to replicate it and give you precise instructions. It’s one of the things I’ll change in my setup, so it’s work I’m doing for myself as well 😉
                          ArcherS
                          @therealdb for my Fujutsu unit:
                          Message to turn off device:
                          mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"Off","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                          Message to turn on device:
                          mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                          I do not know if it would be possible to control the fan also, I am not sure there is a good controller for it. If so the fan is controlled with the "Fanspeed" being set to five values 1-4 and auto: "Min", "Low", "Medium", Max" and "Auto" e.g.
                          mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Max","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                          • A ArcherS
                            @archers after we’re done with heaters, I’ll definitely add a thermostat to the mix, even if it’s a mess and it’s not easy. In the meantime, you could control it with a dimmer. Maybe it’s time to add transformation to the mix, so we could easily produce a range (1…4) from 0/100.
                            Anyway, I was speaking of mqtt messages to get the status, if available in your use case - ie when changing the mode via the official remote.
                              ArcherS
                              #107
                              @therealdb I also thought of using a dimmer or something similar. 🙂
                              When I press the remote and the IR reveiver in the Tasmota captures that I get an IrReceived message in the Console:
                              07:45:47 MQT: tele/TasmotaIR/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE0930400400000000206C","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
                              It always contains the same elements as above, i.e. it reports all of the status fields every time.
                              So e.g. when changing the fan to "Min":
                              01:57:31 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE09304004040000002068","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Min","SwingV":"Off","SwingH":"Off","Quiet":"On","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
                              IRVAC{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Min","SwingV":"Off","SwingH":"Off","Quiet":"On","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                              The FanSpeed values are:
                              "FanSpeed":"Min"
                              "FanSpeed":"Low"
                              "FanSpeed":"Medium"
                              "FanSpeed":"Max"
                              "FanSpeed":"Auto"
                              When powered on:
                              01:55:23 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE0930410400000000206B","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
                              When powered off:
                              00:26:45 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":56,"Data":"0x0x146300101002FD","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Off","Power":"Off","Celsius":"On","Temp":16,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
                              For some reason it also sends "Mode":"Off" when powered off and not only "Power":"Off"
                              When changing mode you get for the four modes:
                              "Mode":"Heat"
                              "Mode":"Cool"
                              "Mode":"Dry"
                              "Mode":"Auto"
                              When I have looked in the Tasmota IR wiki there is some info on this also.
                              Both the IrReceived and IRhvac send protocols seem quite generic in terms of the mode, fan speed etc.
                              • A ArcherS
                                "FanSpeed":"Min"
                                "FanSpeed":"Low"
                                "FanSpeed":"Medium"
                                "FanSpeed":"Max"
                                "FanSpeed":"Auto"
                                When powered on:
                                When powered off:
                                "Mode":"Heat"
                                "Mode":"Cool"
                                "Mode":"Dry"
                                "Mode":"Auto"
                                @archers it should be easy to get the status, since the commands are easily sent. I’ll add the support for status over the week-end.
                                • A ArcherS
                                  "FanSpeed":"Min"
                                  "FanSpeed":"Low"
                                  "FanSpeed":"Medium"
                                  "FanSpeed":"Max"
                                  "FanSpeed":"Auto"
                                  When powered on:
                                  When powered off:
                                  "Mode":"Heat"
                                  "Mode":"Cool"
                                  "Mode":"Dry"
                                  "Mode":"Auto"
                                  #109
                                  @archers ok, new build is on GitHub.
                                  if you want to match for tele/tasmota_E0D649/RESULT topic with a message that contains IrReceived.IRHVAC.Power and a value of Off (case sensitive) use
                                  tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off
                                  As you can see, we could also match a path and get its value:
                                  tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Temp/=/*
                                  I've also added the ability to get the current temperature via MQTT as well. I'll update the docs later, with the new formats.
                                    ArcherS
                                    #110
                                    Should it be mqtt://tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off etc?
                                    I tried both with and without "mqtt://" but I cannot see any changes on the varibles of the device.
                                    Checked the log and it says beta 4 so it should be installed properly.
                                    Edit: problem solved, see below.
                                    The variables I have for the device are as below, there could very well be something wrong with them; I have not yet got full controll of the settings for heater device. 😕
                                    • A ArcherS
                                      ArcherS
                                      #111
                                      @therealdb now it works! 🙂
                                      I managed to find what I think was the error. I somehow some time ago have managed to copy all the VirtualDevices files into a sub-folder in the cmh-ludl folder. Stupid error my my side that gave a lot of strange behaviour...
                                      I simply removed the sub-folder and reloaded the master branch from the "plugins" tab in AltUi and then it worked as it should.
                                      The variables are now:
                                      In other words it should be mqtt://tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off etc i.e. with the mqtt:// prefix.
                                      Thanks for a great addition to the plugin, I will play some more with this one and see that it works as supposed. 🙂
                                      Edit: I discovered that the changing the temp on the OpenLuup device via "SetSetpointURL" does only work when the "ModeState" is "Heating".
                                      It seems as if "ModeState" reverts to "Idle" and then changing the temperature from the OpenLuup device with the "SetSetpointURL" does not work. Is this something that can be changed?
                                      • A ArcherS
                                        No need to use the prefix for the incoming messages, but it should discard it anyway.
                                        I’ll take a look at setpoint, but I fear it’s not updating it because of the way heaters are coded. Maybe a thermostat in your case could be better, but it’ll need more work on my part.
                                          ArcherS
                                          @therealdb you are of course correct, I tested and it works both with and without the mqtt:// prefix for the incoming messages.
                                          I changed the "CurrentTemperature" to a value that always will be lower than the setpoints ( in my case 10 degrees), by doing this the "ModeState" stays at "Heating" which means that the changing the temperature from the OpenLuup device works. Quite obvious of course when you think of it. 🙂
                                          All in all it works as it should, thanks for the hard work!
                                          My current variables with everything working:
                                            163.0k
