  3. Security exposure with internet connected homes
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied. I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film. Are there any products on the market that would work for my application?
Looking for Bluetooth device for smartphone audio transmission
Hello, I am in search of a device capable of using Bluetooth to connect with a smartphone and serve as its primary sound source on demand. This device should function similarly to conventional Bluetooth headphones, which automatically become the phone's sound output upon activation. However, this device should differ in that it transmits the audio signal to an amplifier via a jack, SPDIF, or similar connection. Alternatively, it could be an integrated amplifier that directly sends the signal to passive speakers. The control of this process should be manageable through an API such as MQTT, REST, MODBUS, or similar. Are you aware of any devices that operate in this manner? The concept is as follows: upon entering the bathroom, I would press a wall-mounted switch. This switch would send a signal to the Bluetooth device, prompting it to connect to my smartphone and seamlessly continue playing the audiobook I am currently listening to. Instead of using the phone's speakers, it would seamlessly start playing through ceiling-mounted speakers. Many thanks
Beginner assistance
Hi folks, I currently have some cheap Zigbee hub and some Amazon Alexas running my smart home which mostly consists of Zigbee power strips and Zigbee battery powered switches. It all worked OK originally, but now whenever I press a Zigbee switch the light in the corresponding plug switches on then immediately off again. If I ask Alexa to turn the light on it works fine. Likewise if I switch it on from my phone. Any ideas what the issue could be? I've tried unplugging the hub a number of times but that doesn't seem to fix it. I was thinking about getting a Homey Pro 2023 to speed things up (tmas the Zigbee hub seems to be really slow now as well, for some reason) but I'm not sure about that either. Any suggestions greatly appreciated!
16 Posts 6 Posters 904 Views 6 Watching
    I am a pretty active forum user over on the QNAP forum and there has been a number of viral threads there and on reddit about the spread of ransomware on these NAS.
    I wanted to post here to say that this is a fresh reminder to be very cautious with the current state of the affair when it comes to smarthomes and the trend towards IOT we are observing from all these companies attempting to make our homes cloud dependent, opening so called "secure tunnels" to their servers which can turn into very real exposures to your LAN (home network).
    In order to mitigate it, QNAP released a firmware which now has autoupdate enabled by default (reminds me one other company...) and IMHO is the climax of absurdity but in fact when I come to think about it is how the amazon echos and ecobees work for example without even offering the ability to disable.
    I am in no way a security expert but have had enough exposure and interest about it to recommend using a real firewall for your home network to block these backdoors if you have a smarthome and avoid these cloud oriented platforms and devices as if they were COVID.
      Apple's OK, though ... ? (Homehub mini / Homekit / Home)
      • DesTD Offline
        DesTD Offline
        DesT
        wrote on last edited by DesT
        I'm your man if you want to talk about cyber security 😉
        Doing that for the last 25years!
          @akbooer
          It's better in two ways that I can see:
          1. They don't auto-update their firmware by default. This exposes you to surprises when you come back to a broken system. I went on a very long tirade on the ecobee forum years ago about how risky such a feature is only to find out the amazon echos are doing the same thing. I was very happy to get rid of all of these devices. These companies think that this is a security feature because they automatically load security patches in these updates for ignorant users. The problem is the downtime these automatic updates create and risk of breaking something during the update or within the firmware itself. It is not so different from the nightly heal philosophy. The thought of automating a maintenance is all good intention but it is pushing downtime and often very high risks of breaking something without any control.
          2. They don't send your voice recording for processing if it can process locally. It does send the STT (Speech to text) output though whenever it can. This is more a privacy issue than security.
          They are still cloud connected devices so there is still an exposure. If their servers get hacked and your credentials are exposed, one can actually take control of your homekit. The connection from their server to your device though is much more secure (than QNAP's default scheme which exposes a lot of things). Maybe @DesT will have more knowledge of this. 😉
          Homekit isn't by any stretch of the imagination more secure than the Google or the Amazon platform. It is just a bit better in terms of privacy and much better in terms of performance and reliability. The ideal security is for it not to be connected to the cloud at all which was Rhasspy or Mycroft are offering.
          • DesTD Offline
            DesTD Offline
            DesT
            yeah.... rule #1 in my work is:
            Connected=hacked
            Cloud=leak
            So of course, I'm also a non-cloud user as much as possible and it's one of the reason why almost all of our clients are not "cloud" too!
            I'm 100% for doing regular update BUT never automatically and even more for firmware. Firmware can break thing often and it's always too late after!
