  3. SNMP - Is anyone leveraging info via the Simple Network Management Protocol ?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
18 Posts 2 Posters 5.3k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi
    In my ongoing quest to try and retrieve as much information as I can about the amount of energy I’m using , I found out that I could use SNMP to see how much power (watts) my UPS is handling .
    To do this, I installed snmpd/snmp on my Vera linked Raspberry Pi, and then ran the following command.
    local command = io.popen("ssh -i /etc/dropbear/dropbear_rsa_host_key pi@192.168.102.37 'snmpwalk -Os -c public -v 1 10.10.10.103' 2>&1")
    local response = command:read("*a")
    print(response)
    Which returned a huge amount of information, which prompted me to ask the community here if there anything on Vera/OpenLuup that people have that can process this sort of information into a new devices and associated variables to then monitor/track going forward ?
    iso.3.6.1.2.1.1.1.0 = STRING: "Eaton 5P 1150"
    iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.705.1
    iso.3.6.1.2.1.1.3.0 = Timeticks: (51435090) 5 days, 22:52:30.90
    iso.3.6.1.2.1.1.4.0 = STRING: "Computer Room Manager"
    iso.3.6.1.2.1.1.5.0 = STRING: "ups239"
    iso.3.6.1.2.1.1.6.0 = STRING: "Computer Room"
    iso.3.6.1.2.1.1.7.0 = INTEGER: 72
    iso.3.6.1.2.1.1.8.0 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.1
    iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.10.3.1.1
    iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.11.3.1.1
    iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.15.2.1.1
    iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.6.3.16.2.1.1
    iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB Module from SNMPv2 entities"
    iso.3.6.1.2.1.1.9.1.3.2 = STRING: "SNMP Management Architecture MIB"
    iso.3.6.1.2.1.1.9.1.3.3 = STRING: "Message Processing and Dispatching MIB"
    iso.3.6.1.2.1.1.9.1.3.4 = STRING: "USM User MIB"
    iso.3.6.1.2.1.1.9.1.3.5 = STRING: "VACM MIB"
    iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (0) 0:00:00.00
    iso.3.6.1.2.1.2.1.0 = INTEGER: 2
    iso.3.6.1.2.1.2.2.1.1.1 = INTEGER: 1
    iso.3.6.1.2.1.2.2.1.1.2 = INTEGER: 2
    iso.3.6.1.2.1.2.2.1.2.1 = STRING: "LOOPBACK"
    iso.3.6.1.2.1.2.2.1.2.2 = STRING: "eth0"
    iso.3.6.1.2.1.2.2.1.3.1 = INTEGER: 24
    iso.3.6.1.2.1.2.2.1.3.2 = INTEGER: 6
    iso.3.6.1.2.1.2.2.1.4.1 = INTEGER: 1500
    iso.3.6.1.2.1.2.2.1.4.2 = INTEGER: 1500
    etc....
    • parkercP Offline
      parkercP Offline
      parkerc
      Oh, and if I just want to pull one of the items I just specify the iso number with the snmpget command. E.g
      local command = io.popen("ssh -i /etc/dropbear/dropbear_rsa_host_key pi@192.168.102.37 'snmpget -v1 -c public 10.10.10.103 iso.3.6.1.2.1.1.1.0' 2>&1")
      print(response)
      which in this case will just return the first one.
      • propheadP Offline
        propheadP Offline
        prophead
        I use a lua scene to read snmp network usage from my switches. Working great for a couple of years now.
        • parkercP Offline
          parkercP Offline
          parkerc
          Hi @prophead - can you share more details on the Scene, is it with Lua/luup code ?
          propheadP 2 Replies Last reply
          • parkercP parkerc
            propheadP Offline
            propheadP Offline
            prophead
            wrote on last edited by prophead
            @parkerc Yes, I have 3 lua scenes, one for each switch for LAN monitoring and one for my Edgerouter for WAN monitoring. Each uses the same basic snmp framework with device specific tweaks and then saves results to an empty device and then I graph those device variables. I'm happy to share my code below:
            • parkercP parkerc
              propheadP Offline
              propheadP Offline
              prophead
              @parkerc this is the Dlink 8 port SNMP switch lua:
              -- SNMP 8 port BWmon
              -- read stored in/out values
              local lines = ""
              local Din = {}
              local Dout = {}
              local Oin = {}
              local Oout = {}
              local Nin = {}
              local Nout = {}
              local T = {}
              local i,j
              --check for switch
              local ping = os.execute("ping -c 1 192.168.1.11")
              if ping ~= 0 then
                luup.log("Dlink 8: Switch down. Aborted.")
