  4. EzloController error
20 Posts 3 Posters 4.1k Views 3 Watching
    Why don't you just condition the sys_system.state attribute of the openLuup controller's system entity?
    @toggledbits Today I got a false positive from Reactor saying my Ezlo Plus was offline, a restart of Reactor solved it.
    This was found in the log before the restart:
    2021-10-01T06:32:29.441Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: RangeError: Maximum call stack size exceeded
    2021-10-01T06:32:29.441Z <EzloController:CRIT> RangeError: Maximum call stack size exceeded
        at EzloController._now.ws_message [as refreshTime] (/home/user/reactor/server/lib/EzloController.js:1134:127)
        at EzloController._now.ws_message [as refreshTime] (/home/user/reactor/server/lib/EzloController.js:1138:54)
    2021-10-01T06:32:38.985Z <EzloController:ERR> EzloController#ezlo request "17c3a8dccaf" (hub.info.get) failed: TimedPromise timeout
    2021-10-01T06:32:38.985Z <EzloController:ERR> EzloController#ezlo failed to complete inventory: TimedPromise timeout
    2021-10-01T06:32:38.985Z <EzloController:CRIT> !TimedPromise timeout
    2021-10-01T06:32:38.988Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1002
    Reactor latest-21270-48528ec, updated to latest-21270-46679ac just now.
    CrilleC 1 Reply Last reply
      When posting error messages from the logs it's really helpful to post several dozen lines from before the message, as well as the message itself. This gives the message more context and usually exposes what was going on at the time the error occurred. Can you post a bit of context for me? It would also be helpful to know what version of MSR you are running.
      • CrilleC Crille
        @crille said in EzloController error:
        One of my rules executed at the time uses set variable and I was running the version without the fix. I'm guessing the controller was unreachable for a short time but Reactor never caught the online status cause of the "Maximum call stack size exceeded".
        The hub responded but was offline in Reactor until I restarted Reactor.
        2021-10-01T04:00:00.002Z <Rule:INFO> Schema - Vitrinskåp (Rule#rule-kmusx4kh) SET!
        2021-10-01T04:00:00.003Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:00.003Z <Engine:INFO> Enqueueing "Schema - Vitrinskåp<SET>" (rule-kmusx4kh:S)
        2021-10-01T04:00:00.007Z <Engine:5:Engine.js:1219> Engine#1 enqueued reaction rule-kmusx4kh:S as 428
        2021-10-01T04:00:00.007Z <Engine:5:Engine.js:1359> _process_reaction_queue() ending with 1 in queue; waiting for 1633060800007<10/1/2021, 6:00:00 AM> (next delayed task)
        2021-10-01T04:00:00.008Z <Rule:INFO> Schema - Larm: Nattläge (Rule#rule-ksvitzde) RESET!
        2021-10-01T04:00:00.009Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:00.009Z <Engine:INFO> Enqueueing "Schema - Larm: Nattläge<RESET>" (rule-ksvitzde:R)
        2021-10-01T04:00:00.009Z <Engine:5:Engine.js:1219> Engine#1 enqueued reaction rule-ksvitzde:R as 429
        2021-10-01T04:00:00.010Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 428 { "tid": 428, "id": "rule-kmusx4kh:S", "rule": "rule-kmusx4kh", "__reaction": [RuleReaction#rule-kmusx4kh:S], "next_step": 0, "status": 0, "ts": 1633060800003, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-10-01T04:00:00.010Z <Engine:NOTICE> Starting reaction Schema - Vitrinskåp<SET> (rule-kmusx4kh:S)
        2021-10-01T04:00:00.010Z <Engine:5:Engine.js:1421> Engine#1 reaction rule-kmusx4kh:S step 0 perform { "entity": "ezlo>device_603a0363129e0715cf4a75fe", "action": "power_switch.on" }
        2021-10-01T04:00:00.011Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status 3; task 428
        2021-10-01T04:00:00.012Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 429 { "tid": 429, "id": "rule-ksvitzde:R", "rule": "rule-ksvitzde", "__reaction": [RuleReaction#rule-ksvitzde:R], "next_step": 0, "status": 0, "ts": 1633060800009, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-10-01T04:00:00.012Z <Engine:NOTICE> Starting reaction Schema - Larm: Nattläge<RESET> (rule-ksvitzde:R)
        2021-10-01T04:00:00.012Z <Engine:5:Engine.js:1421> Engine#1 reaction rule-ksvitzde:R step 0 perform { "entity": "vera>device_10050", "action": "x_vera_plugin_housemodes.set_house_mode", "args": { "new_mode": "1" } }
        2021-10-01T04:00:00.013Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status 3; task 429
        2021-10-01T04:00:00.013Z <VeraController:null> VeraController#vera enqueue task for Entity#vera>device_10050 action x_vera_plugin_housemodes.set_house_mode: task { "newHModeValue": 1, "DeviceNum": 10050, "id": "action", "serviceId": "urn:micasaverde-com:serviceId:HouseModes1", "action": "SetHMode" }
        2021-10-01T04:00:00.014Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 2 in queue; none delayed/ready; waiting
        2021-10-01T04:00:00.014Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:00:00.015Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:00:00.017Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:00.017Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 429 { "tid": 429, "id": "rule-ksvitzde:R", "rule": "rule-ksvitzde", "__reaction": [RuleReaction#rule-ksvitzde:R], "next_step": 1, "status": 1, "ts": 1633060800009, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
        2021-10-01T04:00:00.017Z <Engine:NOTICE> Resuming reaction Schema - Larm: Nattläge<RESET> (rule-ksvitzde:R) from step 1
        2021-10-01T04:00:00.018Z <Engine:INFO> Schema - Larm: Nattläge<RESET> all actions completed.
        2021-10-01T04:00:00.018Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status -1; task 429
        2021-10-01T04:00:00.019Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
        2021-10-01T04:00:00.025Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:00:00.026Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:00:00.146Z <Engine:5:Engine.js:1083> Engine#1 var HouseMode dependency entity-changed Entity#vera>device_10050
        2021-10-01T04:00:00.148Z <default:CRIT> Error: Object does not exist
            at Function.getInstance (/home/username/reactor/server/lib/GlobalExpression.js:135:27)
            at Engine._expr_dependency (/home/username/reactor/server/lib/Engine.js:1084:59)
            at /home/username/reactor/server/lib/MessageBus.js:103:200
            at MessageBus._sendToBus (/home/username/reactor/server/lib/MessageBus.js:100:46)
            at Immediate._onImmediate (/home/username/reactor/server/lib/MessageBus.js:113:34)
            at processImmediate (internal/timers.js:461:21)
        2021-10-01T04:00:00.149Z <Engine:5:Engine.js:1083> Engine#1 var hm dependency entity-changed Entity#vera>housemode
        2021-10-01T04:00:00.151Z <default:CRIT> Error: Object does not exist
        2021-10-01T04:00:00.156Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>housemode) ctx=other
        2021-10-01T04:00:00.156Z <Rule:INFO> Notifiering - House mode (Rule#rule-ksw26xod) SET!
        2021-10-01T04:00:00.165Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:00.166Z <Engine:INFO> Enqueueing "Notifiering - House mode<SET>" (rule-ksw26xod:S)
        2021-10-01T04:00:00.167Z <Engine:5:Engine.js:1219> Engine#1 enqueued reaction rule-ksw26xod:S as 430
        2021-10-01T04:00:00.167Z <Engine:5:Engine.js:1359> _process_reaction_queue() ending with 2 in queue; waiting for 1633060800167<10/1/2021, 6:00:00 AM> (next delayed task)
        2021-10-01T04:00:00.170Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>housemode) ctx=other
        2021-10-01T04:00:00.178Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:00.179Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 430 { "tid": 430, "id": "rule-ksw26xod:S", "rule": "rule-ksw26xod", "__reaction": [RuleReaction#rule-ksw26xod:S], "next_step": 0, "status": 0, "ts": 1633060800166, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-10-01T04:00:00.179Z <Engine:NOTICE> Starting reaction Notifiering - House mode<SET> (rule-ksw26xod:S)
        2021-10-01T04:00:00.179Z <Engine:5:Engine.js:1470> Engine#1 reaction rule-ksw26xod:S step 0 notify Pushover with { "message": "Larmet ändrades från night till home.", "profile": "MSR", "title": "Larmet ändrade status", "priority": "0" }
        2021-10-01T04:00:00.180Z <NotifyPushover:5:NotifyPushover.js:228> NotifyPushover sending profile MSR notification request: Larmet ändrades från night till home.