            We are also always checking what's the RELEASE NOTES are saying about an update to check if something can break and also checking on internet if ppl are complaining about an update that break something.
            The problem with things like QNAP it's the service they offer to allow people reaching their "data" from Internet by using their cloud service to send you back inside your home network! That's why I will always prefer having a VPN connection from my device directly to the home network when necessary.
            Just google what happen with Solarwinds and you will have more fear about being "connected"!
            • parkercP Offline
              parkercP Offline
              parkerc
              Totally agree
              And being a long term QNAP User myself, I’ve so far (touch wood) avoided any of these attacks, but I put that down to the obvious and never exposing my NAS to the internet, I’m amazed at how many people place theirs at the perimeter - and I agree QNAP don’t help, as they have add-ons that almost encourage it.
              I appreciate nothing is going to be 100%, but for a while now I’ve been happy with my UniFi Secure Gateway (Router) with it’s VPN capability which allows me to connect back in as/when I need to.
                I am still following the events unfolding. It is indeed amazing to me how many people had their NAS open and accessible directly through port forwarding...
                S 1 Reply Last reply
                  Another week has passed and now there is a breach in the Eufy security camera platform and we have seen what has happened to the Colonial pipelines in the US... I wonder who is next. Highly encourage people to be much more deliberate and conscientious with what device you buy and install in your homes...
                    sender
                    @rafale77 it functionality vs usability... if you do not forward specific ports (smtp, ftp, etc) you van not use the device as intendes. And placing it behind a vpn is not workable in that sense...
                      sender
                      @rafale77 exactly! I don't care anymore and place all tunnelneeding devices in a separate vlan/segment with internet access...
                      • S sender
                        @sender said in Security exposure with internet connected homes:
                        Well that rather depends on the device. Alexa, for example, requires no port forwarding. A NAS probably would but can be accessed via a VPN.
                        For example my mail server does need very specific ports (obviously) but they are not forwarded. I connect to my own VPN end point.
                        The only port I have open is a non-standard SSH port. However Alexa creates her own connections which may be insecure.
                        So not quite sure what case you're looking at here.
                          @CatmanV2 is correct. It's not just about port forwarding. In many case it is the cloud server getting hacked, exposing your credentials and allowing people to access your account. The reason for my post about being careful with the devices you buy... is more related to smart home devices or I would say IOT devices getting hacked from the "I" internet. The latest as of this morning about Eufy cameras is an example. See here
                          Access to Random Cameras in another country
                          It always blew my mind that anyone would want their cameras to stream anywhere outside their own network besides through a direct VPN but... you see all of these cloud doorbells and cloud cameras services but the same is true for all the other smart thermostats etc... which I have either eliminated or am isolating and aggressively blocking access to/from WAN.
                            Well this, frankly.
                            My alarm installer was looking some new tech that could actually interface with z-wave, which was of interest. Turns out that all its security functions are cloud dependant....
                              sender
                              @catmanv2 hence I have a separate vlan/sybnet for "tunneling" and outbound session things (mostly IOT). And specific ports forwarded to a nas (compared to a vpc but locally managed)
                              • S sender
                                I should really do the same thing. But I'm not convinced that there's really much benefit. My Alexas still need to talk to HA bridge. I guess I could put HA bridge on a separate machine and then allow only connections from that IP into the main device but that doesn't seem any more robust than the current set up.
                                Perhaps a better piece would be to separate all my critical services so keep NotVera and HA bridge and Alexa all on a separate subnet.
                                  Could be a bizarre follow up to a post I made on another thread but it may be more related to this topic so I am posting here. Oddly things are unraveling... It is confirming my own observations that Android devices seem to send a lot of data, a lot more than iOS devices even when you don't them to. This is odd because of how hit and miss geofence on android has been yet I am observing that they update Google about where your device is a lot more frequently and with a lot more "details" than iOS devices do.
                                  https://www.businessinsider.in/tech/news/apple-is-eating-our-lunch-google-employees-admit-in-lawsuit-that-the-company-made-it-nearly-impossible-for-users-to-keep-their-location-private/articleshow/83063947.cms
                                    35.4k
                                  • Z-Wave Future....
                                  • Can´t restart or upgrade/deploy MSR
                                  • [Solved] Limit HA Entity in MSR
                                  • Disaster recovery and virtualisation
                                  • Remote access of Zwave stick from Z-wave server
                                  • Organizing/ structuring rule sets and rules
                                  • Moving MSR from a QNAP container to RP 5 - some issues
                                  • Widget deletion does not work and landing page (status) is empy
                                  • Need help reducing false positive notifications
