  3. Vera
  4. Deleting Multiple Devices without Reload Inbetween
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
5 Posts 2 Posters 1.8k Views 2 Watching
    Does anyone have a quick way to delete multiple devices without having to do a reload between each delete? I have about 20 child devices to get rid of and it will take forever to delete them all one by one with a reload in between.
      Wish I could offer something easy here, but in my experience, deleting multiple goes wrong too often.
      But, you might try dropping this automated delete script into startup Lua. Don't forget to remove it when the work is done...
      -- Put the device numbers of the devices you want to delete in here:
      deleteDevices = { 9991, 9992, 9993 }
      function postDeleteReload()
          luup.reload()
      luup.log( "Running Startup Lua Device Deleter", 2 )
      for _,d in ipairs( deleteDevices ) do
          if luup.devices[d] then
              luup.log( "Startup Lua Device Deleter found " .. tostring(d) .. ", deleting...", 2 )
              luup.call_action( "urn:micasaverde-com:serviceId:HomeAutomationGateway1",
                  "DeleteDevice", { DeviceNum=d }, 0 )
              luup.call_delay( "postDeleteReload", 30 )
              break
      When your Vera stops reloading, the script has deleted all of the devices and you can remove it from Startup Lua. It's meant to be slow (long delay) to give you time to get in and disable the script if it goes wrong and runs indefinitely (it shouldn't, but there's a reason skydivers have reserves).
        Going to try this, hopefully it works
          wrote on last edited by Pabla
          Didn't think this one through.. all the devices were hidden so now I am playing the guessing game for when its done lol
          Edit: It worked!!! Thanks Patrick 🙂
            @pabla said in Deleting Multiple Devices without Reload Inbetween:
            You got it figured out, but the benefit of future readers: just wait for the reloads to stop. If it goes longer than two minutes without a reload, it's done.
              1.1k
              159.0k
