Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
67 Posts 3 Posters 35.6k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi @rafale77
    With your help, could we make this ‘shift’ run almost like a batch like process on the same device, by that I mean.
    After doing a backup of the old Vera and a restore onto the new one.
    Could I move the UZB1 USB dongle onto the new VeraPlus, ensuring it’s operational and working first under /dev/ttyACM0
    Then is there a set of commands I could run that does the cloning straight off from /dev/ttyACM0 (UZB1) onto to /dev/ttyS0 (onboard) ?
    And then ideally at the end of that, could it update the new Vera z-wave config to now look at /dev/ttyS0 (onboard) allowing me to move the UZB1 dongle (and store it away) ?
      It's not a very hard thing to do but I unfortunately gave away most of my veras and only have a couple of bricked ones left so I can't test this.
      There was another way which was to manipulate the zwave serial port inside your backup user-data.json which is what I had to do but it takes decompressing your backup and the user-data.json.lzo and the compress it back and then restore that backup.
      The silliness of the backup restore process is that it is very rigid and doesn't allow you to restore to a different serial port than what your original backup file. What I gave you should work though... manually grab the last dongle file from one unit, move it to the other one and with your UI already showing the new target serial port, start a dongle restore.
      As I previously said, I also highly recommend you stay with the usb stick. It likely has greater range and upgradeability.
      parkercP 1 Reply Last reply
        parkercP Offline
        parkercP Offline
        parkerc
        I’d actually seriously consider that, but the upgrading route for the z-way UZB1 dongle, seems so unnecessarily complicated .
        One of the reasons for getting the new Vera was because a Fibaro RGBW Module was appearing as many multiple nodes, and Vera support had a look and seemed to suggest it was due to the z-wave version I was running.
        parkerc said in Controller shift - How do you do it ?:
        My UZB1 usb stick is on 4.05 L:1 - Role: Suc SIS: YES PRI: YES
        The new Vera is on 6.01 L:1 - Role: Master SIS: NO PRI: YES
          upgrading firmware on a UZB is actually quite easy...
          what is the brand of your stick?
          Sep 28, 2018
          Updating firmware on Silicon Labs Z-wave UZB USB sticks
          There may be occasions when it becomes necessary to update the firmware of Silicon Labs Z-wave UZB controller USB sticks. Firmware updates may be needed when new SDKs are released or a change in UZB functionality is required. UZB firmware can be updated using Silicon Labs Windows based Z-Wave...
            Sep 28, 2018
            parkercP Offline
            parkercP Offline
            parkerc
            Z-wave.me - ZMEEUZB
            UZB
              Ahhhhh then this is what you need:
              https://z-wave.me/zmeserialupdater-manual/
              and it is indeed a little more complicated due to the need of following this crazy map:
              https://service.z-wave.me/expertui/uzb-stats/versions-graph.html
              • parkercP Offline
                parkercP Offline
                parkerc
                Yep, that’s it 🙂 and I think you even helped me a while back, as that ‘crazy map’ was doing me head in.
                Trying to follow it drove me crazy !
                  I can help you read through it and break down the commands to upgrade if you want me to. What is your current firmware version?
                    I am afraid a controller shift will not help in this case. The problem stems from rigidity of the restore tool of the vera. What you are observing is completely expected.
                    The vera controller backup contains two things:
                    1. The user-data file along with all your plugin data.
                    2. The zwave dongle network backup.
                    When you did the restore from backup step on your new vera, your user-data had your port as /dev/ttyACM0 so during the restoration the vera attempted to restore the zwave network to that port which obviously did not exist. What you need to do now that you changed the zwave serial port back to the vera onboard chip, is to manually grab the latest dongle backup file from the old vera (it's in /etc/cmh-ludl) and move it to the new vera in the same location. Use SFTP to do this.
                    Then SSH into the new vera and run
                    touch /etc/cmh-ludl/dongle.restore
                    then reload luup. It should normally restore your previous zwave network configuration into the new vera zwave chip.
                    Another alternative is of course to just plug your uzb zwave dongle into the new vera.... I actually prefer using USB these days for exactly this kind of moves.
