  4. [Solved] MSR won't start after upgrade
3 Posts 2 Posters 936 Views 2 Watching
    Did an upgrade from 21200, but MSR (on bare metal linux) did not start:
    2021-08-17T10:45:20.985Z <app:null> Reactor latest-21228-05d7497 starting on v14.16.0
    2021-08-17T10:45:21.009Z <app:INFO> Process ID 15806; platform linux/arm #25556 SMP Thu Mar 4 17:56:56 CST 2021
    2021-08-17T10:45:21.010Z <app:INFO> Basedir /home/reactor; data in /home/reactor/storage
    2021-08-17T10:45:21.012Z <app:INFO> NODE_PATH (undefined); module paths [ "/home/reactor/node_modules", "/home/node_modules", "/node_modules" ]
    internal/modules/cjs/loader.js:883
      throw err;
    Error: Cannot find module 'server/lib/httpapi'
    Running 'npm install --loglevel error --no-save' to install package dependencies does not help.
      Your NODE_PATH environment variable isn't set. What mechanism are you using to start Reactor?
      If you are using systemd, you need to add the following line to the [Service] section (with your correct path):
      Environment=NODE_PATH=/path/to/installed/reactor
      Since you are changing the service configuration file, you also must do:
      sudo systemctl daemon-reload
      You can then start/restart Reactor:
      sudo systemctl restart reactor
      If you are using app.sh, that's no longer supported and you should switch to systemd. The template service file can be found in the tools directory, and there are instructions in the Manual.
        Using pm2, but was testing with "node app.js". 21200 worked fine without NODE_PATH set
        EDIT: now works with NODE_PATH set. Still wondering if there has been a change related to this as with build 21200 I didn't have this set?
          154.3k