        2021-10-01T04:00:00.182Z <Engine:INFO> Notifiering - House mode<SET> all actions completed.
        2021-10-01T04:00:00.182Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status -1; task 430
        2021-10-01T04:00:00.185Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
        2021-10-01T04:00:01.171Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>housemode) ctx=other
        2021-10-01T04:00:01.171Z <Rule:INFO> Notifiering - House mode (Rule#rule-ksw26xod) RESET!
        2021-10-01T04:00:01.171Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:01.172Z <Engine:INFO> Enqueueing "Notifiering - House mode<RESET>" (rule-ksw26xod:R)
        2021-10-01T04:00:01.173Z <Engine:5:Engine.js:1219> Engine#1 enqueued reaction rule-ksw26xod:R as 431
        2021-10-01T04:00:01.173Z <Engine:5:Engine.js:1359> _process_reaction_queue() ending with 2 in queue; waiting for 1633060801173<10/1/2021, 6:00:01 AM> (next delayed task)
        2021-10-01T04:00:01.184Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:01.184Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 431 { "tid": 431, "id": "rule-ksw26xod:R", "rule": "rule-ksw26xod", "__reaction": [RuleReaction#rule-ksw26xod:R], "next_step": 0, "status": 0, "ts": 1633060801172, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-10-01T04:00:01.185Z <Engine:NOTICE> Starting reaction Notifiering - House mode<RESET> (rule-ksw26xod:R)
        2021-10-01T04:00:01.185Z <Engine:5:Engine.js:1597> Engine#1 reaction rule-ksw26xod:R step 0 set variable prevHouseMode=${{housemode}} (string home)
        2021-10-01T04:00:01.185Z <Engine:5:Engine.js:1161> Engine#1 global set variable prevHouseMode = (string) home
        2021-10-01T04:00:01.185Z <Engine:5:Engine.js:1167> Engine#1 var prevHouseMode set/changed to (string)home
        2021-10-01T04:00:01.185Z <Engine:INFO> Notifiering - House mode<RESET> all actions completed.
        2021-10-01T04:00:01.186Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status -1; task 431
        2021-10-01T04:00:01.186Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
        2021-10-01T04:00:01.186Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>housemode) ctx=other
        2021-10-01T04:00:01.187Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>housemode) ctx=other
        2021-10-01T04:00:05.003Z <Engine:INFO> Engine#1 master timer tick, local time "10/1/2021, 6:00:05 AM" (TZ offset 120 mins from UTC)
        2021-10-01T04:00:10.233Z <NotifyPushover:ERR> NotifyPushover failure response from endpoint: 520 (undefined)
        2021-10-01T04:00:10.233Z <NotifyPushover:INFO> NotifyPushover request URL: https://api.pushover.net/1/messages.json
        2021-10-01T04:00:10.234Z <NotifyPushover:INFO> NotifyPushover request body: token=xxxxxxxxxxxxxxxxxxxx&user=xxxxxxxxxxxxxxxxxxxxxxxxx&priority=0&title=Larmet%20%C3%A4ndrade%20status&message=Larmet%20%C3%A4ndrades%20fr%C3%A5n%20night%20till%20home.
        2021-10-01T04:00:10.234Z <NotifyPushover:ERR> NotifyPushover request to https://api.pushover.net/1/messages.json failed: Error: NotifyPushover request failed
        2021-10-01T04:00:10.234Z <Engine:ERR> Engine#1 reaction rule-ksw26xod:S step 0 notification (Pushover) failed: Error: NotifyPushover request failed
        2021-10-01T04:00:13.164Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:13.165Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:13.167Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:13.168Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:13.169Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:13.170Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:13.171Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:00:15.015Z <EzloController:ERR> EzloController#ezlo request "17c3a02460b" ({ "method": "hub.item.value.set", "api": "1.0" }) failed: TimedPromise timeout
        2021-10-01T04:00:15.017Z <EzloController:WARN> EzloController#ezlo action power_switch.on on Entity#ezlo>device_603a0363129e0715cf4a75fe failed!
        2021-10-01T04:00:15.018Z <Engine:ERR> Engine#1 reaction rule-kmusx4kh:S step 0 perform power_switch.on failed: TimedPromise timeout
        2021-10-01T04:00:15.018Z <Engine:INFO> Engine#1 action args: {  }
        2021-10-01T04:00:15.018Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:00:15.020Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 428 { "tid": 428, "id": "rule-kmusx4kh:S", "rule": "rule-kmusx4kh", "__reaction": [RuleReaction#rule-kmusx4kh:S], "next_step": 1, "status": 1, "ts": 1633060800003, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
        2021-10-01T04:00:15.020Z <Engine:NOTICE> Resuming reaction Schema - Vitrinskåp<SET> (rule-kmusx4kh:S) from step 1
        2021-10-01T04:00:15.021Z <Engine:INFO> Schema - Vitrinskåp<SET> all actions completed.
        2021-10-01T04:00:15.021Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status -1; task 428
        2021-10-01T04:00:15.023Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
        2021-10-01T04:00:57.033Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:57.033Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:57.035Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:57.036Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:57.037Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:57.038Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:00:58.167Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:58.168Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:00:58.172Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:58.173Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:58.174Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:58.176Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:00:58.176Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:01:00.004Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 1ms and returned 22 entities
        2021-10-01T04:01:00.009Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 1ms and returned 22 entities
        2021-10-01T04:01:00.018Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:01:00.023Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 5ms and returned 22 entities
        2021-10-01T04:01:12.961Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:12.961Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:12.961Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:12.962Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:12.963Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:12.963Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:01:13.165Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:13.165Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:13.167Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:13.168Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:13.169Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:13.170Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:01:56.999Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:56.999Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:57.000Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:57.001Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:57.001Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:01:58.169Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:58.170Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:01:58.172Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:58.173Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:58.174Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:58.175Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:01:58.176Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:02:00.004Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:02:00.005Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:02:00.015Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:02:00.016Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:02:13.427Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:13.428Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:13.430Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:13.431Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:13.433Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:13.433Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:02:34.912Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1006
        2021-10-01T04:02:39.918Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
        2021-10-01T04:02:39.918Z <EzloController:INFO> EzloController#ezlo opening hub connection to "XXXXXXXX" at wss://192.168.1.100:17000
        2021-10-01T04:02:39.920Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.1.100:17000
        2021-10-01T04:02:40.007Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://192.168.1.100:17000)
        2021-10-01T04:02:40.007Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-10-01T04:02:55.016Z <EzloController:ERR> EzloController#ezlo request "17c3a04b708" (hub.info.get) failed: TimedPromise timeout
        2021-10-01T04:02:55.017Z <EzloController:ERR> EzloController#ezlo failed to complete inventory: TimedPromise timeout
        2021-10-01T04:02:55.018Z <EzloController:CRIT> !TimedPromise timeout
        2021-10-01T04:02:55.025Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1002
        2021-10-01T04:02:56.933Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:56.933Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:56.933Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:56.934Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:56.934Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:02:58.144Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:58.144Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:02:58.144Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:58.145Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:02:58.145Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:03:00.003Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 1ms and returned 22 entities
        2021-10-01T04:03:00.005Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:03:00.015Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 1ms and returned 22 entities
        2021-10-01T04:03:00.016Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
        2021-10-01T04:03:00.025Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
        2021-10-01T04:03:00.025Z <EzloController:INFO> EzloController#ezlo opening hub connection to "XXXXXXXX" at wss://192.168.1.100:17000
        2021-10-01T04:03:00.025Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.1.100:17000
        2021-10-01T04:03:00.110Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://192.168.1.100:17000)
        2021-10-01T04:03:00.110Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-10-01T04:03:13.125Z <Engine:5:Engine.js:1083> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:03:13.125Z <Engine:5:Engine.js:1083> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
        2021-10-01T04:03:13.126Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_30005) ctx=global
        2021-10-01T04:03:13.126Z <Engine:5:Engine.js:942> Engine#1 getEntity(vera>device_52) ctx=global
        2021-10-01T04:03:15.112Z <EzloController:ERR> EzloController#ezlo request "17c3a05058e" (hub.info.get) failed: TimedPromise timeout
        2021-10-01T04:03:15.113Z <EzloController:ERR> EzloController#ezlo failed to complete inventory: TimedPromise timeout
        2021-10-01T04:03:15.113Z <EzloController:CRIT> !TimedPromise timeout
        2021-10-01T04:03:15.117Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1002
        2021-10-01T04:03:15.119Z <EzloController:ERR> Controller EzloController#ezlo is off-line!