                    To be clear on what a controller shift does:
                    It is a combination of inclusion of a new controller and moving the zwave master flag from the master controller to the new controller. The problem with this is the node numbering and will leave you with the vera not being node 1 on your zwave network. It could be ok but some devices may not like it. Sensors for example may have issues with their lifeline associations. The lifeline association is essentially a direct relation to the target controller a device reports its data to. The controller shift was very relevant for the time when zwave was just controlling lights from a controller which was a remote control. After that it has become less and less useful.
                    parkercP Offline
                    parkercP Offline
                    parkerc
                    Hi @rafale77
                    Picking this up again as i have managed to find a bit of time - and looking on my Vera I can’t see that a dongle.restore.sh file, plus the dongle files seem to be in /etc/cmh rather than /etc/cmh-ludl see below..
                    root@MiOS_55100454:/# find -name dongle*.*
                    ./etc/cmh/dongle.4.5.dump.0
                    ./etc/cmh/dongle.4.5.dump.1
                    ./etc/cmh/dongle.4.5.dump.2
                    ./etc/cmh/dongle.4.5.dump.3
                    ./etc/cmh/dongle.4.5.dump.4
                    ./etc/cmh/dongle.4.5.dump.5
                    ./ezmi/cmh/dongle.4.5.dump.0
                    ./ezmi/cmh/dongle.4.5.dump.1
                    ./ezmi/cmh/dongle.4.5.dump.2
                    ./ezmi/cmh/dongle.4.5.dump.3
                    ./ezmi/cmh/dongle.4.5.dump.4
                    ./ezmi/cmh/dongle.4.5.dump.5
                    Any ideas where the dongle.restore file might be or if it’s called something different ?
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Have looked here too, which has helped a bit.. https://smarthome.community/topic/199/problem-migration-z-wave-nw-from-vera-to-uzb1-dongle?_=1632067117298
                      The issue seems to be the dongle.restore file requirements
                      If it helps, i found this within the ./mios/www/cgi-bin/cmh/restore.sh file
                      if [ "$FORM_dongle" == "1" ]; then
                                      # LuaUPnP will restore the Z-Wave backup file if it finds the 'dongle.restore.go' file.
                                      # To prevent LuaUPnP from restoring a dongle backup until the next boot,
                                      # we'll save the file as 'dongle.restore', and the 'Start_cmh.sh' script will rename it to 'dongle.restore.go'.
                                      log "Create $MIOS_CONF_PATH/dongle.restore"
                                      touch "$MIOS_CONF_PATH/dongle.restore" 2>>$log_file
                              fi
                      And then looking in ./usr/bin/Start_cmh.sh the reference there is..
                      # to prevent LuaUPnP from restoring a dongle backup until the next boot,
                      # the web ui saves .restore and LU looks for .go
                      mv /etc/cmh/dongle.restore /etc/cmh/dongle.restore.go || /bin/true
                      Sadly not much further forward…
                        I don't want to be stupid, but have you actually made a backup? Unless it's automatic and storing locally.....
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Yep, I have made a local back up. (Inc z-wave network) and have it stored locally
                          Both Veras are on the network, I first went into the veraplus with the usb zwave dongle and did the full backup, saved it locally and then logged into the VeraSecure and did the restore.
                          Everything but the zwave devices was restored and based on what @rafale77 had said before my issue is that it’s trying to restore back to an /dev/ttyACM0 dongle, rather than the onboard one /dev/ttyS0
                          I somehow need to get the zwave records onto the right tty..
                            #21
                            So from memory, if you just create the dongle.restore.go file in /etc/cmh and reboot.....
                            But that is from memory
                            touch /etc/cmh/dongle.restore.go
                            Oh and obviously make sure your backup file is uploaded!
                              parkercP Offline
                              parkercP Offline
                              parkerc
                              #22
                              @catmanv2 said in Controller shift - How do you do it ?:
                              Hi @CatmanV2
                              That’s the bit I’m not sure about , so do I just create a blank file , with nothing in it and call it a dongle.restore.go?
                              Also, just to confirm do I copy over the dongle back up file dongle.4.5.dump.0 into /etc/cmh too
                              Once both are in there (making sure the a-wave settings are set to the correct onboard zwave chip etc.) I can just do a reboot or luup.reload ?
                                I believe that's exactly it. Although if you create dongle.restore.go you'll need to reboot, not just luup.reload.
                                Clearly you might want to keep dongle.4.5.dump.0 as a copy somewhere, but I guess it depends on the current state of the Vera you are restoring to
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Ok, i gave that a go, but sadly no luck..
