  4. VirtualEntityController & time series
6 Posts 2 Posters 2.2k Views 2 Watching
    Is the following config correct?
              capabilities:
                temperature_sensor:
                  attributes:
                    value:
                      model: time series
                      entity: "hass>sensor_outdoor_temperature"
                      attribute: "temperature_sensor.value"
                      interval: 5  # minutes
                      retention: 20  # minutes
                      aggregate: wma
              primary_attribute: temperature_sensor.value
              type: ValueSensor
    Specifically, is "depth" directive needed/mandatory here? Reason I'm asking is that I'm not getting a "final" value in MSR, only debug values are shown:
    temperature_sensor.units=null
    temperature_sensor.value=null
    x_virtualentity.last_request_time=null
    x_virtualentity.request_failures=null
    x_virtualentity.template=null
    x_virtualentity.timeseries_debug=[{"time":1716537360000,"value":22.1},{"time":1716537660000,"value":22},{"time":1716537960000,"value":22},{"time":1716538260000,"value":21.9},{"time":1716538560000,"value":22}]
      Let me check it more directly. As I noted in release notes, I haven't tested every aggregate, and wma is one that I haven't yet. Also, wma needs weights, and you haven't specified those. It may just be a problem generating default weights, so try supplying them.
        @toggledbits I'll experiment this further, but I didn't add weights as manual says in relation to wma: "If no weight array is given, a default set that weights newer values higher than older values is used"
          Correct. I'm saying to try adding your own, because the default generation may have a bug. With your 5 minute samples and 20 minute span, you'll need 5 weights (for t, t-5, t-10, t-15, t-20). Any can be zero. Aside from all that, I'm looking at this now.
            @toggledbits did add the following to the config, but still "temperature_sensor.value" shows null
            depth: 4
            weight:
               - 0.50
               - 0.35
               - 0.10
               - 0.05
            (I know there are five samples, but "depth" should handle that?)
              Yup, I'd expect that, based on my testing. All aggregates are working except weighted average.
              Two issues, first, a doc error, it should be wa for the aggregate name, not wma.
              Second issue, computation is botched, so it will give a value, but it's incorrect. But the brain-fade on my part was simple, and you can easily work around it until I get the next build out: add expr: "value*X" where X is the depth you've requested (e.g. 4).
              Next build will fix it, but remember to remove the expression workaround when you install it.
              Correct!
                148.5k
