  4. MSR on QNAP TS-321P
MSR on QNAP TS-321P
    Talisker
    I'm struggling to get MSR working in my QNAP (TS-321P). I am obviously not doing something correct in the setup, but cannot work out what. When I select 'Start' a second or so later the container stops. I get the following message in the container station - container tab 'standard_init_linux.go:219: exec user process caused: exec format error'. Assistance would be very much appreciated!
    MSR user on Raspberry PI 4. Running MSR version 26011 in Docker
      Probably best to start a new topic for this.
      The 321P is apparently ARM-based, 32-bit, not Intel/AMD 64-bit. First, which docker image are you trying?
        Talisker
        Thanks for setting up a new topic for my request.
        Firstly, I need to make a correction. My QNAP is a TS-231P. However you correct - its a Arm based 32 bit dual core processor.
        I am using 'latest-generic-amd64'. I guess 64 into 32 doesn't go!
          It's the Intel/AMD vs ARM that's the problem more than anything right now.
          Try latest-raspbian-armv7l... it may work.
            Talisker
            What do you know. It works. Well I still need to set up some Reactions to test it. Thanks.
              161.9k
              1.3k
