  4. iPhone location or alternative.
54 Posts 6 Posters 20.9k Views 6 Watching
    Tried
      entities:
            catman_iphone:
              topic: "FFCEB043-B975-490E-B051-198473F6A504"
              uses_template: owntracks_in_region
              regionName: Home
    and
      entities:
            "catman_iphone":
              regionName: Home
    With no discernible difference
    @catmanv2 Topics for me are not UUIDs, but rather the content of the Device ID field in the Identification section of the configuration. This is a value you set, not a value determined by OwnTracks. That's Android. I no longer have an Apple device I can use for this.
            owntracks_patrick_home_template:
              name: "Patrick Home Template"
              topic: phrs21
              regionName: Home
    • MikeReadingtonM Offline
      MikeReadington
      Thanks for all of the input.
      For whatever reason I am having the same spotty relationship with OwnTracks that @CatmanV2 has. One minute I think it's solved, the next minute it's missed a trigger.
      With the success others have had, including @gwp1 with the same method of deployment, I must have something wrong. I'll keep working on it as time permits.
      Thanks again
        Thanks again
        @mikereadington iPhone or Android?
          MikeReadington
          @catmanv2 iPhone. I just returned home and it got a location trigger, but it was far from an instant trigger. The phone was in sleep for at least 30 minutes before I crossed the perimeter, and I would say the delay was in the area of 45 seconds.
            45 seconds I can live with, personally but might not be right for your use case. (My fence is about 5km out)
            The thing I'm struggling with right now is testing it. I think I need to cross the fence. Logically I make the region much smaller for testing purposes but other issues at work today.
            G MikeReadingtonM 2 Replies Last reply
              @catmanv2 testing OwnTracks can be accomplished by changing from substantial to move in the app and then, well, moving.
                @gwp1 said in iPhone location or alternative.:
                Thanks, I can see the data arriving from Owntracks in Mosquitto (if you hit publish, for example) but what I can't do is get the MQQT entity to have anything but 'null' as its primary value. I can see MQQT is publishing to reactor as well, so confidence is reasonably high....
                My "logic" is that MSR is looking for the 'Enter' or 'Leave' payload which you only get when you transition into / out of a region.
                I was expecting to go somewhere today but the optician was ill and I've been tied up on calls and meetings all day so not had a chance to set a small region and wander up the road.
                Of course my logic could be utterly wrong, but wanted to test it before asking for more help.
                Because then I can save what little credibility I have and use it asking for help as to why the second phone (Mrs C's) doesn't have primary value. I found an error in the logs though which I'll dig at later
                Cheers
                  MikeReadington
                  @catmanv2 Yeah, my use case is a little more particular. I don't have an issue with never getting notification changes, they are just more delayed than I would like. I think once you get MQTT and MSR talking a 5km is going be more than relievable enough.
                  I had iPhone locator poll/force location refresh when I came in my driveway and triggered the magnetic sensor. I needed the location to be accurate and updated by the time I reached either my house or my building on property. The driveway is about 300m long as the crow flies for region radius purposes, and traversal to either location is much less than 45 seconds.
                  For what it is worth, I do see instant (and I mean instant instant) location changes like @therealdb and @gwp1 reported when the app is open or recently accessed. The delay seems to come from the app being backgrounded and the phone idle for a long period.
                  @gwp1 with HASS iCloud3, can you remote request a location refresh of the phone? Meaning, could I have polling suspended until I ask for an update? I think I could get exactly what I am looking for with a combination of the two and some MSR logic.
                  CatmanV2C therealdbT 2 Replies Last reply
                    @mikereadington said in iPhone location or alternative.:
                    Given my thermostat has a 5 minute update. 45 seconds is just dandy.
                    The lights and so on are never going to be an issue.
                      @mikereadington not an issue for me and my wife. Both set to significant, and I rarely open the app and I can say my wife is never opening it.
                      I’ll soon add beacons to my cars/motorcycle because home assistant has btle relay and I’ll go with esphome. It’s capable of moving btle messages to the central location and update corresponding device. Maybe it’s achievable for you too. My use case is to open/close my car gate automatically, but my driveway is short and I can place the gateway inside the house.
                        MikeReadington
                        @therealdb wow, that is what I was just looking at beacons. Looks promising if they are reliable.
                        I don't have gates, but I would not mind a few automated defensive turrets.
                          @mikereadington I tried beacons; was not successful.
                            #33
                            The issue with IPhoneLocator happened to me a few months ago. @amg0 was away on vacation, and did comment that Apple may have changed the API, and it wasn’t well documented. A few days later, it started working again.
                            The geofencing issues in Vera, along with Ezlo’s lack of geofencing, pushed me over the edge with Vera/Ezlo. I moved over to Home Assistant a few weeks ago, along with MSR, and overall it’s been much more stable. I’m also just using Home Assistant’s built in geofencing, and it’s working well.
                            I still have Vera running, as I’m not 100% migrated, but I’m close.
                              Not sure if @gwp1 was trying the new support in HASS, but I'm leaning a link anyway https://www.home-assistant.io/integrations/ibeacon
                                So I now have two phones that appear to be working just fine in terms of the Owntracks notifications. Clearly it's early days but I wonder if some of the issues that I have perceived are that although Owntracks is reporting to MQQT almost instantly, the screen notifications are not...
                                  @therealdb I was not - I will look into this.
                                    #37
                                    I may have spoken too soon. Mrs C's phone still claims to not be home. I suspect a config error on the phone however given it triggered correctly when she left the region
                                    <edit>
                                    I managed to pry her phone away and check the settings. Her region had vanished. I've seen this once on mine and assumed it was because we had the same RegionName (hence mine being Home2) but clearly not.
                                    Having re-created the region and published, the entity changed state as expected.
                                    The region was clearly there when she exited this morning (as the entity changed from 'null' to 'false') so this will need to be watched.
                                    Maybe it's just 'Home' it does not like as a region name <shrug>
                                      <edit>
                                      @catmanv2 Changes to user and a couple other settings will remove all regions.
                                        @gwp1 Thanks. That would be it!
                                          OK so this is mostly good. There is less functionality than iPhone locator (i.e. ETA isn't trrivial to get out) but still not 100% reliable. I was travelling from Friday to yesterday. I failed to get an update that I'd 'got home' yesterday PM. Mrs C was at home all that time, going to work and back, and reported perfectly so I have to assume it's a configuration / implementation on my phone.
                                            299
                                            150.8k