        2021-10-01T04:03:15.129Z <Rule:INFO> Notifiering - Ezlo status (Rule#rule-ktsucjh1) SET!
        2021-10-01T04:03:15.132Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:03:15.132Z <Engine:INFO> Enqueueing "Notifiering - Ezlo status<SET>" (rule-ktsucjh1:S)
        2021-10-01T04:03:15.133Z <Engine:5:Engine.js:1219> Engine#1 enqueued reaction rule-ktsucjh1:S as 432
        2021-10-01T04:03:15.133Z <Engine:5:Engine.js:1359> _process_reaction_queue() ending with 1 in queue; waiting for 1633060995133<10/1/2021, 6:03:15 AM> (next delayed task)
        2021-10-01T04:03:15.144Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
        2021-10-01T04:03:15.145Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 432 { "tid": 432, "id": "rule-ktsucjh1:S", "rule": "rule-ktsucjh1", "__reaction": [RuleReaction#rule-ktsucjh1:S], "next_step": 0, "status": 0, "ts": 1633060995132, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-10-01T04:03:15.145Z <Engine:NOTICE> Starting reaction Notifiering - Ezlo status<SET> (rule-ktsucjh1:S)
        2021-10-01T04:03:15.145Z <Engine:5:Engine.js:1470> Engine#1 reaction rule-ktsucjh1:S step 0 notify Pushover with { "message": "Ezlo Plus svarar inte, troligen nere.", "profile": "MSR", "title": "Ezlo Plus nere!", "priority": "0" }
        2021-10-01T04:03:15.145Z <NotifyPushover:5:NotifyPushover.js:228> NotifyPushover sending profile MSR notification request: Ezlo Plus svarar inte, troligen nere.
        2021-10-01T04:03:15.146Z <Engine:INFO> Notifiering - Ezlo status<SET> all actions completed.
        2021-10-01T04:03:15.146Z <Engine:5:Engine.js:1324> _process_reaction_queue() task returned, new status -1; task 432
        2021-10-01T04:03:15.147Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
        2021-10-01T04:03:16.289Z <NotifyPushover:5:NotifyPushover.js:236> NotifyPushover successful endpoint exchange (message sent)
        2021-10-01T04:03:20.122Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
        2021-10-01T04:03:20.123Z <EzloController:INFO> EzloController#ezlo opening hub connection to "XXXXXXXX" at wss://192.168.1.100:17000
        2021-10-01T04:03:20.124Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.1.100:17000
        2021-10-01T04:03:20.214Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://192.168.1.100:17000)
        2021-10-01T04:03:20.214Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-10-01T04:03:20.456Z <EzloController:INFO> EzloController#ezlo hub "XXXXXXXX" is h2.1 (undefined) firmware "2.0.19.1714.2"
        2021-10-01T04:03:20.489Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: RangeError: Maximum call stack size exceeded
        2021-10-01T04:03:20.490Z <EzloController:CRIT> RangeError: Maximum call stack size exceeded
            at EzloController._now.ws_message [as refreshTime] (/home/username/reactor/server/lib/EzloController.js:1136:43)
            at EzloController._now.ws_message [as refreshTime] (/home/username/reactor/server/lib/EzloController.js:1138:54)
        2021-10-01T04:03:35.461Z <EzloController:ERR> EzloController#ezlo request "17c3a05550c" ({ "method": "hub.modes.get", "api": "2.0" }) failed: TimedPromise timeout
        2021-10-01T04:03:35.462Z <EzloController:ERR> EzloController#ezlo failed to complete inventory: TimedPromise timeout
        2021-10-01T04:03:35.462Z <EzloController:CRIT> !TimedPromise timeout
        2021-10-01T04:03:35.468Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1002
        2021-10-01T04:03:40.474Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
        2021-10-01T04:03:40.474Z <EzloController:INFO> EzloController#ezlo opening hub connection to "XXXXXXXX" at wss://192.168.1.100:17000
        2021-10-01T04:03:40.475Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.1.100:17000
        2021-10-01T04:03:40.563Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://192.168.1.100:17000)
        2021-10-01T04:03:40.563Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-10-01T04:03:40.596Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: RangeError: Maximum call stack size exceeded
        2021-10-01T04:03:40.597Z <EzloController:CRIT> RangeError: Maximum call stack size exceeded
        RangeError: Maximum call stack size exceeded...
          The Set Variable issue is specific to Vera controllers only and does not apply to eZLO or any other.
          The variable hm associated with rule Notifiering - House mode (Rule#rule-ksw26xod): can you tell me if that's a rule variable, or a global variable?
            @toggledbits Yes, in one of the rules I set the openLuup house mode via house mode plugin to push the mode to my Vera (That is otherwise primary for openLuup's house mode).
            The variable hm is an old test I did and does no longer exist and is not referenced anywhere visible to me?
              Variables hm and HouseMode both are referenced somewhere, but appear to not be global. If you don't see hm in the list of global variables, it's probably buried in a rule somewhere. What about HouseMode? Global or rule?
                @toggledbits After going through every Rule Set I have, I deleted the global HouseMode hours before I got this error since it was not referenced anywhere.
                hm was a local in Notifiering - House mode (Rule#rule-ksw26xod) but was replaced weeks ago with a new local named housemode
                This rule has been untouched for weaks and never failed, the thing I changed yesterday was the Trigger from housemode plugin to vera>housemode since it seems you fixed the housemode change issue from openLuup and native is snappier than the polling plugin.
                  OK. Great detail. That helps, thank you. Let me see what I can do here...
                    @toggledbits I'm still having some problem with variables being referenced when deleted. Looks like the Engine is looking for an old global expression (undefined)? that I think I had a time ago with matchEntities
                    and
                    @ 2021-10-04T14:11:00.003Z
                    This rule triggers: Rule:INFO Notifiering - Ezlo devices (Rule#rule-ku32xyj5) SET!
                    I've now put a sustianed for 3 secs on the first variable trigger to ignore flapping.
                    None of the other rules triggered in the log snippet has any local expression or referenced global expressions and the "Error: Object does not exist" is present from:
                    2021-10-04T10:31:08.900Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:31:08.901Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:31:08.905Z <Engine:5:Engine.js:948> Engine#1 set global Medeltemp; value=(number)22
                    2021-10-04T10:31:08.908Z <Engine:5:Engine.js:948> Engine#1 set global Luftfuktighet; value=(number)0.8148148148148148
                    2021-10-04T10:31:10.074Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:31:10.075Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:31:25.061Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:31:25.061Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:00.014Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                    2021-10-04T10:32:00.027Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                    2021-10-04T10:32:09.094Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:09.095Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:10.297Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:10.297Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:24.996Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:32:24.996Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:00.002Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                    2021-10-04T10:33:00.015Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                    2021-10-04T10:33:09.142Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:09.143Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:09.148Z <Engine:5:Engine.js:948> Engine#1 set global Luftfuktighet; value=(number)0.7901234567901234
                    2021-10-04T10:33:10.387Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:10.388Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:25.394Z <Engine:5:Engine.js:1108> Engine#1 var Medeltemp dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:25.394Z <Engine:5:Engine.js:1108> Engine#1 var Luftfuktighet dependency entity-changed Entity#vera>device_30005
                    2021-10-04T10:33:30.894Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a0373129e0715cf4a765f
                    2021-10-04T10:33:30.897Z <default:CRIT> Error: Object does not exist
                        at Function.getInstance (/home/homebridge/reactor/server/lib/GlobalExpression.js:130:27)
                        at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1109:59)
                        at /home/homebridge/reactor/server/lib/MessageBus.js:99:208
                        at MessageBus._sendToBus (/home/homebridge/reactor/server/lib/MessageBus.js:96:47)
                        at /home/homebridge/reactor/server/lib/MessageBus.js:109:48
                        at new Promise (<anonymous>)
                        at MessageBus.send (/home/homebridge/reactor/server/lib/MessageBus.js:106:16)
                        at Entity.publish (/home/homebridge/reactor/server/lib/Observable.js:71:44)
                        at Entity.deferNotifies (/home/homebridge/reactor/server/lib/Entity.js:248:207)
                    Where everything above the error is just repeating.
