  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
107 Posts 10 Posters 65.6k Views 7 Watching
    @therealdb
    Thanks for that! I think the challenge in this case is that we are somewhat constrained by what the mqttthing is able to handle. It has some configurability, but I’m not sure whether we can use this approach. We will see.
    @akbooer Perhaps an update of all or specified variables could be initiated by a topic in the startPub setting?
    • C Offline
      C Offline
      christian_fabre
      #42
      I have a Shelly plug and a Tasmota sensor.
      I installed the latest OpenLuup version (21.4.28c)
      I have the Shelly and Tasmota bridges that appear automatically, but I don't have the child devices.
      Error message in the logs:
      2021-04-29 15: 02: 20.795 openLuup.context_switch :: ERROR: [dev # 75] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 20.795 openLuup.mqtt :: ERROR publishing application message for mqtt: tele / piscine / SENSOR: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.216 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.217 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / power: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.219 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.219 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / energy: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.221 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.221 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0: ./openLuup/api.lua:148: attempt to index field '? ' (a nil value)
      2021-04-29 15: 02: 21.223 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.223 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.225 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.225 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature_f: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.227 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
      2021-04-29 15: 02: 21.227 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / overtemperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
        #43
        • What MQTT settings do you have in you Lua Startup?
        • What are devices #75 and #76?
        • Can you share more of the log than just the error – context is important
        • C Offline
          C Offline
          christian_fabre
          #44
          MQTT setting :
          luup.attr_set ("openLuup.MQTT.Port", 1885)
          luup.attr_set ("openLuup.MQTT.Username", "*******")
          luup.attr_set ("openLuup.MQTT.Password", "*******")
          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", "0")
          luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) -- publish every variable update
          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", 2)       -- publish a single device status every N seconds (0 = never)
          Devices 75 et 76
          21	2021-04-29 14:56:51.444	75		Done	0.000	21	plugin: Tasmota	OK
          22	2021-04-29 14:56:51.444	76		Done	0.000	22	plugin: Shelly	OK
          Context after StartLuup
          2021-04-29 16:53:44.403   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x184a658
          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x184a658
          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x184a658
          2021-04-29 16:53:44.404   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.404   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.405   luup.shelly:76: New Shelly announced: shellyplug-s-20E453
          2021-04-29 16:53:44.405   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.406   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.407   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
          2021-04-29 16:53:44.661   openLuup.server:: request completed (515424 bytes, 33 chunks, 272 ms) tcp{client}: 0x22f6cf8
            Thanks – that shows exactly what I needed to see. The first incoming message from the Shelly is not an announcement, so the device doesn't yet exist. I knew this happened, but thought I had handled the condition. A recent change has made it appear again. I'll work on it...
            • C Offline
              C Offline
              christian_fabre
              Okay
              Thank you for your work that I am with interest
              • C christian_fabre
                Okay
                @christian_fabre
                Can you tell me what Shelly devices you are using here? Thanks.
                  @christian_fabre
                  Could you try the latest development version (21.4.29b) and see if that fixes the issue? Thanks.
                  • C Offline
                    C Offline
                    christian_fabre
                    #49
                    Shelly Plug
                    I installed the last version but still the same problem
                    2021-04-29 20:31:35.495   openLuup.io.server:: MQTT:1885 connection from 192.168.1.149 tcp{client}: 0x1808020
                    2021-04-29 20:31:35.500   openLuup.server:: request completed (1304 bytes, 1 chunks, 6470 ms) tcp{client}: 0x1a2dc08
                    2021-04-29 20:31:35.515   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x1808020
                    2021-04-29 20:31:35.516   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x1808020
                    2021-04-29 20:31:35.517   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x1808020
                    2021-04-29 20:31:35.518   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.518   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.519   luup.shelly:76: New Shelly announced: shellyplug-s-20E453
                    2021-04-29 20:31:35.520   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                    2021-04-29 20:31:35.520   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                    2021-04-29 20:31:35.521   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.521   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.522   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.522   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.523   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.524   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.525   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.525   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.526   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.526   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.527   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.527   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.528   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                    2021-04-29 20:31:35.528   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                      Sorry to hear.
                      Can you send me that startup log? Something is not right here.
