  4. Dynamic Alert Based on Tripped Expression
3 Posts 2 Posters 868 Views 2 Watching
    Hello -
    Long time. Hope everyone is good.
    I have a rule that looks at a number of temperature sensors around the house. It simply sends a general alert if any of them fall below their threshold. (A basic “House is too cold” alert for when we’re away)
    Generally, this has worked well. But I was wondering if there’s a way to make the message somewhat dynamic without creating separate rules for each sensor.
    E.g. “House is too cold due to Sump Temperature below 45 degrees.”
    I thought I remember reading about someone doing this in the past but couldn’t find it.
    Thanks for any ideas!
    • T tbully
      Hello -
      @tbully that's easy, you have to use a variable in the notification and set that variable using case-statement, e.g.
      case
        when sump_temp < 45: "House is too cold due to Sump Temperature below 45 degrees"
        when x_temp < 45: "similar message"
        when y_temp < 45: "similar message"
        else "some default message if needed"
        This is fantastic (and I’m sure is covered in the manual - oops). Thank you, @tunnus
          161.7k
          1.3k