                    Log from rule SET in next post...
                    • CrilleC Crille
                      and
                      First lines looks interesting
                      2021-10-04T14:10:33.692Z <EzloController:WARN> EzloController#ezlo warning: update parameter serviceNotification for Entity#ezlo>device_603a0367129e0715cf4a7604 not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:33.693Z <EzloController:WARN> EzloController#ezlo warning: update parameter syncNotification for Entity#ezlo>device_603a0367129e0715cf4a7604 not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:33.694Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a0367129e0715cf4a7604
                      2021-10-04T14:10:33.697Z <default:CRIT> Error: Object does not exist
                          at Function.getInstance (/home/username/reactor/server/lib/GlobalExpression.js:130:27)
                          at Engine._expr_dependency (/home/username/reactor/server/lib/Engine.js:1109:59)
                          at /home/username/reactor/server/lib/MessageBus.js:99:208
                          at MessageBus._sendToBus (/home/username/reactor/server/lib/MessageBus.js:96:47)
                          at /home/username/reactor/server/lib/MessageBus.js:109:48
                          at MessageBus.send (/home/username/reactor/server/lib/MessageBus.js:106:16)
                          at Entity.publish (/home/username/reactor/server/lib/Observable.js:71:44)
                          at Entity.deferNotifies (/home/username/reactor/server/lib/Entity.js:248:207)
                      2021-10-04T14:10:35.317Z <EzloController:WARN> EzloController#ezlo warning: update parameter serviceNotification for Entity#ezlo>device_603a036a129e0715cf4a761d not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:35.318Z <EzloController:WARN> EzloController#ezlo warning: update parameter syncNotification for Entity#ezlo>device_603a036a129e0715cf4a761d not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:35.318Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036a129e0715cf4a761d
                      2021-10-04T14:10:35.318Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:10:35.439Z <EzloController:WARN> EzloController#ezlo warning: update parameter serviceNotification for Entity#ezlo>device_6107edd0129e071241a25469 not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:35.439Z <EzloController:WARN> EzloController#ezlo warning: update parameter syncNotification for Entity#ezlo>device_6107edd0129e071241a25469 not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:35.440Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_6107edd0129e071241a25469
                      2021-10-04T14:10:35.440Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:10:39.201Z <EzloController:WARN> EzloController#ezlo warning: update parameter serviceNotification for Entity#ezlo>device_603a60dc129e071231a7f95e not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:39.201Z <EzloController:WARN> EzloController#ezlo warning: update parameter syncNotification for Entity#ezlo>device_603a60dc129e071231a7f95e not previously defined! (value now (boolean)false)
                      2021-10-04T14:10:39.203Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a60dc129e071231a7f95e
                      2021-10-04T14:10:39.205Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:11:00.002Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                      2021-10-04T14:11:00.003Z <Rule:INFO> Notifiering - Ezlo devices (Rule#rule-ku32xyj5) SET!
                      2021-10-04T14:11:00.005Z <Engine:5:Engine.js:1386> _process_reaction_queue() wake-up!
                      2021-10-04T14:11:00.005Z <Engine:INFO> Enqueueing "Notifiering - Ezlo devices<SET>" (rule-ku32xyj5:S)
                      2021-10-04T14:11:00.006Z <Engine:5:Engine.js:1246> Engine#1 enqueued reaction rule-ku32xyj5:S as 70
                      2021-10-04T14:11:00.006Z <Engine:5:Engine.js:1386> _process_reaction_queue() ending with 1 in queue; waiting for 1633356660006<10/4/2021, 4:11:00 PM> (next delayed task)
                      2021-10-04T14:11:00.013Z <Engine:INFO> Engine#1 matchEntities({ "controller": [ "ezlo" ], "capability": [ "x_ezlo_device" ], "group": [  ] }) took 0ms and returned 22 entities
                      2021-10-04T14:11:00.014Z <Rule:INFO> Notifiering - Ezlo devices (Rule#rule-ku32xyj5) RESET!
                      2021-10-04T14:11:00.015Z <Engine:5:Engine.js:1386> _process_reaction_queue() wake-up!
                      2021-10-04T14:11:00.015Z <Engine:5:Engine.js:1347> _process_reaction_queue() running task 70 { "tid": 70, "id": "rule-ku32xyj5:S", "rule": "rule-ku32xyj5", "__reaction": [RuleReaction#rule-ku32xyj5:S], "next_step": 0, "status": 0, "ts": 1633356660005, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "halt": true }
                      2021-10-04T14:11:00.015Z <Engine:INFO> Halting reaction Notifiering - Ezlo devices<SET> (rule-ku32xyj5:S) at step 0
                      2021-10-04T14:11:00.016Z <Engine:NOTICE> Handling reaction halt request for Notifiering - Ezlo devices<SET> at step 0
                      2021-10-04T14:11:00.016Z <Engine:5:Engine.js:1351> _process_reaction_queue() task returned, new status -1; task 70
                      2021-10-04T14:11:00.016Z <Engine:NOTICE> Engine#1 entry 70 reaction rule-ku32xyj5:S: terminated
                      2021-10-04T14:11:00.016Z <Engine:CRIT> !terminated
                      2021-10-04T14:11:00.017Z <Engine:5:Engine.js:1386> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
                      2021-10-04T14:11:00.021Z <Engine:INFO> Enqueueing "Notifiering - Ezlo devices<RESET>" (rule-ku32xyj5:R)
                      2021-10-04T14:11:00.021Z <Engine:5:Engine.js:1246> Engine#1 enqueued reaction rule-ku32xyj5:R as 71
                      2021-10-04T14:11:00.021Z <Engine:5:Engine.js:1386> _process_reaction_queue() wake-up!
                      2021-10-04T14:11:00.022Z <Engine:5:Engine.js:1347> _process_reaction_queue() running task 71 { "tid": 71, "id": "rule-ku32xyj5:R", "rule": "rule-ku32xyj5", "__reaction": [RuleReaction#rule-ku32xyj5:R], "next_step": 0, "status": 0, "ts": 1633356660021, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
                      2021-10-04T14:11:00.022Z <Engine:NOTICE> Starting reaction Notifiering - Ezlo devices<RESET> (rule-ku32xyj5:R)
                      2021-10-04T14:11:00.023Z <Engine:5:Engine.js:1496> Engine#1 reaction rule-ku32xyj5:R step 0 notify Pushover with { "message": "Alla enheter svarar igen.", "profile": "MSR", "title": "Ezlo-enheter svarar igen.", "priority": "0" }
                      2021-10-04T14:11:00.023Z <NotifyPushover:5:NotifyPushover.js:216> NotifyPushover sending profile MSR notification request: Alla enheter svarar igen.
                      2021-10-04T14:11:00.024Z <Engine:INFO> Notifiering - Ezlo devices<RESET> all actions completed.
                      2021-10-04T14:11:00.024Z <Engine:5:Engine.js:1351> _process_reaction_queue() task returned, new status -1; task 71
                      2021-10-04T14:11:00.025Z <Engine:5:Engine.js:1386> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
                      2021-10-04T14:11:00.647Z <NotifyPushover:5:NotifyPushover.js:224> NotifyPushover successful endpoint exchange (message sent)
                      2021-10-04T14:11:03.822Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036e129e0715cf4a763e
                      2021-10-04T14:11:03.825Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:11:03.828Z <Rule:INFO> Tänd i Källaren beroende på Ljus (Rule#rule-kmuwu2tk) RESET!
                      2021-10-04T14:11:03.835Z <Engine:5:Engine.js:1386> _process_reaction_queue() wake-up!
                      2021-10-04T14:11:03.836Z <Engine:INFO> Enqueueing "Tänd i Källaren beroende på Ljus<RESET>" (rule-kmuwu2tk:R)
                      2021-10-04T14:11:03.837Z <Engine:5:Engine.js:1246> Engine#1 enqueued reaction rule-kmuwu2tk:R as 72
                      2021-10-04T14:11:03.838Z <Engine:5:Engine.js:1386> _process_reaction_queue() ending with 1 in queue; waiting for 1633356663837<10/4/2021, 4:11:03 PM> (next delayed task)
                      2021-10-04T14:11:03.840Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036e129e0715cf4a763a
                      2021-10-04T14:11:03.842Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:11:03.845Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036e129e0715cf4a763a
                      2021-10-04T14:11:03.848Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:11:03.850Z <Engine:5:Engine.js:1386> _process_reaction_queue() wake-up!
