  3. Vera/openLuup plugins
  4. Plugin Switchboard : Virtual Switch in VeraPlus not shown in Openluup
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
38 Posts 5 Posters 11.9k Views 5 Watching
  • E Offline
    E Offline
    Edwin1972
    email is send to you
    • E Edwin1972
      @akbooer I've been using version 21.3.2 for a few days now, but the connection drops frequently. http: // IP: 3480 / cannot be called, so reactor doesn't work either and the lights and other things don't turn on / off automatically. Node Red can be called so my RP4 is well connected to wifi. Is it possible to go back to the old version; 20.5.22?
      @edwin1972 said in Plugin Switchboard : Virtual Switch in VeraPlus not shown in Openluup:
      A quick diagnostic...
      I assume that you mean that you can't reach AltUI at that URL, but does this get you the openLuup console?
      IP:3480/openLuup
      I'm seeing an error from AltUI in its latest update (I'm running 2.53b.) Did you accept an AltUI update recently?
      • E Offline
        E Offline
        Edwin1972
        I can't reach Altui and OpenLuup. I Use Altui 2.53b
        • E Offline
          E Offline
          Edwin1972
          #24
          I update a few weeks ago altui to 2.53b
            #25
            The fact that this happens with an older version of openLuup would tend to suggest that this (latest openLuup) isn’t the problem.
              #26
              I noticed when I first starting using my new RPI4 that the SSH connection would have frequent pregnant pauses. I'd type and get no response for a few seconds, and then it would spring to life, or a rolling output would pause and then rush to catch up. Although I have good Wifi throughout my house (and well beyond), changing the connection to Ethernet was the first thing I tried and no troubles since.
              Since then, I ran across an article where someone had figured out that at a specific resolution (1440p), the RF noise from the HDMI exactly stomps on WiFi channel 1 (which is what I use). Here: https://www.tomshardware.com/news/raspberry-pi-4-wi-fi-not-working
              LibraSunL 1 Reply Last reply
                @toggledbits said in Plugin Switchboard : Virtual Switch in VeraPlus not shown in Openluup:
                @toggledbits did you mean to post that reply under this topic? (Asking cuz I don't see its precedent)
                • E Edwin1972
                  @edwin1972
                  Can’t see anything in the logs which is untoward. What may show something is a couple of the previous logs (.1, .2) after it’s failed and you’ve restarted.
                  • LibraSunL LibraSun
                    @librasun said in Plugin Switchboard : Virtual Switch in VeraPlus not shown in Openluup:
                    Precedent was this post in topic: https://smarthome.community/post/5129
                    • E Offline
                      E Offline
                      Edwin1972
                      #30
                      I changed the connection to ethernet but the problem is not resolved. It takes sometimes over 60 minutes or even more to reconnect with openluup or alui via IP; 3480. I have ordered a new micro DS card and I restore my RP4 backup. I hope the problem may be solved.
                      The strange thing is that node red server can be reached when openluup is not available.
                        #31
                        Just out of curiosity, can you check if you are able to access the openLuup console? "http://IP:3480/openLuup"
                        That way you know whether it is openLuup or ALTUI which is causing the problem. ALTUI relies on a lot of stuff in the web if you don't localize the cdn and sometimes can cause some problems. I understand the need for the license check but for everything else, it seems silly to me so I have been localizing everything I could.
                        • E Offline
                          E Offline
                          Edwin1972
                          Both upenluup and Altui are not able to acces.
                            Have you found anything in the (previous) log file when this happens?
                              #34
                              @Edwin1972
                              This section of the latest log you sent is particularly worrying...
                              2021-03-08 19:10:48.819   luup.variable_set:: 28.urn:honeywell-com:serviceId:ThermostatData1.OutdoorHumidity was:  now:  #hooks:0
                              2021-03-08 19:10:48.819   luup.variable_set:: 28.urn:honeywell-com:serviceId:ThermostatData1.IndoorHumidity was:  now:  #hooks:0
                              2021-03-08 19:26:28.221   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.t.6.refreshStatus was:  now:  #hooks:0
                              2021-03-08 19:26:28.222   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.statusRefreshDateTime was: Mon, Mar 08, 07:10:48 PM now: Mon, Mar 08, 07:26:28 PM #hooks:0
                              2021-03-08 19:26:28.222   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.getStatus was: Successful now: Unsuccessful.  Error code: 5 #hooks:0
                              2021-03-08 19:26:28.222   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.t.6.refreshStatus was:  now: FAIL: Mon, Mar 08, 07:26 PM #hooks:0
                              2021-03-08 19:43:47.581   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.t.7.refreshStatus was:  now:  #hooks:0
                              2021-03-08 19:43:47.582   luup.variable_set:: 23.urn:joeyd-com:serviceId:HoneywellTCC1.statusRefreshDateTime was: Mon, Mar 08, 07:26:28 PM now: Mon, Mar 08, 07:43:47 PM #
                              Not one, but TWO, 15+ minute discontinuities, which Reactor spots has happened...
                              2021-03-08 19:46:05.991   luup_log:6: Reactor: ***** SYSTEM CLOCK HAS LEAPT FORWARDS! Last master tick 1615226880(2021-03-08.19:08:00), now 1615229165(2021-03-08.19:46:05)???
                              I cannot think what might cause this, other than some event external to the system.
                              I do note, however, that your Honeywell devices are very, very chatty in the logs. Is that normal? Also, what might Error code: 5 mean?
                              • E Offline
                                E Offline
                                Edwin1972
                                #35
                                @toggledbits @akbooer
                                This evening I restore my backup (image) on my RP4, but the problem was not solved yet! I checked what I had edit last week. Last week I was playing a bit with switchboard. I installed this plugin on both machines (vera and openluup). On my vera I had created two virtual switches. The Switchboard plugin on both machines (Vera and Openluup) caused problem. After removing switchboard on openluup everything runs like a charm again !!
                                  It would be really helpful if I could get a log file from you which might highlight the problem. I've not come across this difficulty myself, nor (yet) had any other reports. Has anything else changed in your system?
                                  Does the system remain up sufficiently long for you to get the logs and also revert? You can revert to any version manually by retrieving the files in the openLuup folder from the openLuup project in GitHub:
                                  History for openLuup - akbooer/openLuup
                                  a pure-Lua open-source emulation of the Vera Luup environment - History for openLuup - akbooer/openLuup
                                  I've fallen out of the habit of tagging releases, so there's not a sufficiently recent one that you can revert to automatically.
                                  I really would like to get to the root of this problem, though, rather than just trying to avoid it.
                                  That’s great, but I have to say “I told you so!”...
                                  @akbooer said in Plugin Switchboard : Virtual Switch in VeraPlus not shown in Openluup:
                                  • E Offline
                                    E Offline
                                    Edwin1972
                                    The system hangs again. Grrrr ...... What could it be? Tonight I'm going to remove the switchboard from me Vera. Hopefully that will provide the solution
                                    • E Offline
                                      E Offline
                                      Edwin1972
                                      It looks like the problem has been resolved. It turned out to be the Honeywell plugin that caused problems. Honeywell's server was unreachable. Honeywell plugin on google home did not work either. Now everything works perfectly . Thanks everyone for the help
                                        137.3k
