  3. Vera
  4. Vera Christmas Lights and migration away from Vera
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
3 Posts 3 Posters 895 Views 3 Watching
  • C Offline
    C Offline
    cubs2b23
    My VeraPlus is in Christmas Light mode after attempting the latest update. So as I attempt to get things back with Vera Support I need to start looking into an alternate solution. I've installed OpenLuup in an Ubuntu VM I have running on an old PC. Right now I can still ssh into the VeraPlus.
    1. Will I be able to migrate the Z-Wave NW to a UZB dongle in this state?
    2. Or can I use @rafale77 's Nuke Vera Script to just use the VeraPlus as my zwave antenna?
    3. With either of these options have I lost the ability to migrate my configuration without Vera support restoring my VeraPlus first?
      huh... sorry to hear this.
      As long as you have ssh access, you should be able to migrate to the uzb dongle. It strange though that you have the device blinking and still have ssh access. You also can use the nuke vera script and still use the zwave radio in the vera. Your entire network can then show up in openzwave/home assistant for example but not with z-way which require a license only present on the uzb and razberrries.
      What you probably lost though is your automation which should be transferred to openluup.
        richie.digital
        Just factory reset and run the extroot script again
          160.0k