                      2021-10-04T14:11:03.851Z <Engine:5:Engine.js:1347> _process_reaction_queue() running task 72 { "tid": 72, "id": "rule-kmuwu2tk:R", "rule": "rule-kmuwu2tk", "__reaction": [RuleReaction#rule-kmuwu2tk:R], "next_step": 0, "status": 0, "ts": 1633356663836, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
                      2021-10-04T14:11:03.852Z <Engine:NOTICE> Starting reaction Tänd i Källaren beroende på Ljus<RESET> (rule-kmuwu2tk:R)
                      2021-10-04T14:11:03.852Z <Engine:5:Engine.js:1416> Engine#1 reaction rule-kmuwu2tk:R handling group rule-kmuwu2tk:R-7pjfxee constraints state true
                      2021-10-04T14:11:03.852Z <Engine:5:Engine.js:1418> Engine#1 constraints OK for reaction rule-kmuwu2tk:R group rule-kmuwu2tk:R-7pjfxee, queueing
                      2021-10-04T14:11:03.853Z <Engine:5:Engine.js:1430> Engine#1 reaction rule-kmuwu2tk:R group rule-kmuwu2tk:R-7pjfxee enqueued, waiting for completion
                      2021-10-04T14:11:03.853Z <Engine:5:Engine.js:1351> _process_reaction_queue() task returned, new status 3; task 72
                      2021-10-04T14:11:03.855Z <Engine:5:Engine.js:1246> Engine#1 enqueued reaction rule-kmuwu2tk:R-7pjfxee as 73
                      2021-10-04T14:11:03.856Z <Engine:5:Engine.js:1386> _process_reaction_queue() ending with 2 in queue; waiting for 1633356663855<10/4/2021, 4:11:03 PM> (next delayed task)
                      2021-10-04T14:11:03.856Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036e129e0715cf4a763a
                      2021-10-04T14:11:03.857Z <default:CRIT> Error: Object does not exist
                      2021-10-04T14:11:03.858Z <Engine:5:Engine.js:1108> Engine#1 var (undefined) dependency entity-changed Entity#ezlo>device_603a036e129e0715cf4a763a
                      2021-10-04T14:11:03.859Z <default:CRIT> Error: Object does not exist
                        Is this on 21275?
                          Is this on 21275?
                          @toggledbits Sorry, yes. latest-21275-df3d784
                            OK. I think I see this. I was at least able to reproduce one case. It's not to do with deleting global variables, or global variables at all, really; it. It has to do with the subcontexts that are created by lexpjs in each statements, and the MSR Engine looking for private data in the current context and not realizing that it was operating from a subcontext. And in this case, it was your rule expression that exposed the problem. Sounds messy, but not hard to fix. I think.
                            Build coming later today.
                            FYI, just an observation on what you're doing in this rule expression:
                            join(each name in (each id in (matchEntities( { controller: 'ezlo', capability: 'x_ezlo_device' } )):
                                getEntity( id ).attributes.x_ezlo_device.reachable == false ? id : null ):
                                    getEntity( name ).name, ', ' )
                            If you use a compound statement (do...done) as the body of a single each loop, and store the getEntity() result in a temporary variable, you only need one loop, it looks a bit cleaner, and runs a lot faster (because you're only fetching the entity once):
                            join(
                              each id in matchEntities( { controller: 'ezlo', capability: 'x_ezlo_device' } ): do
                                e=getEntity( id ),
                                e.attributes.x_ezlo_device.reachable ? null : e.name
                              done, ", " )
                            This compound statement loop first stores the result of getEntity() into a variable e. This variable, since it is being defined by the loop, can only be used within the loop. But, as you can see on the next line, it can be used both to make the reachable test, and to return name as the loop body result for each. Also note that since the reachable attribute is already a boolean, you can use it directly (without a comparison against another boolean), you just need to reverse the ternary operands (so when reachable is true, null is returned, and when not reachable, the entity name is returned).
                              join(
                                  e=getEntity( id ),
                                done, ", " )
                              @toggledbits Ok, great explanation!
                              I do like cleaner expressions and will absolutely switch to do...done, thank you for the example.
                              I knew it was doing double gets but each run took 0ms so I did not bother, but optimization is always welcomed.
                              FYI: I have some devices paired that are not usable yet and they return x_ezlo_device.reachable=null so until they are integrated correctly I'll keep the boolean comparison for now.
                              • N Offline
                                N Offline
                                wrote on last edited by noelab
                                Hi, updated MSR latest-21281-c4807c0
                                I have connection with ezloplus in set_anonymous_access: true
                                MSR starts to be connected and disconnected.
                                Ezlo is not connected
                                sys_system.state=false
                                [latest-21281]2021-10-08T20:29:30.398Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                [latest-21281]2021-10-08T20:29:33.849Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                [latest-21281]2021-10-08T20:29:33.850Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                [latest-21281]2021-10-08T20:29:33.850Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                [latest-21281]2021-10-08T20:29:38.850Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                [latest-21281]2021-10-08T20:29:38.851Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                [latest-21281]2021-10-08T20:29:38.851Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                [latest-21281]2021-10-08T20:29:59.226Z <Structure:WARN> Structure#1 promiseEntity(ezlo>housemode,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.227Z <Rule:CRIT> Rule#rule-ks210svp failed subscription to ezlo>housemode
                                [latest-21281]2021-10-08T20:29:59.227Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.251Z <Structure:WARN> Structure#1 promiseEntity(ezlo>housemode,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.251Z <Rule:CRIT> Rule#rule-ks210svp failed subscription to ezlo>housemode
                                [latest-21281]2021-10-08T20:29:59.252Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.252Z <Rule:5:Rule.js:704> Rule#rule-ks210svp start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.252Z <Rule:5:Rule.js:982> Rule#rule-ks210svp (v0 Function DayMode OverNight) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.252Z <Rule:5:Rule.js:986> Rule#rule-ks210svp._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.253Z <Rule:5:Rule.js:990> Rule#rule-ks210svp update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.253Z <Rule:5:Rule.js:914> Rule#rule-ks210svp evaluateExpressions() with 0 expressions
                                [latest-21281]2021-10-08T20:29:59.254Z <Rule:5:Rule.js:1002> Rule#rule-ks210svp._evaluate() trigger state now false (was false)
                                [latest-21281]2021-10-08T20:29:59.259Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>housemode
                                    at Rule._evaluateCondition (/opt/reactor/server/lib/Rule.js:1294:27)
                                    at Rule._evaluateGroup (/opt/reactor/server/lib/Rule.js:1658:99)
                                    at Rule._evaluateCondition (/opt/reactor/server/lib/Rule.js:1283:47)
                                    at Rule._evaluateConstraints (/opt/reactor/server/lib/Rule.js:1689:42)
                                    at Rule._evaluate (/opt/reactor/server/lib/Rule.js:1003:55)
                                    at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                    at async /opt/reactor/server/lib/Rule.js:969:17
                                [latest-21281]2021-10-08T20:29:59.261Z <Structure:WARN> Structure#1 promiseEntity(ezlo>device_613e233f129e2912114c0941,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.262Z <Rule:CRIT> Rule#rule-ktmit785 failed subscription to ezlo>device_613e233f129e2912114c0941
                                [latest-21281]2021-10-08T20:29:59.262Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.262Z <Rule:5:Rule.js:704> Rule#rule-ktmit785 start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.262Z <Rule:5:Rule.js:982> Rule#rule-ktmit785 (vT DLT 1 Bulb ID ) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.263Z <Rule:5:Rule.js:986> Rule#rule-ktmit785._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.263Z <Rule:5:Rule.js:990> Rule#rule-ktmit785 update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.263Z <Rule:5:Rule.js:914> Rule#rule-ktmit785 evaluateExpressions() with 0 expressions
                                [latest-21281]2021-10-08T20:29:59.279Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>device_613e233f129e2912114c0941
                                    at Rule._evaluateTriggers (/opt/reactor/server/lib/Rule.js:1675:38)