                do return end
              for i = 1,8 do
              -- read stored values
                 local f = io.open("/tmp/8"..i.."I.txt")
                 if f then
                 for line in f:lines() do
                   lines = line
                 end -- for each line
                f:close()
                else os.execute("touch /tmp/8"..i.."I.txt")
                if not lines then lines = "0" end
                Oin[i] = lines
                --print (Oin[i])
                 local f = io.open("/tmp/8"..i.."O.txt")
                 if f then
                     lines = line
                 f:close()
                 else os.execute("touch /tmp/8"..i.."O.txt")
                Oout[i] = lines
                --print (Oout[i])
              end -- for each port read
              -- parse values
              for j = 1,8 do
              Oin[j] = string.match(Oin[j], ".*Counter32: (%d+)")
              if Oin[j] == "" or Oin[j] == nil then Oin[j] = 0 end
              Oout[j] = string.match(Oout[j], ".*Counter32: (%d+)")
              if Oout[j] == "" or Oout[j] == nil then Oout[j] = 0 end
              -- read snmp
              lines = ""
              os.execute("/usr/bin/snmpget -r 1 -v1 -c PASSWORD 192.168.1.11 iso.3.6.1.2.1.2.2.1.10."..j.." >/tmp/8"..j.."I.txt")
              local f = io.open("/tmp/8"..j.."I.txt")
                 if not f then return end
                    lines = line
              f:close()
              Nin[j] = lines
              --print (Nin[j])
              lines = ""
              os.execute("/usr/bin/snmpget -r 1 -v1 -c PASSWORD 192.168.1.11 iso.3.6.1.2.1.2.2.1.16."..j.." >/tmp/8"..j.."O.txt")
              local f = io.open("/tmp/8"..j.."O.txt")
                    lines = line
              f:close()
              Nout[j] = lines
              --print (Nout[j])
              --parse
              Nin[j] = string.match(Nin[j], ".*Counter32: (%d+)")
              if Nin[j] == "" or Nin[j] == nil then Nin[j] = 0 end
              Nout[j] = string.match(Nout[j], ".*Counter32: (%d+)")
              if Nout[j] == "" or Nout[j] == nil then Nout[j] = 0 end
              --print (Nin[j])
              --print (Nout[j])
              --deltas
              Din[j] = Nin[j] - Oin[j]
              Dout[j] = Nout[j] - Oout[j]
              local max32 = 4294967295
              --local max32 = 4294966864
              -- handle rotation
              if Nin[j] < Oin[j] then Din[j] = max32 - Oin[j] + Nin[j] end
              if Nout[j] < Oout[j] then Dout[j] = max32 - Oout[j] + Nout[j] end
              if Din[j] > max32 or Din[j]<0 then Din[j] = 0 end --math.max(Oin[j],Nin[j]) end
              if Dout[j] > max32 or Dout[j]<0 then Dout[j] = 0 end --math.max(Oout[j],Nout[j]) end
              end -- end for each port write
              -- add real time interval tracking
              -- read old time
              lines = ""
              local ot = ""
              local f = io.open("/tmp/lastDlink8run.txt")
                  if not f then os.execute("touch /tmp/lastDlink8run.txt") return end
                      ot = line
              f:close()
              if not ot then ot = "300" end -- default to five minutes
              -- write new time
              local nt = tonumber(os.time())
              local t = assert(io.open("/tmp/lastDlink8run.txt", "w"), "Failed to open lastDlink8run.txt")
              t:write(nt)
              io.close(t)
              -- delta seconds
              local nds = nt - ot
              -- bounds
              if nds < 24 then nds = 24 end
              if nds > 900 then nds = 900 end
              -- debugging
              local t = assert(io.open("/tmp/Dlink8nds.txt", "w"), "Failed to open Dlink8nds.txt")
              t:write(nds)
              io.close(t)
              -- maths
              for k = 1,8 do