                      • C Offline
                        C Offline
                        christian_fabre
                        #51
                        logs/LuaUPnP_startup.log
                        178 lines, 1 error, max gap 0s @ 2021-04-30 08:45:58.936
                        2021-04-30 08:45:57.409   :: openLuup STARTUP :: /etc/cmh-ludl
                        2021-04-30 08:45:57.409   openLuup.init::        version 2021.04.08  @akbooer
                        2021-04-30 08:45:57.437   openLuup.scheduler::   version 2021.03.19  @akbooer
                        2021-04-30 08:45:57.462   openLuup.io::          version 2021.03.27  @akbooer
                        2021-04-30 08:45:57.462   openLuup.mqtt::        version 2021.04.28b  @akbooer
                        2021-04-30 08:45:57.464   openLuup.wsapi::       version 2019.08.12  @akbooer
                        2021-04-30 08:45:57.464   openLuup.servlet::     version 2021.04.28c  @akbooer
                        2021-04-30 08:45:57.464   openLuup.client::      version 2019.10.14  @akbooer
                        2021-04-30 08:45:57.465   openLuup.server::      version 2020.03.26  @akbooer
                        2021-04-30 08:45:57.473   openLuup.scenes::      version 2021.04.28  @akbooer
                        2021-04-30 08:45:57.477   openLuup.chdev::       version 2020.21.27  @akbooer
                        2021-04-30 08:45:57.477   openLuup.userdata::    version 2021.03.14  @akbooer
                        2021-04-30 08:45:57.477   openLuup.requests::    version 2021.02.20  @akbooer
                        2021-04-30 08:45:57.478   openLuup.gateway::     version 2020.03.08  @akbooer
                        2021-04-30 08:45:57.481   openLuup.smtp::        version 2018.04.12  @akbooer
                        2021-04-30 08:45:57.485   openLuup.historian::   version 2021.02.03  @akbooer
                        2021-04-30 08:45:57.486   openLuup.luup::        version 2021.04.27  @akbooer
                        2021-04-30 08:45:57.487   openLuup.pop3::        version 2018.04.23  @akbooer
                        2021-04-30 08:45:57.488   openLuup.compression:: version 2016.06.30  @akbooer
                        2021-04-30 08:45:57.488   openLuup.timers::      version 2019.05.03  @akbooer
                        2021-04-30 08:45:57.488   openLuup.logs::        version 2018.03.25  @akbooer
                        2021-04-30 08:45:57.488   openLuup.json::        version 2020.05.20  @akbooer
                        2021-04-30 08:45:57.488   openLuup.init:: using openLuup.json.Lua.decode() for JSON decoding (Cjson not installed)
                        2021-04-30 08:45:57.545   luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                        2021-04-30 08:45:57.561   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
                        2021-04-30 08:45:57.561   openLuup.init:: loading configuration user_data.json
                        2021-04-30 08:45:57.571   openLuup.userdata:: loading user_data json...
                        2021-04-30 08:45:57.846   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                        2021-04-30 08:45:57.846   openLuup.userdata:: loading rooms...
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#1 'MiOS-45003471'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#2 'VeraEdge_Exterieur'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#3 'VeraEdge_Essai'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#4 'VeraEdge_Température'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#5 'VeraEdge_Piscine'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#6 'VeraEdge_System'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#7 'VeraEdge_Securité'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#8 'ZWay-31415926'
                        2021-04-30 08:45:57.846   openLuup.userdata:: room#9 'OpenLuup'
                        2021-04-30 08:45:57.847   openLuup.userdata:: ...room loading completed
                        2021-04-30 08:45:57.847   openLuup.userdata:: loading devices...
