  4. Home assistant Native Notification
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
    Hey Patrick,
    I’m trying to figure out how to run Home Assistant native push notifications from MSR. I have MSR set up to arm my home alarm every night, and when all users are out of the home. I’ve used it for years through Reactor, and it works fine, but when I ran Vera and Reactor for Vera, I would get notifications from Vera when Vera went into different home modes. (Home, Away, Night, etc). I’ve set up Home Modes in HA as well, so I’m looking to get the native push notifications from the HA companion app (i.e., System in Home Mode, System Armed Away, or Good Night, etc) Can I set up notifications from MSR to use those native push notifications, or does that need to be done from HA exclusively?
    I’m running latest-23028-ddc3fb14 and Home Assistant 2023.1.7.
    PablaP 1 Reply Last reply
    • T tamorgen
      Hey Patrick,
      @tamorgen you’re going to have to run a service using the Home Assistant controller entity. The service id will be notify.mobile_app_<name of the device> the name can be found under developer tools in HA. In the data section is where you’ll put what the message and title will be.
        @Pabla ,
        Thanks, that makes sense, but It doesn't appear to be working for me. I hit he play button on the entity action, and I didn't get a notification on my phone.
        When I do the same thing from HA, and hit Call Sevice, I immediately get a notification.
          On the Hass side, click the "Go to YAML mode" link, and you'll see the correct form for the data field in Reactor. It needs to be a JSON or YAML object.
            Thanks Patrick, that did the trick!
              163.7k
