  3. Plugins
  4. openLuup: Tasmota MQTT Bridge
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
Plugins
AltUi
Plugins
127 Posts 5 Posters 104.7k Views 4 Watching
  • A ArcherS
    @therealdb I also thought of using a dimmer or something similar. 🙂
    When I press the remote and the IR reveiver in the Tasmota captures that I get an IrReceived message in the Console:
    07:45:47 MQT: tele/TasmotaIR/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE0930400400000000206C","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
    It always contains the same elements as above, i.e. it reports all of the status fields every time.
    So e.g. when changing the fan to "Min":
    01:57:31 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE09304004040000002068","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Min","SwingV":"Off","SwingH":"Off","Quiet":"On","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
    IRVAC{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Min","SwingV":"Off","SwingH":"Off","Quiet":"On","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
    The FanSpeed values are:
    "FanSpeed":"Min"
    "FanSpeed":"Low"
    "FanSpeed":"Medium"
    "FanSpeed":"Max"
    "FanSpeed":"Auto"
    When powered on:
    01:55:23 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE0930410400000000206B","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
    When powered off:
    00:26:45 RSL: tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":56,"Data":"0x0x146300101002FD","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Off","Power":"Off","Celsius":"On","Temp":16,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
    For some reason it also sends "Mode":"Off" when powered off and not only "Power":"Off"
    When changing mode you get for the four modes:
    "Mode":"Heat"
    "Mode":"Cool"
    "Mode":"Dry"
    "Mode":"Auto"
    When I have looked in the Tasmota IR wiki there is some info on this also.
    Both the IrReceived and IRhvac send protocols seem quite generic in terms of the mode, fan speed etc.
    #109
    @archers ok, new build is on GitHub.
    if you want to match for tele/tasmota_E0D649/RESULT topic with a message that contains IrReceived.IRHVAC.Power and a value of Off (case sensitive) use
    tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off
    As you can see, we could also match a path and get its value:
    tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Temp/=/*
    I've also added the ability to get the current temperature via MQTT as well. I'll update the docs later, with the new formats.
      ArcherS
      #110
      @therealdb said in openLuup: Tasmota MQTT Bridge:
      Should it be mqtt://tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off etc?
      I tried both with and without "mqtt://" but I cannot see any changes on the varibles of the device.
      Checked the log and it says beta 4 so it should be installed properly.
      Edit: problem solved, see below.
      The variables I have for the device are as below, there could very well be something wrong with them; I have not yet got full controll of the settings for heater device. 😕
      • A ArcherS
        ArcherS
        #111
        @therealdb now it works! 🙂
        I managed to find what I think was the error. I somehow some time ago have managed to copy all the VirtualDevices files into a sub-folder in the cmh-ludl folder. Stupid error my my side that gave a lot of strange behaviour...
        I simply removed the sub-folder and reloaded the master branch from the "plugins" tab in AltUi and then it worked as it should.
        The variables are now:
        In other words it should be mqtt://tele/tasmota_E0D649/RESULT/=/IrReceived.IRHVAC.Power/=/Off etc i.e. with the mqtt:// prefix.
        Thanks for a great addition to the plugin, I will play some more with this one and see that it works as supposed. 🙂
        Edit: I discovered that the changing the temp on the OpenLuup device via "SetSetpointURL" does only work when the "ModeState" is "Heating".
        It seems as if "ModeState" reverts to "Idle" and then changing the temperature from the OpenLuup device with the "SetSetpointURL" does not work. Is this something that can be changed?
        • A ArcherS
          @archers said in openLuup: Tasmota MQTT Bridge:
          No need to use the prefix for the incoming messages, but it should discard it anyway.
          I’ll take a look at setpoint, but I fear it’s not updating it because of the way heaters are coded. Maybe a thermostat in your case could be better, but it’ll need more work on my part.
            ArcherS
            @therealdb you are of course correct, I tested and it works both with and without the mqtt:// prefix for the incoming messages.
            I changed the "CurrentTemperature" to a value that always will be lower than the setpoints ( in my case 10 degrees), by doing this the "ModeState" stays at "Heating" which means that the changing the temperature from the OpenLuup device works. Quite obvious of course when you think of it. 🙂
            All in all it works as it should, thanks for the hard work!