                        2021-04-30 08:45:57.850   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                        2021-04-30 08:45:57.859   luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
                        2021-04-30 08:45:57.868   luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json   (VeraBridge)
                        2021-04-30 08:45:57.903   luup.create_device:: [15] D_Switchboard1.xml / I_Switchboard1.xml / D_Switchboard1_UI7.json   (urn:schemas-toggledbits-com:device:Switchboard:1)
                        2021-04-30 08:45:57.957   luup.create_device:: [18] D_Reactor.xml / I_Reactor.xml / D_Reactor_UI7.json   (urn:schemas-toggledbits-com:device:Reactor:1)
                        2021-04-30 08:45:57.994   luup.create_device:: [19] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:57.999   luup.create_device:: [20] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.004   luup.create_device:: [25] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.starts' (a function value)
                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.altui_split' (a function value)
                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.template' (a function value)
                        2021-04-30 08:45:58.111   openLuup.scheduler.sandbox:: device 26 defined 'string.trim' (a function value)
                        2021-04-30 08:45:58.111   luup.create_device:: [26] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                        2021-04-30 08:45:58.158   luup.create_device:: [27] D_VirtualSensor1.xml / I_VirtualSensor1.xml / D_VirtualSensor1.json   (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                        2021-04-30 08:45:58.165   luup.create_device:: [28] D_GenericSensor1.xml /  / D_GenericSensor1.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                        2021-04-30 08:45:58.210   luup.create_device:: [29] D_MString.xml / I_MString.xml / D_MString.json   (urn:schemas-upnp-org:device:VContainer:1)
                        2021-04-30 08:45:58.214   luup.create_device:: [32] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.219   luup.create_device:: [33] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.281   luup.create_device:: [35] D_ZWay.xml / I_ZWay2.xml / D_ZWay.json   (ZWay)
                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.fliprsplit' (a function value)
                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.template' (a function value)
                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.trim' (a function value)
                        2021-04-30 08:45:58.301   luup.create_device:: [36] D_FLIPR.xml / I_FLIPR.xml / D_FLIPR_UI7.json   (urn:schemas-upnp-org:device:flipr:1)
                        2021-04-30 08:45:58.319   luup.create_device:: [40] D_MString.xml / I_MString.xml / D_GenericSensor1_Ph.json   (urn:schemas-upnp-org:device:VContainer:1)
                        2021-04-30 08:45:58.338   luup.create_device:: [41] D_MString.xml / I_MString.xml / D_GenericSensor1_mVolts.json   (urn:schemas-upnp-org:device:VContainer:1)
                        2021-04-30 08:45:58.356   luup.create_device:: [42] D_MString.xml / I_MString.xml / D_GenericSensor1_Tpiscine.json   (urn:schemas-upnp-org:device:VContainer:1)
                        2021-04-30 08:45:58.385   luup.create_device:: [46] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.407   luup.create_device:: [49] D_BinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.411   luup.create_device:: [50] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.425   luup.create_device:: [51] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.437   luup.create_device:: [54] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.450   luup.create_device:: [55] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.463   luup.create_device:: [56] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.480   luup.create_device:: [57] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.489   luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tele/#
                        2021-04-30 08:45:58.489   luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tasmota/tele/#
                        2021-04-30 08:45:58.490   luup.create_device:: [75] D_TasmotaBridge.xml / I_TasmotaBridge.xml / D_TasmotaBridge.json   (TasmotaBridge)
                        2021-04-30 08:45:58.494   luup.register_handler:: global_function_name=Shelly_MQTT_Handler, request=mqtt:shellies/#
                        2021-04-30 08:45:58.494   luup.create_device:: [76] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json   (ShellyBridge)
                        2021-04-30 08:45:58.501   luup.create_device:: [10002] D_SceneController1.xml / X / D_SceneController1.json   (urn:schemas-micasaverde-com:device:SceneController:1)
                        2021-04-30 08:45:58.505   luup.create_device:: [10003] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.509   luup.create_device:: [10006] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.513   luup.create_device:: [10012] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.522   luup.create_device:: [10016] D_InfoViewer1.xml / X / D_InfoViewer1.json   (urn:schemas-a-lurker-com:device:InfoViewer:1)
                        2021-04-30 08:45:58.544   luup.create_device:: [10034] D_DeusExMachinaII1.xml / X / D_DeusExMachinaII1_UI7.json   (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                        2021-04-30 08:45:58.606   luup.create_device:: [10040] D_MiLightRGBWBOX2.xml / X / D_MiLightRGBW.json   (urn:schemas-dcineco-com:device:DimmableLightRGBW:1)
                        2021-04-30 08:45:58.610   luup.create_device:: [10046] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.614   luup.create_device:: [10047] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.617   luup.create_device:: [10048] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.625   luup.create_device:: [10059] D_LuaView1.xml / X / D_LuaView1.json   (urn:schemas-toggledbits-com:device:LuaView:1)
                        2021-04-30 08:45:58.643   luup.create_device:: [10060] D_ZiBlueGateway1.xml / X / D_ZiBlueGateway1.json   (urn:schemas-upnp-org:device:ZiBlueGateway:1)
                        2021-04-30 08:45:58.644   luup.create_device:: [10061] D_SerialPortRoot1.xml / X /    (urn:micasaverde-org:device:SerialPortRoot:1)
                        2021-04-30 08:45:58.654   luup.create_device:: [10062] D_SerialPort1.xml / X /    (urn:micasaverde-org:device:SerialPort:1)