              Din[k] = ((Din[k]/nds)/1024)
              if Din[k] > 1500000 then Din[k] = 0 end
              Dout[k] = ((Dout[k]/nds)/1024)
              if Dout[k] > 1500000 then Dout[k] = 0 end
              T[k] = Din[k]+Dout[k]
              end -- end for each K conversion
              -- set luup device variables for device 12, LAN
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DoorBirdINKBps", Din[1] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DoorBirdOUTKBps", Dout[1] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DoorBirdKBps", T[1] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "RoomHubINKBps", Din[2] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "RoomHubOUTKBps", Dout[2] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "RoomHubKBps", T[2] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "BedroomINKBps", Din[3] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "BedroomOUTKBps", Dout[3] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "BedroomKBps", T[3] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DownstairsINKBps", Din[4] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DownstairsOUTKBps", Dout[4] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "DownstairsKBps", T[4] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "LivingRoomINKBps", Din[5] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "LivingRoomOUTKBps", Dout[5] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "LivingRoomKBps", T[5] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "KitchenINKBps", Din[6] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "KitchenOUTKBps", Dout[6] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "KitchenKBps", T[6] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "UpstairsINKBps", Din[7] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "UpstairsOUTKBps", Dout[7] , 12)
              luup.variable_set("urn:upnp-org:serviceId:altui1", "UpstairsKBps", T[7] , 12)
              • parkercP Offline
                parkercP Offline
                parkerc
                Many thanks for sharing @prophead
                QQ - How did you get smtpget installed on your Vera ? (I don’t have smtpget listed in usr/bin ?)
                propheadP 3 Replies Last reply
                • propheadP Offline
                  propheadP Offline
                  prophead
                  Altui on a pi
                  • parkercP parkerc
                    propheadP Offline
                    propheadP Offline
                    prophead
                    @parkerc then I use grafana to graph
                    • parkercP parkerc
                      propheadP Offline
                      propheadP Offline
                      prophead
                      @parkerc I’m going to point you here:
                      GitHub - jertel/vuegraf: Populate metrics from your Emporia Vue energy monitoring devices into an InfluxDB
                      Populate metrics from your Emporia Vue energy monitoring devices into an InfluxDB - jertel/vuegraf
                      For more energy centric metrics then snmp. I love the vue devices and the grafana integration with this link is stellar for really understanding your energy use.
                      • parkercP parkerc
                        propheadP Offline
                        propheadP Offline
                        prophead
                        @parkerc
                        FC4656C3-8DD1-4493-9E74-5DC71923C335.jpeg F2329C8D-3B50-4C93-914B-8BA3FF49656C.jpeg
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Impressive stuff, thanks for sharing @prophead ..
                          Earlier you mentioned ‘ Edgerouter’ , does that mean you have a Ubiquiti router ? If so would you be able to share the scene Lua for that, as I have a Unfi set up so would love to test that out..
