  4. latest-25016 toggle.toggle on VeraController Lock entity not working
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 2 Posters 1.5k Views 2 Watching
    After upgrade from 24366 to 25016 toggle on Vera (openLuup) lock entity doesn't seem to work.
    VeraController log level 5
    24366:
    [latest-24366]2025-01-20T20:26:49.724Z <VeraController:INFO> VeraController#vera perform action toggle.toggle on Lock#vera>device_10016 with [Object]{  }
    [latest-24366]2025-01-20T20:26:49.725Z <VeraController:5:VeraController.js:514> [VeraController:verarequest] requesting http://127.0.0.1:3480/data_request?id=action&serviceId=urn%3Amicasaverde-com%3AserviceId%3ADoorLock1&action=SetTarget&newTargetValue=0&DeviceNum=10016&output_format=json&_r=1737404809725 ([Object]{  })
    25016:
    [latest-25016]2025-01-20T20:30:25.457Z <VeraController:INFO> VeraController#vera perform action toggle.toggle on Lock#vera>device_10016 with [Object]{  }
    [latest-25016]2025-01-20T20:30:25.458Z <VeraController:5:VeraController.js:1210> VeraController#vera no configured implementation for toggle.toggle on Lock#vera>device_10016; calling super
    [latest-25016]2025-01-20T20:30:25.458Z <VeraController:INFO> VeraController#vera perform action lock.set on Lock#vera>device_10016 with [Object]{ "state": false }
    [latest-25016]2025-01-20T20:30:25.461Z <VeraController:5:VeraController.js:1255> VeraController#vera sending action request [Object]{ "newTargetValue": "0", "DeviceNum": 10016, "id": "action", "serviceId": "urn:upnp-org:serviceId:DoorLock1", "action": "SetTarget" }
    [latest-25016]2025-01-20T20:30:25.461Z <VeraController:5:VeraController.js:515> [VeraController:verarequest] requesting http://127.0.0.1:3480/data_request?newTargetValue=0&DeviceNum=10016&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ADoorLock1&action=SetTarget&output_format=json&_r=1737405025461 ([Object]{  })
    [latest-25016]2025-01-20T20:30:25.463Z <VeraController:NOTICE> VeraController#vera action lock.set([Object]{ "state": false }) on Lock#vera>device_10016 succeeded
    I tried to log an issue in Mantis Bug Tracker but I can't log in anymore?
    CrilleC 1 Reply Last reply
    • CrilleC Crille
      24366:
      25016:
      So the difference is the new serviceId urn:upnp-org:serviceId:DoorLock1 called by "super" vs the old urn:micasaverde-com:serviceId:DoorLock1.
      I tried to manually use them both in a browser to openLuup, even though both calls get OK in response, the only one actually opens the lock is the old serviceId urn:micasaverde-com:serviceId:DoorLock1
      Calling it in a browser directly to my Vera Secure (not openLuup) with serviceId urn:upnp-org:serviceId:DoorLock1 I get ERROR: Invalid Service
        @Crille yes, already found that. Unfortunately, I don't recall what platform/install method you use, you didn't put it in your post (guidelines, please), and I haven't had time to go dig it out of other posts, which is why I haven't responded until now. That will determine what I have to do to get you the fixed file.
          Sorry I missed that, it’s a bare metal install.
            OK. On the download server, under latest, you'll find vera_data.zip... download that and put it into your config directory, then restart.
              Thank you! toggle.toggle is back in business.
                164.3k