                        2021-04-30 08:45:58.659   luup.create_device:: [10069] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.664   luup.create_device:: [10070] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.667   luup.create_device:: [10071] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.669   luup.create_device:: [10072] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.672   luup.create_device:: [10075] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.675   luup.create_device:: [10076] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.683   luup.create_device:: [10082] D_DelayLight.xml / X / D_DelayLight_UI7.json   (urn:schemas-toggledbits-com:device:DelayLight:1)
                        2021-04-30 08:45:58.695   luup.create_device:: [10089] D_WindSensor1.xml / X / D_WindSensor1.json   (urn:schemas-micasaverde-com:device:WindSensor:1)
                        2021-04-30 08:45:58.698   luup.create_device:: [10095] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.718   luup.create_device:: [10097] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
                        2021-04-30 08:45:58.723   luup.create_device:: [10099] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
                        2021-04-30 08:45:58.726   luup.create_device:: [10102] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.730   luup.create_device:: [10103] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.733   luup.create_device:: [10104] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.735   luup.create_device:: [10105] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.738   luup.create_device:: [10106] D_Reactor.xml / X / D_Reactor_UI7.json   (urn:schemas-toggledbits-com:device:Reactor:1)
                        2021-04-30 08:45:58.743   luup.create_device:: [10107] D_Switchboard1.xml / X / D_Switchboard1_UI7.json   (urn:schemas-toggledbits-com:device:Switchboard:1)
                        2021-04-30 08:45:58.747   luup.create_device:: [10110] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.751   luup.create_device:: [10114] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.753   luup.create_device:: [10115] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.759   luup.create_device:: [10118] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
                        2021-04-30 08:45:58.761   luup.create_device:: [10124] D_SmartHomeHelper.xml / X /    (urn:schemas-upnp-org:device:GoogleHome:1)
                        2021-04-30 08:45:58.767   luup.create_device:: [10131] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                        2021-04-30 08:45:58.774   luup.create_device:: [10132] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
                        2021-04-30 08:45:58.778   luup.create_device:: [10133] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.784   luup.create_device:: [10138] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
                        2021-04-30 08:45:58.788   luup.create_device:: [10139] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                        2021-04-30 08:45:58.792   luup.create_device:: [10143] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.796   luup.create_device:: [10145] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.799   luup.create_device:: [10146] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.802   luup.create_device:: [10147] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.808   luup.create_device:: [10165] D_SmokeSensor1.xml / X / D_COSensor1NoTamper.json   (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                        2021-04-30 08:45:58.815   luup.create_device:: [10166] D_FloodSensor1.xml / X / D_FloodSensor1.json   (urn:schemas-micasaverde-com:device:FloodSensor:1)
                        2021-04-30 08:45:58.820   luup.create_device:: [10172] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.825   luup.create_device:: [10173] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.831   luup.create_device:: [10177] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.836   luup.create_device:: [10178] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                        2021-04-30 08:45:58.841   luup.create_device:: [10181] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.848   luup.create_device:: [10182] D_VirtualSensor1.xml / X / D_VirtualSensor1.json   (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                        2021-04-30 08:45:58.852   luup.create_device:: [10183] D_TemperatureSensor1.xml / X / D_GenericSensor1_Tpiscine.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.857   luup.create_device:: [10184] D_GenericSensor1.xml / X / D_GenericSensor1_mVolts.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                        2021-04-30 08:45:58.861   luup.create_device:: [10185] D_GenericSensor1.xml / X / D_GenericSensor1_Ph.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                        2021-04-30 08:45:58.865   luup.create_device:: [10186] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.871   luup.create_device:: [10187] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.875   luup.create_device:: [10189] D_MString.xml / X / D_MString.json   (urn:schemas-upnp-org:device:VContainer:1)
                        2021-04-30 08:45:58.880   luup.create_device:: [10190] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.882   luup.create_device:: [10192] D_VeraAlert.xml /  /    ()
                        2021-04-30 08:45:58.882   openLuup.chdev:: ERROR: unable to read XML file D_VeraAlert.xml
                        2021-04-30 08:45:58.886   luup.create_device:: [10193] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                        2021-04-30 08:45:58.894   luup.create_device:: [10195] D_FloodSensor1.xml / X / D_FloodSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:FloodSensor:1)
                        2021-04-30 08:45:58.898   luup.create_device:: [10196] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.902   luup.create_device:: [10197] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.906   luup.create_device:: [10198] D_VeraAlexa1.xml / X / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                        2021-04-30 08:45:58.909   luup.create_device:: [10199] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.913   luup.create_device:: [10200] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.916   luup.create_device:: [10201] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.919   luup.create_device:: [10202] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.922   luup.create_device:: [10203] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                        2021-04-30 08:45:58.925   luup.create_device:: [10204] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                        2021-04-30 08:45:58.928   luup.create_device:: [30040] D_BinaryLight1.xml /  / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                        2021-04-30 08:45:58.932   luup.create_device:: [30070] D_DoorSensor1.xml /  / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
                        2021-04-30 08:45:58.933   openLuup.userdata:: loading scenes...