                                    at Rule._evaluate (/opt/reactor/server/lib/Rule.js:1001:55)
                                [latest-21281]2021-10-08T20:29:59.280Z <Structure:WARN> Structure#1 promiseEntity(ezlo>device_613e2b02129e2912114c0993,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.280Z <Rule:CRIT> Rule#rule-kthqmgb6 failed subscription to ezlo>device_613e2b02129e2912114c0993
                                [latest-21281]2021-10-08T20:29:59.280Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.280Z <Rule:5:Rule.js:704> Rule#rule-kthqmgb6 start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.281Z <Rule:5:Rule.js:982> Rule#rule-kthqmgb6 (vR4 DLT 1 Bulb ID ) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.281Z <Rule:5:Rule.js:986> Rule#rule-kthqmgb6._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.281Z <Rule:5:Rule.js:990> Rule#rule-kthqmgb6 update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.282Z <Rule:5:Rule.js:914> Rule#rule-kthqmgb6 evaluateExpressions() with 0 expressions
                                [latest-21281]2021-10-08T20:29:59.284Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>device_613e2b02129e2912114c0993
                                    at runNextTicks (internal/process/task_queues.js:64:3)
                                    at listOnTimeout (internal/timers.js:526:9)
                                    at processTimers (internal/timers.js:500:7)
                                [latest-21281]2021-10-08T20:29:59.285Z <Structure:WARN> Structure#1 promiseEntity(ezlo>device_613e2959129e2912114c098f,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.285Z <Rule:CRIT> Rule#rule-kthqpda8 failed subscription to ezlo>device_613e2959129e2912114c098f
                                [latest-21281]2021-10-08T20:29:59.286Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.286Z <Rule:5:Rule.js:704> Rule#rule-kthqpda8 start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.286Z <Rule:5:Rule.js:982> Rule#rule-kthqpda8 (vR4 DLT 3 Lux ID  ) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.287Z <Rule:5:Rule.js:986> Rule#rule-kthqpda8._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.287Z <Rule:5:Rule.js:990> Rule#rule-kthqpda8 update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.287Z <Rule:5:Rule.js:914> Rule#rule-kthqpda8 evaluateExpressions() with 1 expressions
                                [latest-21281]2021-10-08T20:29:59.290Z <Rule:ERR> Rule#rule-kthqpda8: error evaluating expression test: TypeError: Cannot read property 'log' of null
                                [latest-21281]2021-10-08T20:29:59.290Z <Rule:ERR> Rule#rule-kthqpda8: expression: round((abs(int( getEntity( "ezlo>device_613e2959129e2912114c098f" ).attributes.light_sensor.value ) * (100/300) -100) - int((  getEntity( "ezlo>device_613e2959129e2912114c098f" ).attributes.light_sensor.value  * (100/300) ) - 100))/2)
                                [latest-21281]2021-10-08T20:29:59.291Z <Rule:CRIT> TypeError: Cannot read property 'log' of null
                                    at _0x2f8d77 (/opt/reactor/server/lib/Engine.js:984:21)
                                    at _run (/opt/reactor/common/lexp.js:1383:34)
                                    at _run (/opt/reactor/common/lexp.js:1338:33)
                                    at /opt/reactor/common/lexp.js:1381:33
                                    at _run (/opt/reactor/common/lexp.js:1380:28)
                                    at _run (/opt/reactor/common/lexp.js:1208:34)
                                [latest-21281]2021-10-08T20:29:59.295Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>device_613e2959129e2912114c098f
                                [latest-21281]2021-10-08T20:29:59.296Z <Structure:WARN> Structure#1 promiseEntity(ezlo>device_613e2959129e2912114c0982,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.296Z <Rule:CRIT> Rule#rule-kthqljcu failed subscription to ezlo>device_613e2959129e2912114c0982
                                [latest-21281]2021-10-08T20:29:59.296Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.296Z <Rule:5:Rule.js:704> Rule#rule-kthqljcu start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.297Z <Rule:5:Rule.js:982> Rule#rule-kthqljcu (vR4 DLT 2 Motion ID ) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.297Z <Rule:5:Rule.js:986> Rule#rule-kthqljcu._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.297Z <Rule:5:Rule.js:990> Rule#rule-kthqljcu update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.297Z <Rule:5:Rule.js:914> Rule#rule-kthqljcu evaluateExpressions() with 0 expressions
                                [latest-21281]2021-10-08T20:29:59.299Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>device_613e2959129e2912114c0982
                                [latest-21281]2021-10-08T20:29:59.300Z <Structure:WARN> Structure#1 promiseEntity(ezlo>device_614e0c2f129e29124dfcd825,30000) timeout!
                                [latest-21281]2021-10-08T20:29:59.300Z <Rule:CRIT> Rule#rule-ktpv9g18 failed subscription to ezlo>device_614e0c2f129e29124dfcd825
                                [latest-21281]2021-10-08T20:29:59.300Z <Rule:CRIT> !timeout
                                [latest-21281]2021-10-08T20:29:59.301Z <Rule:5:Rule.js:704> Rule#rule-ktpv9g18 start() dependencies resolved, performing initial evaluation
                                [latest-21281]2021-10-08T20:29:59.301Z <Rule:5:Rule.js:982> Rule#rule-ktpv9g18 (vR3 DLT 1 Bulb ID) evaluate() acquiring mutex
                                [latest-21281]2021-10-08T20:29:59.301Z <Rule:5:Rule.js:986> Rule#rule-ktpv9g18._evaluate() mutex acquired, evaluating
                                [latest-21281]2021-10-08T20:29:59.301Z <Rule:5:Rule.js:990> Rule#rule-ktpv9g18 update rate is 0/min limit 60/min
                                [latest-21281]2021-10-08T20:29:59.301Z <Rule:5:Rule.js:914> Rule#rule-ktpv9g18 evaluateExpressions() with 0 expressions
                                [latest-21281]2021-10-08T20:29:59.304Z <Rule:CRIT> ReferenceError: Can't find entity ezlo>device_614e0c2f129e29124dfcd825
                                -Docker on Synology NAS
                                -HASS Docker 2026.8.1
                                -ZWaveJS-UI 11.22.3
                                -Update 16/08/2026
                                N 1 Reply Last reply
                                • N noelab
                                  N Offline
                                  N Offline
                                  @noelab
                                  [latest-21281]2021-10-08T20:37:59.635Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:38:06.565Z <Rule:5:Rule.js:763> Rule#rule-ks56pa4y dependency notification timer-trigger Timer#rule-ks56pa4y from Timer#rule-ks56pa4y
                                  [latest-21281]2021-10-08T20:38:06.566Z <Rule:5:Rule.js:769> Rule#rule-ks56pa4y requesting eval; timer-trigger Timer#rule-ks56pa4y
                                  [latest-21281]2021-10-08T20:38:06.566Z <Rule:5:Rule.js:982> Rule#rule-ks56pa4y (vK DLT 8 Delay OFF ) evaluate() acquiring mutex
                                  [latest-21281]2021-10-08T20:38:06.569Z <Rule:5:Rule.js:986> Rule#rule-ks56pa4y._evaluate() mutex acquired, evaluating
                                  [latest-21281]2021-10-08T20:38:06.570Z <Rule:5:Rule.js:990> Rule#rule-ks56pa4y update rate is 0/min limit 60/min
                                  [latest-21281]2021-10-08T20:38:06.570Z <Rule:5:Rule.js:914> Rule#rule-ks56pa4y evaluateExpressions() with 0 expressions
                                  [latest-21281]2021-10-08T20:38:06.571Z <Rule:5:Rule.js:1650> cond condcxc7czr evaluation state false->true
                                  [latest-21281]2021-10-08T20:38:06.576Z <Rule:5:Rule.js:1002> Rule#rule-ks56pa4y._evaluate() trigger state now false (was false)
                                  [latest-21281]2021-10-08T20:38:06.576Z <Rule:5:Rule.js:1004> Rule#rule-ks56pa4y._evaluate() constraints state true
                                  [latest-21281]2021-10-08T20:38:06.576Z <Rule:5:Rule.js:1013> Rule#rule-ks56pa4y rule state now false, changed no
                                  [latest-21281]2021-10-08T20:38:07.815Z <Rule:5:Rule.js:763> Rule#rule-ktrefqfy dependency notification timer-trigger Timer#rule-ktrefqfy from Timer#rule-ktrefqfy
                                  [latest-21281]2021-10-08T20:38:07.815Z <Rule:5:Rule.js:769> Rule#rule-ktrefqfy requesting eval; timer-trigger Timer#rule-ktrefqfy
                                  [latest-21281]2021-10-08T20:38:07.816Z <Rule:5:Rule.js:982> Rule#rule-ktrefqfy (vH DLT 8 Delay OFF  ) evaluate() acquiring mutex
                                  [latest-21281]2021-10-08T20:38:07.816Z <Rule:5:Rule.js:986> Rule#rule-ktrefqfy._evaluate() mutex acquired, evaluating
                                  [latest-21281]2021-10-08T20:38:07.816Z <Rule:5:Rule.js:990> Rule#rule-ktrefqfy update rate is 0/min limit 60/min
                                  [latest-21281]2021-10-08T20:38:07.816Z <Rule:5:Rule.js:914> Rule#rule-ktrefqfy evaluateExpressions() with 0 expressions
                                  [latest-21281]2021-10-08T20:38:07.817Z <Rule:5:Rule.js:1650> cond condcxc7czr evaluation state false->true
                                  [latest-21281]2021-10-08T20:38:07.818Z <Rule:5:Rule.js:1002> Rule#rule-ktrefqfy._evaluate() trigger state now false (was false)
