  4. Is this correct? Text shown in the blue banners on the rule summaries
11 Posts 2 Posters 3.0k Views 2 Watching
    Hi
    I've just created four new rules as you can see in the screen shot above.
    In the dark blue banners, the first two rules show text of:
    Group: rule-klgiivpk-trig;
    and
    Group: rule-klghttuk-trig;
    and the bottom two rules have text of:
    Group: trig;
    I've named each of my rules as you can see in the screen shot.
    I was just wondering about the text in these dark blue banners.
    There doesn't appear to be a way to edit that text at all.
    All the rules are working fine as expected though.
      Seems to be related to copying an existing rule from one group to another or even within the same group.
      Also when I copied this rule from one group to another the "Set Reaction" action was fired and ran as it turned on my "Globe lamp".
        That's a bug; that view is still a work in progress. As I mentioned in the other thread, the constraints are missing from this display, as are any expressions local to each rule. Much work yet to be done, but this kind of thing usually mops up quickly. I wanted to get at least this much out so one could see what was going on. In any case, it should show nothing there for the "root" (highest-level) group.
          And the "Set reaction" action actually running when copying a rule ?
          Would you like me to create a ticket on the tracker for this ?
          • cw-kidC cw-kid
            @cw-kid said in Is this correct? Text shown in the blue banners on the rule summaries:
            That's new information. What's that?
              Then I copied that "Globe Lamp On or Off" rule from my group called "Moodlights" to the group called "Security" the action in the "Set Reaction" was fired and ran because my Globe lamp actually turned on.
                You can open a bug, but it needs to have reproducible steps, please.
                  OK its happened twice now when copying that particular rule and the Globe lamp is turned on for real.
                    Just to be clear, if you copy a rule to new rule, the new rule has no states, so if that rule is enabled, it will evaluated and it will run. So that may actually be normal and expected. The states of the original rule are not copied with the rule.
                      OK I've created a ticket you can decide.
                        I can't comment on the ticket now its closed.
                        Yes having the new copied rule disabled initially will work, you generally then want to edit and tweak that copied rule anyway and then you can enable it.
                        This will stop the copied rule just firing when you don't want it to do so.
                          1.1k
                          158.6k
