  4. Installing MSR on Windows
13 Posts 3 Posters 3.8k Views 3 Watching
    Andr
    Well. Now I have looked, read, re-read and looked again. So now I am ready to get an surely obvious answer smashed in my face.
    How do I download the Reactor package??
    The link reactor.toggledbits.com/mantisbt leads to a login page, but no way to register, no link in the left margin...
      Did you PM me your full name and email? I don't think you did, but then, I've been a bit distracted today...
        Andr
        Nope, have not done that. Coming right up!
        I don't know were that information is, but you maybe can add it in your first post in this thread to help others in the future?
        Multi-System Reactor Developer Preview AVAILABLE:
          I split this off to its own thread...
          You know, I don't know. I just checked it and rolled on. I may have to uninstall/reinstall later and see if it makes a difference. But I went with it on to start.
          Andr
          @toggledbits said in Installing MSR on Windows:
          So now MSR is up and running ✌
          I start without adding the extra "Chocolatey" stuff in the Node.js install, so we will see if this comes back and bite me later on.
          But I try to have a little stuff on the system as possible.
          Rest of installation went as expected.
          When extracting using 7-zip there was some error messages, but I don't what that means or if it have anything to do with MSR.
            OK. I'll look into those. If it interferes with anything, it will be the dashboard, not Reactor itself, it looks like.
              Yay, proud of myself getting MSR v.21068 installed and running on a clean Windows 10 machine, just for fun.
              My next plan, if it's possible, is to configure MSR to work with the ezlo Plus I have running at that location.
              Will check the YAML files...
              EDIT: Nope, not yet implemented. Still can play with the UI and do bug reports in the meantime!
                LOL, even dug up my ol' trusty Vera 1 and am putting it through its initial Setup paces (not going smoothly -- "Update" fails, it wants to run Adobe Flash, which has since been discontinued, etc.). We'll see what MSR has to make of this dinosaur.
                EDIT: Quite shockingly, even my old Z-Wave dongle, which I thought had bitten the dust, appears to be working!?!? Also managed to log into extremely old MIOS1 servers with un/pw.
                EDIT 2: MSR no likey! When I enabled the Vera controller IP in reactor.yaml, and restarted MSR, it just kinda hung. Had to CTRL-C my way out. Oh, well! 😞
                EDIT 3: Nope, I spoke too soon. Even with Vera > enable: false, MSR seems to hang about 3 minutes on startup, then magically pops up with 21068 in the upper right corner. Will continue exploring what else may be hanging MSR up.
                EDIT 4: Reactor's fully up and running, connected to my Vera 1. A quick reboot of the host PC seemed to help!
                  Andr
                  wrote on last edited by Andr
                  Life has kept me busy this year so I haven't had time to tinker with any fun smarthome stuff for a long while.
                  So I was set to upgrade to latest version 21275 and install MSR as a service.
                  It have not gone well 😞
                  The service stops directly.
                  Info from daemon\reactor.err.log
                  Logging stream path spec may be using pre-21075 form; please remove ./logs/ from the path!
                  internal/modules/cjs/loader.js:883
                    throw err;
                  Error: Cannot find module 'ws'
                  Require stack:
                  - C:\reactor\server\wsapi\wsapi.js
                  - C:\reactor\app.js
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                      at Module.require (internal/modules/cjs/loader.js:952:19)
                      at require (internal/modules/cjs/helpers.js:88:18)
                      at Object.<anonymous> (C:\reactor\server\wsapi\wsapi.js:239:30)
                      at Module._compile (internal/modules/cjs/loader.js:1063:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                      at Module.load (internal/modules/cjs/loader.js:928:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                      at Module.require (internal/modules/cjs/loader.js:952:19) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [ 'C:\\reactor\\server\\wsapi\\wsapi.js', 'C:\\reactor\\app.js' ]
                  When I tries to start MSR normally i get a "NODE_PATH is missing" but I have set this, and with correct casing.
                  ||PS C:\reactor> set NODE_PATH=C:\reactor
                  PS C:\reactor> node app.js
                  basedir C:\reactor
                  confdir C:\reactor\config
                  datadir C:\reactor\storage
                  logsdir C:\reactor\logs
                  plugindir C:\reactor\ext
                  module.paths [ 'C:\reactor\node_modules', 'C:\node_modules' ]
                  NODE_PATH undefined
                  Required environment variable NODE_PATH is missing; can't continue.
                  2021-10-03T21:55:13.989Z app:null Reactor latest-21275-df3d784 starting on v14.16.0
                  2021-10-03T21:55:13.990Z app:INFO Process ID 8800; platform win32/x64 Windows 10 Education; locale (undefined)
                  2021-10-03T21:55:13.990Z app:INFO Basedir C:\reactor; data in C:\reactor\storage
                  2021-10-03T21:55:13.990Z app:INFO NODE_PATH (undefined)
                  C:\reactor\app.js:233
                  throw new Error(a0_0x52b285(0x1c5));
                  Error: Required environment variable NODE_PATH is not set
                  at Object.<anonymous> (C:\reactor\app.js:233:11)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
                  at internal/main/run_main_module.js:17:47||
                  Please help 🙂
                    Tells me you have a really old configuration that needs to be updated. At least copy the dist-config/logging.yaml file to the config directory to start over with that part of your config. The other parts of your config are likely OK.
                    Tells me that you haven't installed the prerequisite dependencies, which is part of the installation instructions. Did you follow the installation instructions for Windows?
                    If you think you set it, and it says you didn't, then most likely you didn't use the correct command for the shell you are in. The instructions are different for CMD.EXE vs Windows PowerShell. The installation instructions cover that, too.
                      Andr
                      Solved it! ✌
                      After updating config files i got a new error message that told me what dependencies that was missing. Some Popper thing...
                      So for now it is up and running again 🙂
                        Andr
                        Well, i did not download the node.js install package since I did that when i installed one of the first MSR-previews.
                        Otherwise i followd all steps.
                        (Except that i miss the config files because i was only updating in my mind and had no idea that CMD & PS makes a difference - You learn every day)
                          159.8k
