  3. Vera/openLuup plugins
  4. Tesla Plugin Not Logging in After v2.3
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
8 Posts 2 Posters 1.8k Views 2 Watching
    Hello @mrFarmer , ever since the v2.3 update I haven't been able to login to my account attached are the logs. Before the update I was getting the wake-up error too. I rolled back to V2.2 and the plugin was stuck on "updating car status".
    06	05/17/21 10:45:20.102	Device_Variable::m_szValue_set device: 168 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x11c7b58/NONE duplicate:0 <0x7708d520>
    06	05/17/21 10:45:20.103	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273198 now: 1621273520 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520>
    01	05/17/21 10:45:20.160	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520>
    01	05/17/21 10:45:25.101	luup_device_message missing args <0x73394520>
    01	05/17/21 10:45:25.102	luup_device_message missing args <0x73394520>
    06	05/17/21 10:45:25.103	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273520 now: 1621273525 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520>
    01	05/17/21 10:45:25.158	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520>
    01	05/17/21 10:45:30.102	luup_device_message missing args <0x73394520>
    01	05/17/21 10:45:30.103	luup_device_message missing args <0x73394520>
    06	05/17/21 10:45:30.104	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273525 now: 1621273530 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520>
    01	05/17/21 10:45:30.165	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520>
    01	05/17/21 10:45:35.101	luup_device_message missing args <0x73394520>
    01	05/17/21 10:45:35.102	luup_device_message missing args <0x73394520>
    06	05/17/21 10:45:35.103	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273530 now: 1621273535 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520>
    01	05/17/21 10:45:35.156	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520>
    04	05/17/21 10:45:37.219	<Job ID="16" Name="pollnode #9 1 cmds" Device="129" Created="2021-05-17 10:45:37" Started="2021-05-17 10:45:37" Completed="2021-05-17 10:45:37" Duration="0.117271000" Runtime="0.116483000" Status="Successful" LastNote="" Node="9" NodeType="ZWaveDimmableLight" NodeDescription="Shed Inside Light"/> <0x7708d520>
    02	05/17/21 10:45:37.219	Device_Basic::AddPoll 129 poll list full, deleting old one <0x7708d520>
    06	05/17/21 10:45:37.220	Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x7708d520>
    06	05/17/21 10:45:37.221	Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastPollSuccess was: 1621273204 now: 1621273537 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7708d520>
    06	05/17/21 10:45:37.221	Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: ConsecutivePollFails was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x7708d520>
    01	05/17/21 10:45:40.100	luup_device_message missing args <0x73394520>
    01	05/17/21 10:45:40.101	luup_device_message missing args <0x73394520>
    06	05/17/21 10:45:40.103	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273535 now: 1621273540 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520>
    01	05/17/21 10:45:40.157	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520>
    01	05/17/21 10:45:40.157	luup_log:901: Tesla Car_error: Could not login to Tesla API after 5 attempts. <0x73394520>
    <0x745ef520>
    02	05/17/21 10:45:45.701	luvd_get_info mg conn can't read /etc/cmh-ludl//shared.js or /etc/cmh-lu//shared.js from filename /shared.js pPtrFile (null) <0x6ed5f520>```
      mrFarmer
      Hi Pabla,
      Tesla made a change to obtain the tokens again 😞 So need some time to find the new way. As long as the tokens are there it will still be working.
      Cheers Rene
      PablaP 2 Replies Last reply
      • M mrFarmer
        Hi Pabla,
        Cheers Rene
        @mrfarmer Oh no!! I was hoping that was not the case, hopefully its not too difficult to fix this! Let me know if you need any help with testing 🙂
        • M mrFarmer
          Hi Pabla,
          Cheers Rene
          @mrfarmer So I updated to V2.4 and I still can't seem to login. The plugin keeps saying the vehicle is in deep sleep when its not.
          luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x72937520>
            Here are some more logs
            01	06/07/21 9:03:18.593	luup_log:901: Tesla Car_error: Unable to wake up car in set time. <0x72937520>
            01	06/07/21 9:03:18.596	luup_log:901: Tesla Car_error: Wake up error. Reason #408, Unable to wakeup car.. <0x72937520>
            06	06/07/21 9:03:18.596	Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Not ready for regular polling. Check settings or reload luup. now: Wake up error. Reason  Unable to wakeup car. #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x72937520>
            06	06/07/21 9:03:18.848	Device_Variable::m_szValue_set device: 1304 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.851	Device_Variable::m_szValue_set device: 1321 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.882	Device_Variable::m_szValue_set device: 1305 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.885	Device_Variable::m_szValue_set device: 1306 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.888	Device_Variable::m_szValue_set device: 1307 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.890	Device_Variable::m_szValue_set device: 1308 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.892	Device_Variable::m_szValue_set device: 1309 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.895	Device_Variable::m_szValue_set device: 1310 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.896	Device_Variable::m_szValue_set device: 1311 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.900	Device_Variable::m_szValue_set device: 1312 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.904	Device_Variable::m_szValue_set device: 1313 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.906	Device_Variable::m_szValue_set device: 1314 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.908	Device_Variable::m_szValue_set device: 1315 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.911	Device_Variable::m_szValue_set device: 1316 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.912	Device_Variable::m_szValue_set device: 1317 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.918	Device_Variable::m_szValue_set device: 1318 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.926	Device_Variable::m_szValue_set device: 1319 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.928	Device_Variable::m_szValue_set device: 1320 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.931	Device_Variable::m_szValue_set device: 1323 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:18.942	Device_Variable::m_szValue_set device: 1324 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520>
            06	06/07/21 9:03:19.180	Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Wake up error. Reason  Unable to wakeup car. now: Not ready for regular polling. Check settings or reload luup. #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x6e4fe520>
            01	06/07/21 9:03:19.181	luup_device_message missing args <0x6e4fe520>
            01	06/07/21 9:03:19.182	luup_device_message missing args <0x6e4fe520>
            06	06/07/21 9:03:19.183	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623077691 now: 1623081799 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6e4fe520>
            01	06/07/21 9:03:19.515	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x6e4fe520>
            06	06/07/21 9:03:19.517	Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Not ready for regular polling. Check settings or reload luup. now: Updating car status... #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x6e4fe520>
            01	06/07/21 9:03:24.101	luup_device_message missing args <0x72937520>
            01	06/07/21 9:03:24.102	luup_device_message missing args <0x72937520>
            06	06/07/21 9:03:24.103	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623081799 now: 1623081804 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72937520>
            01	06/07/21 9:03:24.594	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x72937520>
            01	06/07/21 9:03:29.101	luup_device_message missing args <0x72937520>
            01	06/07/21 9:03:29.102	luup_device_message missing args <0x72937520>
            06	06/07/21 9:03:29.104	Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623081804 now: 1623081809 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72937520>
            01	06/07/21 9:03:29.469	luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x72937520>```
              mrFarmer
              Hi Pabla,
              Try to clear the Credentials variable by entering {} for it. That will force a complete new login. Maybe that will clear this too, but I have not seen this message though.
              Cheers Rene
                That did the trick! Back up and working now
                  mrFarmer
                  Great. I need to make some re-login function so you can force this and with that I might be able to get it working with MFA and no need to store password.
                    152.5k