                        2021-04-30 08:45:58.933   openLuup.userdata:: [10014] Alarme Température Congel/frigo
                        2021-04-30 08:45:58.933   openLuup.userdata:: [10010] Gestion_SmartLed
                        2021-04-30 08:45:58.933   openLuup.userdata:: [10009] essai_clavier
                        2021-04-30 08:45:58.934   openLuup.userdata:: [10001] Eclairage_Allee(Manu)
                        2021-04-30 08:45:58.934   openLuup.userdata:: number of scenes = 4
                        2021-04-30 08:45:58.934   openLuup.userdata:: ...scene loading completed
                        2021-04-30 08:45:58.934   openLuup.userdata:: loading installed plugin info...
                        2021-04-30 08:45:58.934   openLuup.userdata:: [openLuup] openLuup (21.4.29b)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [VeraBridge] VeraBridge (21.1.3)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [8246] ALTUI (2.53b.)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [Z-Way] Z-Way (21.1.19)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [Arduino] MySensors (not.installed)
                        2021-04-30 08:45:58.934   openLuup.userdata:: [9194] Switchboard (GitHub.GitHub.stable)
                        2021-04-30 08:45:58.935   openLuup.userdata:: [9086] Reactor (GitHub.stable)
                        2021-04-30 08:45:58.935   openLuup.userdata:: [9031] Virtual Sensor (1.11)
                        2021-04-30 08:45:58.935   openLuup.userdata:: [9281] Virtual HTTP Devices (GitHub.master)
                        2021-04-30 08:45:58.935   openLuup.userdata:: [AlexaTTS] VeraAlexa (GitHub.master)
                        2021-04-30 08:45:58.935   openLuup.userdata:: ...user_data loading completed
                        2021-04-30 08:45:58.935   openLuup.init:: running _openLuup_STARTUP_
                        2021-04-30 08:45:58.936   luup_log:0: startup code completed
                        2021-04-30 08:45:58.936   openLuup.init:: init phase completed
                        2021-04-30 08:45:58.936   :: openLuup LOG ROTATION :: (runtime 0.0 days)
                        • CrilleC Crille
                          @akbooer Wow, that was fast! Thanks, works like a charm.
                          May I bother you with my next issue? Every time I restart Homebridge my sensor values and current state of bridged devices are lost to mqttthing and shows 0 or OFF until there is an update from the device. Is there a way to retain the values from openLuup/update?
                          @crille said in MQTT – setup and use:
                          In the latest testing branch release (v21.4.30) the MQTT server now subscribes to the topic openLuup/query. If you publish a message with the format: devNo.serviceId.variable, for example,
                          • topic: openLuup/query
                          • message: 2.openLuup.Memory_Mb
                          it will force an immediate update message:
                          • topic: openLuup/update/2/openLuup/Memory_Mb
                          • message: 8.7 (or whatever)
                          You should be able to use this to get an initial value for any mqttthing.
                          Notice the formatting difference between the message and the returned topic ('.' instead of '/') this is intentional because it is in line with openLuup's existing dev.srv.var notation and it reminds you that it's not a part of the query topic, but it goes in the message, and avoids the need for openLuup to use a wildcard subscription.
                          CrilleC 1 Reply Last reply
                          • C christian_fabre
                            ArcherS
                            @christian_fabre I added my Shelly 1PM today to OpenLuup v21.4.29b.
                            At first it did not work, and I could not figure out why. Then I found a post on the Shelly forum that said that there in some cases (or for some devices) could be a problem with the latest Shelly firmware and Mqtt.
                            I had the latest v1.10.3 in my 1PM. After I downgraded the Shelly to v1.9.4 it worked.
                            Check what firmware you have in your plug and if you have the latest you can try to downgrade and see if it works.