                          • parkercP parkerc
                            propheadP Offline
                            propheadP Offline
                            prophead
                            @parkerc
                            -- SNMP BWmon
                            local files = ""
                            local f = io.open("/tmp/INO.txt")
                            if not f then os.execute("touch /tmp/INO.txt") end
                                  files = line
                            f:close()
                            local OINO = files
                            local f = io.open("/tmp/OUTO.txt")
                            if not f then os.execute("touch /tmp/OUTO.txt") end
                                  files = line
                            f:close()
                            if not files then files = "Counter32: (0)" end
                            local OOUTO = files
                            -- parse values
                            local ROINO = string.match(OINO, ".*Counter32: (%d+)")
                            local ROOUTO = string.match(OOUTO, ".*Counter32: (%d+)")
                            -- read snmp
                            os.execute("/usr/bin/snmpget -r 1 -v1 -c PASSWORD 172.16.0.1 iso.3.6.1.2.1.2.2.1.10.4 >/tmp/INO.txt")
                                  files = line
                            f:close()
                            local INO = files
                            --print (INO)
                            files = ""
                             os.execute("/usr/bin/snmpget -r 1 -v1 -c PASSWORD 172.16.0.1 iso.3.6.1.2.1.2.2.1.16.4 >/tmp/OUTO.txt")
                                    files = line
                            f:close()
                            local OUTO = files
                            --print (OUTO)
                            --parse
                            local RINO = 0
                            RINO = string.match(INO, ".*Counter32: (%d+)")
                            local ROUTO = 0
                            ROUTO = string.match(OUTO, ".*Counter32: (%d+)")
                            --print (RINO)
                            --print (ROUTO)
                            --maths
                            local RINB = 0
                            RINB = RINO --* 8
                            local ROINB = 0
                            ROINB = ROINO --* 8
                            local ROUTB = 0
                            ROUTB = ROUTO --* 8
                            local ROOUTB = 0
                            ROOUTB = ROOUTO --* 8
                            --deltas
                            local INt = 0
                            INt = RINB - ROINB
                            local OUTt = 0
                            OUTt = ROUTB - ROOUTB
                            --debug
                            --luup.log ('RINB ='..RINB..', ROINB ='..ROINB)
                            --luup.log ('ROUTB ='..ROUTB..', ROOUTB ='..ROOUTB)
                            -- handle rotation
                            if RINB < ROINB then INt = max32 - ROINB + RINB end
                            if ROUTB < ROOUTB then OUTt = max32 - ROOUTB + ROUTB end
                            if INt > max32 or INt<0 then INt = max(RINB,ROINB) end
                            if OUTt > max32 or OUTt<0 then OUTt = max(ROUTB,ROOUTB) end
                            --luup.log ('INt ='..INt..', OUTt ='..OUTt)
                            -- 60 is 1 min interval and 1024 makes kBps
                            local kbpsINt = ((INt/60)/1024)
                            local kbpsOUTt = ((OUTt/60)/1024)
                            local total = kbpsINt + kbpsOUTt
                            luup.variable_set("urn:upnp-org:serviceId:altui1", "ComcastKBps", total, 11)
                            luup.variable_set("urn:upnp-org:serviceId:altui1", "ComcastInKBps", kbpsINt, 11)
                            luup.variable_set("urn:upnp-org:serviceId:altui1", "ComcastOutKBps", kbpsOUTt, 11)
                            • parkercP parkerc
                              propheadP Offline
                              propheadP Offline
                              prophead
                              @parkerc as you can see it's virtually same because SNMP is pretty standardized. Yes, this is the ubiquity edgerouter, a great $60 piece of kit. I use it for ISP failover and firewall.
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                Many thanks @prophead - I’m going to try and use this with my UniFi Switch this morning..
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Quick observation, if I try the following against my UniFi (USG) Router
                                  local command = io.popen("ssh -y -i /etc/dropbear/dropbear_rsa_host_key pi@192.168.102.144 'snmpget -r 1 -v1 -c public 192.168.102.1 iso.3.6.1.2.1.2.2.1.10.4' 2>&1")
                                  print(response)
                                  it times out..
                                  Timeout: No Response from 192.168.102.1.
                                  Yet if I try this against a UniFi Switch,
                                  local command = io.popen("ssh -y -i /etc/dropbear/dropbear_rsa_host_key pi@192.168.102.144 'snmpget -r 1 -v1 -c public 192.168.102.7 iso.3.6.1.2.1.2.2.1.10.4' 2>&1")
                                  print(response)
                                  it works fine.
                                  iso.3.6.1.2.1.2.2.1.10.4 = Counter32: 29157590
                                  Hummm..
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    I tried an snmpwalk on the UniFi (USG) Router too,
                                    'snmpwalk -Os -c public -v 1 192.168.102.1' 2>&1
                                    and that timed out..
                                    More digging is needed later, as all seem to have SNMP enabled..
                                    propheadP 1 Reply Last reply
                                    • parkercP parkerc
                                      propheadP Offline
                                      propheadP Offline
                                      prophead
                                      @parkerc sounds like a permissions issue. Debug on command line before trying to script. I would also avoid use of the public access to snmp as it’s a potential security issue. I always setup private domain the proceedure differs by manufacturers. You can use snmpwalk for debugging then move to snmpget once you’re ready to drill down. Good luck.
                                        156.0k