            My current variables with everything working:
            • A ArcherS
              @archers great!
              I’m thinking of creating a cooler device, because I need it myself. It’s really stupid imho that they created heaters, complex thermostats, but no humidifier, dehumidifier or cooler device. But since we’re not tied to Vera anymore, I guess it’s time to add them, as I did with my own virtual alarm/alarm partition.
              • B Buxton
                @akbooer I did some debug on the error messages above and came up with the following. I placed some debug entries in the "L_TasmotaBridge.lua" to try to see what was causing the errors. First the code: under function _G.Tasmota_MQTT_Handler (topic, message)
                  local myMessage = ""
                  if message == nil then
                     myMessage = "Message is null"
                  else
                	if message == "" then
                	 myMessage = "Message is empty"
                	else
                	 myMessage = message
                  _log ("JSON error info " .. myMessage)
                Which produced the following log errors and their context:
                2021-04-16 20:48:01.335   openLuup.io.server:: MQTT:1882 connection from 10.17.2.28 tcp{client}: 0x55fac42317b8
                2021-04-16 20:48:01.355   luup.tasmota:262: JSON error info Online
                2021-04-16 20:48:01.356   luup.tasmota:262: JSON error: ?
                2021-04-16 20:48:01.366   luup.tasmota:262: JSON error info Message is empty
                2021-04-16 20:48:01.367   luup.tasmota:262: JSON error: ?
                2021-04-16 20:48:01.423   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/power_BedroomTV/# tcp{client}: 0x55fac42317b8
                2021-04-16 20:48:01.432   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55fac42317b8
                2021-04-16 20:48:01.433   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/BedroomTV_fb/# tcp{client}: 0x55fac42317b8
                B Offline
                B Offline
                Buxton
                @akbooer I think I found the culprit causing the random connection disconnects to Mosquitto. The LWT payload for a given device is a simple string, which doesn't seem to decode in the json decode call. So I added the below code to send a json string to the decoder. The errors have disappeared and I now see the LWT variable in the service variables. The variable reads "LWT : Online"
                --line 165
                local valid = {SENSOR = true, STATE = true, RESULT = true, LWT = true}
                --line 172
                  -- begin code
                  local info, err = json.decode (message)
                  if message then
                	if not info then  -- json did not decode because of single string parameter
                		message = '{' .. '"' .. mtype .. '"' .. ':' .. '"' .. message .. '"' .. '}'
                  -- end code
                This is probably not the way you would handle the error, but it does work.
                akbooerA 2 Replies Last reply
                • B Buxton
                  --line 165
                  --line 172
                    -- begin code
                    if message then
                    -- end code
                  #116
                  @buxton
                  Great work!
                  There may be some compatibility problem betwen JSON decoders – which one are you using (openLuup / Cjson / RapidJson) ? The beginning of the Startup Log should tell you...
                  2021-06-06 20:08:48.470   openLuup.json::        version RapidJSON (0.6.1) + openLuup (2021.05.01)  @akbooer
                  B 1 Reply Last reply
                  • B Buxton
                    --line 165
                    --line 172
                      -- begin code
                      if message then
                      -- end code
                    @buxton
                    Should now be fixed in development v21.6.8.
                    My implementation, FYI:
                      local tasmota, mtype = tasmotas: match "^(.-)/(%u+)"
                      local valid do            -- thanks @Buxton for LWT as text message
                        local j, t = "json", "text"
                        valid = {SENSOR = j, STATE = j, RESULT = j, LWT = t}
                      local decoder = valid[mtype]
                      if not (tasmota and decoder) then
                        _log (table.concat ({"Topic ignored", topic, message}, " : "))
                        return
                      local info, err
                      if decoder == "text" then
                        info = {[mtype] = message}
                      else
                        if not info then
                          _log ("JSON error: " .. (err or '?'))
                          _log ("Received message ignored: " .. message)
                          return
                      @buxton
                      Great work!
                      B Offline
                      B Offline
                      Buxton
                      @akbooer I used openluup json. I tried dkjson, but there was no change in effect.