                            Go to https://www.shelly-support.eu/index.php?shelly-firmware-archive/ and enter your IP address, select the right plug variant (there are a few to choose from) and firmware release. Then you copy the url that is generated into a browser.
                            If you have blocked the Shelly in your router from Internet access you probably have to open it temporary for the downgrade.
                            I also added my Shelly Button to OpenLuup and for some reason I could not downgrade it, but I managed to get it working anyway after a few attempts.
                            (A bit strange since the post I found on the forum was on problems with the Button and v1.10.3.)
                            Another tip is to use MqttExplorer if you do not already use it and see if the Shelly shows up there. If it does, then at least the Mqtt part of the Shelly most likely works.
                            akbooerA 2 Replies Last reply
                            • A ArcherS
                              #54
                              @archers
                              Excellent diagnosis. Let's hope that's the root cause.
                              Entirely exaplins why I couldn't reproduce this ... my Shelly 2.5s are on 1.9.4, but telling me there's a 1.10.3, so I'll be sure NOT to do that!
                              I don't follow the Shelly forum much, so please pass on when it's safe again to upgrade.
                              @rafale77 Shellies are manual update... a good choice, as I'm sure you'll agree!
                              rafale77R A 2 Replies Last reply
                                @archers
                                #55
                                @akbooer said in MQTT – setup and use:
                                Ha! Indeed, There is an ongoing train wreck on the QNAP forum with people humorously (to me at least, maybe not to them) finding out the firmware autoupdate being enabled on the new firmware which itself has a lot of connectivity problems forcing many to downgrade... sounds familiar? No one is immune to a problematic upgrade or a use case where something breaks. And this came as a knee jerk reaction to a security breach for which the firmware upgrade itself does nothing because the exposure comes from an app.
                                  @archers
                                  ArcherS
                                  @akbooer I routinely updated the two new Shellies and then I got v1.10.3, bad decision as it turnes out. 🙂
                                  My two older Shellies are on v1.9.0 and worked directly when I enabled Mqtt.
                                  Manual update is better, automatic is a pain, Win 10 is a good example on that. I assume I will get it on my Qnap when I update it. 😞
                                  I have also blocked the Shellies and Tasmotas in the the router
                                    @akbooer Awesome!
                                    This keeps HomeKit in sync after a restart. Thank you for the quick update, top notch as always!
                                    • A ArcherS
                                      @archers said in MQTT – setup and use:
                                      I usually wait a couple of days, then update them in batch via MQTT. all good at the moment. I've blocked them from the reaching the Internet as well.
                                        @therealdb said in MQTT – setup and use:
                                        That’s a great idea! I’ve been doing them individually over HTTP up to now.
                                        • C Offline
                                          C Offline
                                          christian_fabre
                                          #60
                                          Thank you very much to all.
                                          in fact I had updated the Shelly plug (v1.10.3)
                                          I installed v1.9.4 following the instructions of ArcherS.
                                          but unfortunately I still have the same problem.
                                          I have the creation of the Shelly Bridge, but no child.
                                          here are the logs
                                          2021-05-01 08:52:42.237   openLuup.io.server:: MQTT:1885 connection from 192.168.1.149 tcp{client}: 0x2ec6018
                                          2021-05-01 08:52:42.267   luup.create_device:: [80] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json   (ShellyBridge)
                                          2021-05-01 08:52:42.268   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.268   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.269   openLuup.scheduler:: [80] Shelly device startup
                                          2021-05-01 08:52:42.269   luup.set_failure:: status = 0
                                          2021-05-01 08:52:42.270   luup.variable_set:: 80.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: EMPTY now: 0 #hooks:0
                                          2021-05-01 08:52:42.270   luup.variable_set:: 80.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0
                                          2021-05-01 08:52:42.270   openLuup.scheduler:: [80] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge
                                          2021-05-01 08:52:42.271   luup.shelly:0: New Shelly announced: shellyplug-s-20E453
                                          2021-05-01 08:52:42.271   openLuup.luup:: creating room [10] Shellies
                                          2021-05-01 08:52:42.272   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                          2021-05-01 08:52:42.272   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                          2021-05-01 08:52:42.273   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.273   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.275   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.275   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.276   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.276   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.305   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.306   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.307   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.307   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.308   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.309   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.310   openLuup.context_switch::  ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.310   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-01 08:52:42.311   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x2ec6018
                                          2021-05-01 08:52:42.313   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x2ec6018
                                          2021-05-01 08:52:42.314   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x2ec6018
                                          I have the same problem with the Tasmota bridge
                                            137.8k
