  3. Plugins
  4. Virtual Devices Plug-in update (with async HTTP support)
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
11 Posts 2 Posters 2.7k Views 2 Watching
    • support for async HTTP (out of the box on openluup, just download https://github.com/akbooer/openLuup/blob/master/openLuup/http_async.lua and copy with the plug-in files on Vera)
    • experimental support for setpoints management in Virtual Heaters (you know, the device will turn itself off if temperature is reached, and automatically on when temperature is not beyond the setpoint)
    • external device for temperature in Virtual Heaters (just set urn:bochicchio-com:serviceId:VirtualHeater1/TemperatureDevice variable)
    • small fixes, stabilization
      I just released a new version with
      • DoorLock (also, to combine two existing sensor+relay)
      • AlarmPanels (if you have an HTTP alarm panel - both with simpliefied (_2) and complete UI (_1) - ALTUI friendly)
      • curl support (to send headers, cookies, POST/PUT/whatever)
      • new power consumption for lights (to have KWH and total consumption reported under the devices - already configured for shellies)
        I've just released a new update, fixing power consumption for Shelly devices reporting KWMin instead of KWH.
        I've just fixed a couple of other things and since I've received no complaints, I'll probably release 3.0 in the coming weeks.
        Release 3.0 beta 5 · dbochicchio/vera-VirtualDevices
        New beta release: fixed KWH for Shelly Plug and similar devices moved meters update for relays to improve startup performance minor tweaks in preparation for 3.0
          rngarcia
          Hello @therealdb , good evening!
          I recently had to restore my VeraPlus and after that the Virtual Devices plugin stopped to work. I was using the version 2.3 (from the App Store) and when my Vera came back, the devices won't respond to on/off commands... I was wondering if you could help me solve the issue. I'm thinking there is something that got corrupted in Vera that I would need to delete (I've already tried deleting the files), but not sure what..
          Thank you!
          • R rngarcia
            Thank you!
            @rngarcia just download the files from GitHub and overwrite them. Latest version is better and you’ll overwrite all the files anyway.
              rngarcia
              @therealdb , thanks for helping me with this! I've installed version 3, but still not working. I'm trying to trigger an ifttt webhook (that somehow worked before) for power on or off (2 different hooks). I've enable the log and this is what I have:
              08 01/05/22 11:29:46.177 JobHandler_LuaUPnP::HandleActionRequest device: 196 service: urn:upnp-org:serviceId:Dimming1 action: SetLoadLevelTarget <0x72868520>
              08 01/05/22 11:29:46.177 JobHandler_LuaUPnP::HandleActionRequest argument action=SetLoadLevelTarget <0x72868520>
              08 01/05/22 11:29:46.177 JobHandler_LuaUPnP::HandleActionRequest argument newLoadlevelTarget=0 <0x72868520>
              08 01/05/22 11:29:46.177 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:Dimming1 <0x72868520>
              08 01/05/22 11:29:46.178 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=196 <0x72868520>
              50 01/05/22 11:29:46.179 luup_log:196: VirtualDevices3.0-beta5@196:actionBrightness(196,"0") <0x72868520>
              50 01/05/22 11:29:46.180 luup_log:196: VirtualDevices3.0-beta5@196:New Position: 0 - original 0 <0x72868520>
              50 01/05/22 11:29:46.180 luup_log:196: VirtualDevices3.0-beta5@196:setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","0",196) old value "0" <0x72868520>
              50 01/05/22 11:29:46.181 luup_log:196: VirtualDevices3.0-beta5@196:setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","0",196) old value "0" <0x72868520>
              50 01/05/22 11:29:46.182 luup_log:196: VirtualDevices3.0-beta5@196:actionPowerInternal(196,false,false) <0x72868520>
              50 01/05/22 11:29:46.182 luup_log:196: VirtualDevices3.0-beta5@196:setVar("urn:upnp-org:serviceId:SwitchPower1","Target","0",196) old value "0" <0x72868520>
              50 01/05/22 11:29:46.183 luup_log:196: VirtualDevices3.0-beta5@196:setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","0",196) old value "0" <0x72868520>
              50 01/05/22 11:29:46.184 luup_log:196: VirtualDevices3.0-beta5@196:sendDeviceCommand("SetPowerOffURL","off",196) <0x72868520>
              50 01/05/22 11:29:46.186 luup_log:196: VirtualDevices3.0-beta5@196:sendDeviceCommand.url("https://maker.ifttt.com/trigger/fecha_cortina_1/with/key/XXXXXXXXXXXX") <0x72868520>
              02 01/05/22 11:29:46.186 luup_require duplicate http_async <0x72868520>
              50 01/05/22 11:29:46.187 luup_log:196: VirtualDevices3.0-beta5@196:httpGet("sync") <0x72868520>
              50 01/05/22 11:29:46.237 luup_log:196: VirtualDevices3.0-beta5@196:httpGet("https://maker.ifttt.com/trigger/fecha_cortina_1/with/key/XXXXXXXXXXX", "", "-1", "") <0x72868520>
              At some point I've noticed it is asking for the http_async, so I've installed it on Vera... but still get the same error as above.
              Can you give me some more advice on this?
              Thank you very much!
                rngarcia
                Also found this on the log: luup_require [string "..."]:7: unexpected symbol near '<'
                  http_async is optional, it will work regardless. from logs it seems OK. Could you please post more logs? Enable debug mode and post again. I have it working in prod in my system and it's OK, so maybe it's something related to the call. Try also with curl, since it will bypass certains https errors.
                    rngarcia
                    With curl now I'm getting a error in the address name... probably I'm using the wrong syntax - do you mind sharing the proper way to send the curl command? Thanks!
                      according to the docs, you should use:
                      curl://-k 'https://maker.ifttt.com/trigger/fecha_cortina_1/with/key/XXXXXXXXXXX'
                      R 1 Reply Last reply
                        rngarcia
                        @therealdb Now, it worked perfectly! Thank you!
                        • Variables not updating properly
                        • [Solved] Loading Screen Safari
                        • VEC Virtual Switch Auto Off
                        • Changes operator does not always detect change
                        • Dynamic MQTT topics and parameters
                        • Condition for trend
                        • Struggling to setup my first Tasmota device and MQTT
                        • Raspberry Pi 4 dual RAM variant introduced to mitigate RAM price increases
                        • Existing Rule stopped working HTTP command fetching IP address from website
                        • Set reaction triggering wrong z-wave device
                        • Can you run MSR on Home Assistant OS ?
                        • RPi Alternative: Orange Pi 4 LTS (3GB RAM/16GB eMMC)
                          2.1k