                                  FYI - The Veraplus (with external a-wave dongle), dongle dump files are already on the VeraSecure in the /etc/cmh folder - I assume they must have come over during the restore this morning.
                                  On the VeraSecure I ssh’d on to it and run that file creation command - touch /etc/cmh/dongle.restore.go
                                  So, all file are in /etc/cmh/ now..
                                  -rw-r--r--    1 root     root         16383 Sep 19 10:16 /etc/cmh/dongle.4.5.dump.0
                                  -rw-r--r--    1 root     root         16383 Sep  2 03:00 /etc/cmh/dongle.4.5.dump.1
                                  -rw-r--r--    1 root     root         16383 May 29 03:00 /etc/cmh/dongle.4.5.dump.2
                                  -rw-r--r--    1 root     root         16383 Mar 15  2021 /etc/cmh/dongle.4.5.dump.3
                                  -rw-r--r--    1 root     root         16383 Mar 11  2021 /etc/cmh/dongle.4.5.dump.4
                                  -rw-r--r--    1 root     root         16383 Feb 27  2021 /etc/cmh/dongle.4.5.dump.5
                                  -rw-r--r--    1 root     root             0 Sep 19 19:48 /etc/cmh/dongle.restore.go
                                  I did the full reboot, a few luup.reloads too, but still the same now zwave devices are shown or being picked up.
                                  Any ideas ?
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    Ok, found something in the Luaupnp logs, which suggests an invalid restore file ?? - interesting.. 🤔
                                    02	09/19/21 19:54:21.868	ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0  ports:/dev/ttyS0 - /dev/ttyS0 <0x77212320>
                                    02	09/19/21 19:54:21.868	ZWave::Start restoring dongle firmware <0x77212320>
                                    03	09/19/21 19:54:21.869	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77212320>
                                    01	09/19/21 19:54:21.882	ZWJob_BackupDongle::FixupBufferVersion not a valid 4.5 backup: 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff (<0x1b>[34;1m################<0x1b>[0m) <0x77212320>
                                    01	09/19/21 19:54:21.883	ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77212320>
                                    03	09/19/21 19:54:21.889	JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77212320>
                                    04	09/19/21 19:54:22.257	<Job ID="1" Name="restore" Device="1" Created="2021-09-19 19:54:21" Started="2021-09-19 19:54:22" Completed="2021-09-19 19:54:22" Duration="0.386898000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77212320>
                                    02	09/19/21 19:54:22.258	JobHandler::PurgeCompletedJobs purge job#1 :restore dev:1 (0xbb88a0) P:5 S:2 Id: 1 restore status 2 <0x7603c520>
                                    06	09/19/21 19:54:22.259	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: ComPort was: /dev/ttyXRUSB1 now: /dev/ttyXRUSB1 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77212320>
                                      OK that made me delete my answer but at least we know how to fire the restore!
                                      Where did your dump file come from, and how did you get it there?
                                      • parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        It must have got there via the original restore process.
                                        Ok, I’ve now copied over an earlier dongle dump direct from the VeraPlus, and made that the zero/0 one.
                                        scp dongle.4.5.dump.4 root@192.168.1.145:/etc/cmh/dongle.4.5.dump.0
                                        Let’s try again
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          Hummmmm, same error..🤔
                                          Does it matter that this is a 4.5 dump file, and the Vera secure is on zwave version 6.1 ?
                                          02	09/19/21 20:42:35.508	ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0  ports:/dev/ttyS0 - /dev/ttyS0 <0x77e96320>
                                          02	09/19/21 20:42:35.521	ZWave::Start restoring dongle firmware <0x77e96320>
                                          03	09/19/21 20:42:35.522	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77e96320>
                                          01	09/19/21 20:42:35.549	ZWJob_BackupDongle::FixupBufferVersion not a valid 4.5 backup: 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff (<0x1b>[34;1m################<0x1b>[0m) <0x77e96320>
                                          01	09/19/21 20:42:35.550	ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77e96320>
                                          03	09/19/21 20:42:35.551	JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77e96320>
                                          04	09/19/21 20:42:35.735	<Job ID="1" Name="restore" Device="1" Created="2021-09-19 20:42:35" Started="2021-09-19 20:42:35" Completed="2021-09-19 20:42:35" Duration="0.212538000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77e96320>
                                            162.4k