                        @buxton
                            return
                          local info, err
                          else
                            if not info then
                              return
                        B Offline
                        B Offline
                        Buxton
                        @akbooer Yes, that should work. However, the LWT MQTT specification calls for a standard message, so a tasmota upgrade could change the text message to a json message. Is there a way to test the message for a non-json string, and then filter accordingly. I fear the hardcoded flags will inevitably break....
                          Yes, I thought of doing it that way. A simple check for a leading [ or { should be adequate.
                          This is the one thing I don’t like about Tasmota (as mentioned a while ago) … no real standards.
                            OK, so here's what it will be now, a hybrid of our approaches...
                              local valid = {SENSOR = 1, STATE = 1, RESULT = 1, LWT = 1}    -- thanks @Buxton for LWT as text message
                              if not (tasmota and valid[mtype]) then
                                return
                              local info = json.decode (message) or {[mtype] = message}   -- treat invalid JSON as plain text
                            B 2 Replies Last reply
                                  return
                              B Offline
                              B Offline
                              Buxton
                              @akbooer Awesome. Cool lua magic using the exception return with "or". That should cover all text messages that are topic filtered.
                                    return
                                B Offline
                                B Offline
                                Buxton
                                @akbooer Can I ask you for one more addition. I'd like to be able to set tasmota prefixes and suffixes via lua startup. Something like:
                                attr ("openLuup.Tasmota.Prefix", "tele", "tasmota/tele","stat")
                                attr ("openLuup.Tasmota.Topic", "SENSOR", "STATE","RESULT", "LWT")
                                You'd also need to change the upper case error check on the topic as some of the full topic suffixes are not all in upper case:
                                local tasmota, mtype = tasmotas: match "^(.-)/(.+)"
                                • B Buxton
                                  @buxton said in openLuup: Tasmota MQTT Bridge:
                                  Try the latest development version (21.6.12b)
                                  A tiny syntax difference from your suggestion, you need to write...
                                  attr ("openLuup.Tasmota.Prefix", {"tele", "tasmota/tele", "stat"})
                                  attr ("openLuup.Tasmota.Topic",  {"SENSOR", "STATE", "RESULT", "LWT"})
                                    B Offline
                                    B Offline
                                    Buxton
                                    @akbooer After updating to the lastest development version (21.6.12b), I did a direct copy and paste of the above attr code into startup lua, and it appears that openLuup hangs on the ipairs iteration, because the ipairs statement is seeing a string instead of a table. I was then able to boot openLuup by removing the "or" clause :
                                    --local prefixes = config.Prefix or {"tele", "tasmota/tele"}       -- subscribed Tasmota prefixes
                                      local prefixes = {"tele", "tasmota/tele"}       -- subscribed Tasmota prefixes
                                      for _, prefix in ipairs (prefixes) do
                                        luup.register_handler ("Tasmota_MQTT_Handler", "mqtt:" .. prefix .. "/#", prefix)   -- * * * MQTT wildcard subscription * * *
                                    The topic table has the same problem.
                                    I was able to see the error message when using "./openLuup_reload" at the linux command prompt.
                                      #126
                                      Oh yes, that's the traditional Vera-compliant Luup API for you, which only allows string attributes.
                                      TBH, I don't use that much these days. Sorry about that.
                                      Two ways forward:
                                      1. This will work right now:
                                      local oL = luup.attr_get "openLuup"
                                      oL.Tasmota = {
                                          Prefix = {"tele", "tasmota/tele", "stat"},
                                          Topic = {"SENSOR", "STATE", "RESULT", "LWT"}}
                                      1. I could change the Tasmota code to accept:
                                      attr ("openLuup.Tasmota.Prefix", "tele, tasmota/tele, stat")
                                      attr ("openLuup.Tasmota.Topic",  "SENSOR, STATE, RESULT, LWT")
                                      which might be better in the long run.
                                        Two ways forward:
                                        oL.Tasmota = {
                                        B Offline
                                        B Offline
                                        Buxton
                                        @akbooer I'm good as I don't have additional topics that must be added at the moment. So the code change is probably the way to go.
                                          163.0k