                                  [latest-21281]2021-10-08T20:38:07.818Z <Rule:5:Rule.js:1004> Rule#rule-ktrefqfy._evaluate() constraints state true
                                  [latest-21281]2021-10-08T20:38:07.818Z <Rule:5:Rule.js:1013> Rule#rule-ktrefqfy rule state now false, changed no
                                  [latest-21281]2021-10-08T20:38:19.635Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:38:19.636Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:38:19.636Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:38:28.614Z <wsapi:WARN> wsapi: timed out waiting for ping reply (pong) from client "172.17.0.1#4"
                                  [latest-21281]2021-10-08T20:38:28.615Z <wsapi:INFO> client "172.17.0.1#4" closed, code=1006, reason=
                                  [latest-21281]2021-10-08T20:38:49.688Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:38:49.688Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:38:49.688Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:38:54.226Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:39:14.695Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:39:14.695Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:39:14.696Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:39:44.747Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:39:44.747Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:39:44.748Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:40:14.758Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:40:14.758Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:40:14.759Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:40:44.809Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:40:44.810Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:40:44.810Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:41:19.824Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:41:19.824Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:41:19.825Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:41:39.101Z <wsapi:WARN> wsapi: timed out waiting for ping reply (pong) from client "172.17.0.1#5"
                                  [latest-21281]2021-10-08T20:41:39.102Z <wsapi:INFO> client "172.17.0.1#5" closed, code=1006, reason=
                                  [latest-21281]2021-10-08T20:41:49.876Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:41:49.876Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:41:49.876Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:42:29.878Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:42:29.879Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:42:29.879Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:42:59.931Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:42:59.931Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:42:59.931Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:43:44.942Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:43:44.942Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:43:44.943Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:44:14.994Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:44:14.994Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:44:14.994Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:44:33.693Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:44:35.025Z <wsapi:INFO> client "172.17.0.1#6" closed, code=1001, reason=
                                  [latest-21281]2021-10-08T20:44:54.281Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:45:04.999Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:45:04.999Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:45:05.000Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:45:35.050Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:45:35.051Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:45:35.051Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:46:30.052Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:46:30.052Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:46:30.053Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:46:34.315Z <wsapi:WARN> wsapi: timed out waiting for ping reply (pong) from client "172.17.0.1#7"
                                  [latest-21281]2021-10-08T20:46:34.316Z <wsapi:INFO> client "172.17.0.1#7" closed, code=1006, reason=
                                  [latest-21281]2021-10-08T20:46:46.206Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:47:00.103Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:47:00.103Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:47:00.104Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:47:11.581Z <wsapi:INFO> client "172.17.0.1#8" closed, code=1005, reason=
                                  [latest-21281]2021-10-08T20:47:14.206Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:48:00.114Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:48:00.115Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:48:00.115Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:48:30.167Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:48:30.167Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:48:30.168Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:49:30.169Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:49:30.169Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:49:30.170Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:50:00.221Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:50:00.221Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:50:00.221Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:50:24.385Z <wsapi:WARN> wsapi: timed out waiting for ping reply (pong) from client "172.17.0.1#9"
                                  [latest-21281]2021-10-08T20:50:24.386Z <wsapi:INFO> client "172.17.0.1#9" closed, code=1006, reason=
                                  [latest-21281]2021-10-08T20:50:27.211Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:51:00.225Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:51:00.225Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:51:00.226Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:51:22.359Z <wsapi:INFO> client "172.17.0.1#10" closed, code=1001, reason=
                                  [latest-21281]2021-10-08T20:51:22.848Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                                  [latest-21281]2021-10-08T20:51:30.276Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:51:30.277Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:51:30.277Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:52:30.279Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:52:30.279Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:52:30.280Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:53:00.331Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:53:00.331Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:53:00.331Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  [latest-21281]2021-10-08T20:54:00.338Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                  [latest-21281]2021-10-08T20:54:00.338Z <Controller:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:54:00.339Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                  [latest-21281]2021-10-08T20:54:30.006Z <Rule:5:Rule.js:763> Rule#rule-ktggia4q dependency notification entity-changed Entity#vera>device_719 from Entity#vera>device_719
                                  [latest-21281]2021-10-08T20:54:30.007Z <Rule:5:Rule.js:769> Rule#rule-ktggia4q requesting eval; entity-changed Entity#vera>device_719
                                  [latest-21281]2021-10-08T20:54:30.007Z <Rule:5:Rule.js:982> Rule#rule-ktggia4q (vB2 DLT 2 Motion ID) evaluate() acquiring mutex
                                  [latest-21281]2021-10-08T20:54:30.008Z <Rule:5:Rule.js:986> Rule#rule-ktggia4q._evaluate() mutex acquired, evaluating
                                  [latest-21281]2021-10-08T20:54:30.008Z <Rule:5:Rule.js:990> Rule#rule-ktggia4q update rate is 0/min limit 60/min
                                  [latest-21281]2021-10-08T20:54:30.008Z <Rule:5:Rule.js:914> Rule#rule-ktggia4q evaluateExpressions() with 0 expressions
                                  [latest-21281]2021-10-08T20:54:30.009Z <Rule:5:Rule.js:1002> Rule#rule-ktggia4q._evaluate() trigger state now false (was false)
                                  [latest-21281]2021-10-08T20:54:30.009Z <Rule:5:Rule.js:1004> Rule#rule-ktggia4q._evaluate() constraints state true
                                  [latest-21281]2021-10-08T20:54:30.009Z <Rule:5:Rule.js:1013> Rule#rule-ktggia4q rule state now false, changed no
                                  [latest-21281]2021-10-08T20:54:30.389Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                  [latest-21281]2021-10-08T20:54:30.390Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                  [latest-21281]2021-10-08T20:54:30.390Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                  -ZWaveJS-UI 11.22.3
                                  -Update 16/08/2026
                                    No changes to EzloController for several builds now. Mine is working great.
                                    What's your install environment?
                                    Log snippets need several dozen lines before the error in order to be useful. For controller connection issues, it's also good to capture the entire startup until a bit past the first connection failure.
