  3. Vera
  4. Deleting unused GeoFencing waypoints from Vera (Mobile)
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
4 Posts 2 Posters 1.1k Views 2 Watching
    Seems as though during my testing of the Vera Mobile app, I set up a couple of Scenes (now deleted) which never worked anyway.
    But MSR's "Entities" tab still shows the presence of two waypoints (with Vera ID's like vera>geo_1625761_1) which I have no clue how to delete.
    I've searched high and low in the app (Settings, Users, etc.), and can't think of anywhere in the Vera Plus UI to look for these - not even sure what to call 'em - to Delete them.
    Any clues?
      They're probably "stuck" in the black hole of Vera's cloud, or in user_data.json on your Vera (which is where MSR gets them), dissociated from anything that might have let you delete them at some point, sitting there rotting.
      I've done some work on per-device configuration exceptions, a big background effort/feature, and it has made an appearance for Hass, but isn't yet available for Vera or Hubitat. Once it is, you'll be able to filter out those entities.
        Just FYI, I posted this same question over on MCV, to see whether their staff (who lately have been VERY involved on the Forum and responding to all but the tiniest minutiae!) have any clue. Figure it's only fair to give their devs a chance (a) to prove their worth, and (b) to genuinely produce a solution where none might have existed before.
          BTW, I have them, too, of course, from my own little soire into the world of their geofencing. I suspect they simply have no way to clean up that data short of editing user_data.json, and that will only work if the data isn't mirrored in their cloud and being synced with it. I haven't bothered to experiment with that, and I probably won't. Maybe I'll just add a flag to VeraController that you can set if you don't use their geofencing and call it good.
            157.7k
