  4. Run rule on dimmer change?
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
12 Posts 3 Posters 2.5k Views 3 Watching
  • I Offline
    I Offline
    ibrewster
    Reactor latest-23302-b7def56a; docker on Ubuntu 20.04; With Vera Plus and Ezlo Plus controllers
    I'm trying to tie the dimmer level of a dimmer switch to the dimmer level of a dimmable device (fan canopy light controller). In the triggers section of the rule I can select "dimming.level changes" as the condition, and I can get said dimming level in an expression that I then use to set the dimming.set attribute of the dimming device in the Set Reaction section, but this only works when going from 0--><some value>. When going from <some value> --> <some other value> or <some value>-->0, this does not work, because the rule is already set (it went true with the first change, and hasn't gone false yet - this is expected behavior as per the documentation)
    I can fix the <some value>-->0 issue by setting the Reset Reaction, but how can I get the rule to run - and set the entity dimming level - every time the switch value changes?
    (I tired to upload a screen shot of what I have, but I just kept getting errors)
      just to be clear, you have "changes from (any) to (any)" in your rule?
      • I Offline
        I Offline
        ibrewster
        That is correct, yes - and it works when going from 0-->any. After that, however, the condition evaluates to true, the rule is set, and so further changes do not trigger it again, as per the documentation (once true it remains true and the rule is not run again until it evaluates to false, i.e. 0)
        • I Offline
          I Offline
          ibrewster
          Ahhhh, I think I finally got it! If I add a second condition of device.dimming.level <> switch.dimming.level, then the rule is set whenever the switch changes, and quickly reset once the device is set to the same level, allowing the next change in switch level to properly trigger the rule again.
          Only took me two days and a forum post to figure that one out... 😆
            Please show your work (post screen shots of your rules).
            What you are describing doesn't make sense to me, and your fix seems unnecessary. I'd like to understand why, but I need to see your actual rules (please see the posting guidelines for this category as well).
            I 1 Reply Last reply
              I Offline
              I Offline
              ibrewster
              @toggledbits said in Run rule on dimmer change?:
              As I mentioned, I tried to do so, but the forum gives me errors. Specifically, it will show the image as uploading, get to 100%, pause, drop back to 60% (or so), give me a message stating "Looks like your connection to SmartHome Community was lost, please wait while we try to reconnect", the progress goes up to 100% again, and then I get an error stating "Something went wrong while parsing server response", and the image is not uploaded, leaving me with something like this:
              ![Screenshot 2023-12-01 at 8.55.28 AM.png]([[error:parse-error]])
              So as far as I can tell, no screen shot posting is possible.
              Perhaps walking through the steps of what happens will help?
              The rule is set up with a single Trigger:
              Entity Attribue -- Inovelli 2-in-1 (the switch) -- dimming.level -- changes -- from <blank> to <blank>
              A local expression is set up with the following code that gets the current dimming.level value:
              SwitchLevel = getEntity( "ezlo>device_65655fb712a3b714bdbcb935" ).attributes.dimming.level
              And a Set Reaction to set the LR Fan Light to the same level:
              Entity Action -- LR Fan Light -- dimming.set -- ${{SwitchLevel}}
              1. We start with the switch at 0 (off), and the rule is reset as expected
              2. We then set the switch to some other value (say, 50% or .5)
                2a. The rule is now set, and the Set Reaction runs as expected.
                2b. The rule remains set at this point - only going back to a dimming level of 0 will reset it.
              3. We then set the switch to another value, say 75% or .75
                3a. Since the rule is already in a set state, the Set Reaction does not run again, meaning the LR Fan light does not change dimming level
              Adding in the rule of the LR Fan Light level <> SwitchLevel allows the rule to drop back to a reset state after setting the LR Fan Light Level, thereby allowing it to run again the next time the switch level changes.
                If you only have a single trigger with changes -operator, the rule is immediately reset after the change (i.e. when change stops), so I don't quite get how your rule could stay set?
                  I Offline
                  I Offline
                  ibrewster
                  @tunnus said in Run rule on dimmer change?:
                  That is not the behavior I am seeing. Sorry! 🤷
                    ...and you don't have "delay reset" -condition option in use?
                    • I Offline
                      I Offline
                      ibrewster
                      wrote on last edited by ibrewster
                      Nope, the delay reset box is empty (nor have I tried to make any modifications in that section of the rule).
                      Although now that you mention it, it does seem odd, since while the rule remains set, if I toggle the rule open in the Rule Set list, the condition is evaluating to false, which (I would think) should reset the rule...right?
                      I have updated reactor recently, but let me try again in case 23302-b7def56a isn't the latest, and has a bug here...
                      EDIT: Nope, doesn't appear there are any updates available
                      • I Offline
                        I Offline
                        ibrewster
                        Ok, now I'm really confused. As part of my attempt to update reactor, the docker container obviously got restarted - and now the rule is working as expected, with only the change condition. I have no idea why the change in behavior, but at least it is now working as you guys expected.
                          Sounds to me like your UI was out of sync. A hard refresh should be done any time things don't look like expected.
                            165.6k