                                    • N Offline
                                      N Offline
                                      It's Docker on Synology
                                      [latest-21281]2021-10-08T21:17:51.677Z <app:null> Reactor latest-21281-c4807c0 starting on v14.17.3
                                      [latest-21281]2021-10-08T21:17:51.678Z <app:INFO> Process ID 1; platform linux/x64 #41890 SMP Thu Jul 15 03:37:40 CST 2021; locale (undefined)
                                      [latest-21281]2021-10-08T21:17:51.678Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
                                      [latest-21281]2021-10-08T21:17:51.679Z <app:INFO> NODE_PATH /opt/reactor
                                      [latest-21281]2021-10-08T21:17:51.691Z <app:INFO> Configured locale (undefined); selected locale(s) en-US.UTF-8
                                      [latest-21281]2021-10-08T21:17:51.746Z <app:INFO> Loaded locale en-US
                                      [latest-21281]2021-10-08T21:17:51.880Z <Plugin:null> Module Plugin v21173
                                      [latest-21281]2021-10-08T21:17:51.888Z <default:INFO> Module Entity v21260
                                      [latest-21281]2021-10-08T21:17:51.891Z <Controller:null> Module Controller v21278
                                      [latest-21281]2021-10-08T21:17:51.891Z <default:null> Module Structure v21270
                                      [latest-21281]2021-10-08T21:17:51.900Z <default:null> Module Ruleset v21096
                                      [latest-21281]2021-10-08T21:17:51.900Z <default:null> Module Rulesets v21096
                                      [latest-21281]2021-10-08T21:17:51.922Z <default:null> Module Rule v21278
                                      [latest-21281]2021-10-08T21:17:51.978Z <default:null> Module Engine v21277
                                      [latest-21281]2021-10-08T21:17:51.978Z <default:null> Module httpapi v21278
                                      [latest-21281]2021-10-08T21:17:51.987Z <default:null> Module httpproxy v21054
                                      [latest-21281]2021-10-08T21:17:52.004Z <default:null> Module wsapi v21274
                                      [latest-21281]2021-10-08T21:17:52.075Z <app:NOTICE> Starting Structure...
                                      [latest-21281]2021-10-08T21:17:52.079Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
                                      [latest-21281]2021-10-08T21:17:52.081Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                                      [latest-21281]2021-10-08T21:17:52.085Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
                                      [latest-21281]2021-10-08T21:17:52.086Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
                                      [latest-21281]2021-10-08T21:17:52.087Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                                      [latest-21281]2021-10-08T21:17:52.173Z <default:null> Module VeraController v21271
                                      [latest-21281]2021-10-08T21:17:52.180Z <default:null> Module EzloController v21274
                                      [latest-21281]2021-10-08T21:17:52.183Z <default:null> Module OWMWeatherController v21278
                                      [latest-21281]2021-10-08T21:17:52.184Z <default:null> Module SystemController v21102
                                      [latest-21281]2021-10-08T21:17:52.192Z <VeraController:NOTICE> VeraController#vera starting
                                      [latest-21281]2021-10-08T21:17:52.246Z <VeraController:INFO> VeraController#vera loaded mapping ver 21274 rev 1 format 1 notice
                                      [latest-21281]2021-10-08T21:17:52.247Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                                      [latest-21281]2021-10-08T21:17:52.295Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "XXXXXXXXXX" }
                                      [latest-21281]2021-10-08T21:17:52.295Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                                      [latest-21281]2021-10-08T21:17:52.314Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking...
                                      [latest-21281]2021-10-08T21:17:52.316Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                      [latest-21281]2021-10-08T21:17:52.346Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                                      [latest-21281]2021-10-08T21:17:52.374Z <Controller:INFO> EzloController#ezlo opening hub connection to "XXXXXXXXXX" at wss://10.0.4.119:17000
                                      [latest-21281]2021-10-08T21:17:52.376Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                      [latest-21281]2021-10-08T21:17:52.381Z <app:INFO> Structure running; pausing for controllers' initial ready
                                      [latest-21281]2021-10-08T21:17:52.632Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
                                      [latest-21281]2021-10-08T21:17:52.634Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                                      [latest-21281]2021-10-08T21:17:53.307Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                                      [latest-21281]2021-10-08T21:18:22.427Z <Controller:WARN> EzloController#ezlo websocket error during open/negotation: Error: WebSocket was closed before the connection was established
                                      [latest-21281]2021-10-08T21:18:22.428Z <Controller:ERR> EzloController#ezlo failed to connect websocket to wss://10.0.4.119:17000: TimedPromise timeout
                                      [latest-21281]2021-10-08T21:18:22.429Z <Controller:NOTICE> EzloController#ezlo websocket to wss://10.0.4.119:17000 closed during open/negotiation
                                      [latest-21281]2021-10-08T21:18:27.433Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                                      [latest-21281]2021-10-08T21:18:27.433Z <Controller:INFO> EzloController#ezlo opening hub connection to "XXXXXXXXXX" at wss://10.0.4.119:17000
                                      [latest-21281]2021-10-08T21:18:27.434Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                                      [latest-21281]2021-10-08T21:18:52.386Z <app:NOTICE> Starting HTTP server and API...
                                      [latest-21281]2021-10-08T21:18:52.392Z <app:NOTICE> Starting Reaction Engine...
                                      [latest-21281]2021-10-08T21:18:52.393Z <Engine:INFO> Reaction Engine starting
                                      [latest-21281]2021-10-08T21:18:52.393Z <Engine:INFO> Checking rule sets...
                                      [latest-21281]2021-10-08T21:18:52.445Z <Engine:INFO> Checking rules...
                                      [latest-21281]2021-10-08T21:18:52.446Z <Engine:INFO> Data check complete; no corrections.
                                      [latest-21281]2021-10-08T21:18:52.485Z <Engine:5:Engine.js:1350> _process_reaction_queue() entry 630
                                      [latest-21281]2021-10-08T21:18:52.500Z <Rule:5:Rule.js:623> Rule#rule-kuhickgs cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.501Z <Engine:5:Engine.js:886> Engine: new rule rule-kuhickgs ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.522Z <Rule:5:Rule.js:623> Rule#rule-ku1myjlz cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.522Z <Engine:5:Engine.js:886> Engine: new rule rule-ku1myjlz ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.534Z <Rule:5:Rule.js:623> Rule#rule-ks5pci0k cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.534Z <Engine:5:Engine.js:886> Engine: new rule rule-ks5pci0k ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.536Z <Rule:5:Rule.js:623> Rule#rule-ks5pdqcs cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.536Z <Engine:5:Engine.js:886> Engine: new rule rule-ks5pdqcs ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.537Z <Rule:5:Rule.js:623> Rule#rule-ks5pbeg9 cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.538Z <Engine:5:Engine.js:886> Engine: new rule rule-ks5pbeg9 ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.539Z <Rule:5:Rule.js:623> Rule#rule-ks5p8t6m cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.539Z <Engine:5:Engine.js:886> Engine: new rule rule-ks5p8t6m ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.540Z <Rule:5:Rule.js:623> Rule#rule-ks3j24qn cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.541Z <Engine:5:Engine.js:886> Engine: new rule rule-ks3j24qn ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.549Z <Rule:5:Rule.js:623> Rule#rule-ktrlog1t cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.549Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlog1t ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.550Z <Rule:5:Rule.js:623> Rule#rule-ktrlox2g cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.550Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlox2g ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.551Z <Rule:5:Rule.js:623> Rule#rule-ktrlp04x cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.552Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlp04x ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.553Z <Rule:5:Rule.js:623> Rule#rule-ktrlp2cn cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.553Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlp2cn ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.554Z <Rule:5:Rule.js:623> Rule#rule-ktrlp4il cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.555Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlp4il ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.556Z <Rule:5:Rule.js:623> Rule#rule-ktrlp6j9 cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.556Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlp6j9 ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.557Z <Rule:5:Rule.js:623> Rule#rule-ktrlp8v2 cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.557Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlp8v2 ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.558Z <Rule:5:Rule.js:623> Rule#rule-ktrlpbmt cleaning loaded condition states
                                      [latest-21281]2021-10-08T21:18:52.558Z <Engine:5:Engine.js:886> Engine: new rule rule-ktrlpbmt ((undefined)), creating!
                                      [latest-21281]2021-10-08T21:18:52.559Z <Rule:5:Rule.js:623> Rule#rule-ktrlpdzf cleaning loaded condition states
                                      -ZWaveJS-UI 11.22.3
                                      -Update 16/08/2026
                                        Huh. Docker container also working just fine for me, with authenticated access, with anonymous access, and with anonymous insecure access. What version of firmware is your hub? Have you tried to reboot the hub?
                                        • N Offline
                                          N Offline
                                          Now it's working again after I powered off/on ezlo controller and restarted Reactor. The log is too long, no privileges to upload it. It's not the first time it happens upgrating the container.
                                          ezloplus Firmware: 2.0.19.1714.2
                                          Thanks anyway.
                                          [latest-21281]2021-10-08T21:55:33.176Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 837ms
                                          [latest-21281]2021-10-08T21:55:33.179Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
                                          -ZWaveJS-UI 11.22.3
                                          -Update 16/08/2026
                                            157.7k
