  3. Vera/openLuup plugins
  4. OpenSprinkler
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
OpenSprinkler
43 Posts 3 Posters 17.9k Views 3 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    The latest/working version of OpenSprinkler for openLuup, is it the one from @therealdb ?
    • DesTD Offline
      DesTD Offline
      DesT
      openLuup.context_switch::  ERROR: [dev #813] ./L_VeraOpenSprinkler1.lua:455: attempt to index local 'jsonResponse' (a nil value)
        Hey @DesT, is this the GitHub version?
        the error is on the status update.
        can you please call yourPI/jc command and post the results?
        Also, set DebugMode to 1 and post some logs to understand if commands are sent correctly.
        DesTD 1 Reply Last reply
          DesTD Offline
          DesTD Offline
          DesT
          @therealdb yeah latest version from github!
          {"fwv":219,"tz":32,"hp0":80,"hp1":0,"hwv":64,"ext":1,"sdt":0,"mas":0,"mton":0,"mtof":0,"wl":100,"den":1,"ipas":0,"devid":0,"uwt":0,"ntp1":50,"ntp2":97,"ntp3":210,"ntp4":169,"lg":1,"mas2":0,"mton2":0,"mtof2":0,"fwm":3,"fpr0":100,"fpr1":0,"re":0,"sar":1,"ife":0,"sn1t":1,"sn1o":0,"sn1on":0,"sn1of":0,"wimod":169,"reset":0,"dexp":-1,"mexp":24,"hwt":255}
            ok, working on it, since it's sending a different output.
            • DesTD Offline
              DesTD Offline
              DesT
              @therealdb any chance to work on that ? 😉
                Yep, I'll ask your for more logs tomorrow. Sorry, I've been busy with projects and outdoor activities, after mostly 70 days of lockdown.
                  DesTD Offline
                  DesTD Offline
                  DesT
                  @therealdb said in OpenSprinkler:
                  Feel the pain! We are in lockdown since March 15, and still in! We can only go out for essential stuff and for people that worked in essential service!
                    Yep, we can only visit family, so I spent the week-end with them. I live in a very low-Covid zones (less than 300 cases in 70 days in the entire region), but the lockdown was enforced in the whole country.
                    Having said that, please send me:
                    • the OS version/type you're running
                    • the output for ja (this is enough, I'm refactoring the code to just have this call, instead of separate ones)
                    A zip is somewhat OK (private too, if you don't want to share your own data).
                    I have an emulator to debug the plugin, so I can put them in my solution and see what's different from the OS version I have developed it against. Thanks!
                      Anyway, I just released a new version, with major refactoring in the logic. Give it a try, if it's not working, I could take a look at your response and fix it easily. Thanks!
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        2020-05-12 20:29:38.572   openLuup.scheduler:: [813] OpenSprinkler device startup
                        2020-05-12 20:29:38.572   luup_log:813: VeraOpenSprinkler Controller Plug-In starting...
                        2020-05-12 20:29:38.574   luup_log:813: VeraOpenSprinkler[1.3.0]: Plugin starting: "VeraOpenSprinkler" - "1.3.0"
                        2020-05-12 20:29:38.574   luup_log:813: VeraOpenSprinkler[1.3.0](nil@694): Running on OpenLuup: true
                        2020-05-12 20:29:38.574   luup_log:813: VeraOpenSprinkler[1.3.0](updateFromController@545): updateFromController started: true
                        2020-05-12 20:29:38.574   luup_log:813: VeraOpenSprinkler[1.3.0](sendDeviceCommand@241): sendDeviceCommand("ja",nil,813)
                        2020-05-12 20:29:38.575   luup_log:813: VeraOpenSprinkler[1.3.0](sendDeviceCommand@264): sendDeviceCommand - url: "http://10.99.99.16/ja?&pw=63df27a19d8f8c6669cc50ca042920cc"
                        2020-05-12 20:29:38.577   luup_log:813: VeraOpenSprinkler[1.3.0](nil@187): HttpGet: "http://10.99.99.16/ja?&pw=63df27a19d8f8c6669cc50ca042920cc" - 1 - "200" - "{\"settings\":{\"devt\":1589315378,\"nbrd\":2,\"en\":1,\"sn1\":0,\"sn2\":0,\"rd\":0,\"rdst\":0,\"sunrise\":329,\"sunset\":1217,\"eip\":1167972197,\"lwc\":1589302841,\"lswc\":1589302841,\"lupt\":0,\"lrbtc\":1,\"lrun\":[2,2,7200,1589266801],\"loc\":\"45.55855,-73.89608\",\"jsp\":\"https://ui.opensprinkler.com/js\",\"wsp\":\"weather.opensprinkler.com\",\"wto\":{\"key\":\"\"},\"ifkey\":\"\",\"wtdata\":{\"wp\":\"Manual\"},\"wterr\":0,\"sbits\":[128,0,0],\"ps\":[[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[1,34223,1589306401],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0]]},\"programs\":{\"nprogs\":4,\"nboards\":2,\"mnp\":40,\"mnst\":4,\"pnsize\":32,\"pd\":[[65,127,0,[1080,-1,-1,-1],[0,0,0,0,0,0,0,43200,0,0,0,0,0,0,0,0],\"Daily Cedars\"],[65,2,0,[180,-1,-1,-1],[7200,1200,7200,900,0,0,0,0,0,0,0,0,0,0,0,0],\"St-Eustache Rules AM\"],[64,127,0,[1170,-1,-1,-1],[0,0,0,0,0,0,0,0,600,0,0,0,0,0,0,0],\"Daily Garden\"],[0,109,0,[150,0,0,0],[0,600,2400,600,0,0,0,0,0,0,0,0,0,0,0,0],\"Quick daily\"]]},\"options\":{\"fwv\":219,\"tz\":32,\"hp0\":80,\"hp1\":0,\"hwv\":64,\"ext\":1,\"sdt\":0,\"mas\":0,\"mton\":0,\"mtof\":0,\"wl\":100,\"den\":1,\"ipas\":0,\"devid\":0,\"uwt\":0,\"ntp1\":50,\"ntp2\":97,\"ntp3\":210,\"ntp4\":169,\"lg\":1,\"mas2\":0,\"mton2\":0,\"mtof2\":0,\"fwm\":3,\"fpr0\":100,\"fpr1\":0,\"re\":0,\"sar\":1,\"ife\":0,\"sn1t\":1,\"sn1o\":0,\"sn1on\":0,\"sn1of\":0,\"wimod\":169,\"reset\":0,\"dexp\":-1,\"mexp\":24,\"hwt\":255},\"status\":{\"sn\":[0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0],\"nstations\":16}"
                        2020-05-12 20:29:38.578   luup_log:813: VeraOpenSprinkler[1.3.0](updateStatus@430): Update status in progress...
                        2020-05-12 20:29:38.578   openLuup.context_switch::  ERROR: [dev #813] ./L_VeraOpenSprinkler1.lua:434: attempt to index local 'jsonResponse' (a nil value)
                        2020-05-12 20:29:39.813   luup.variable_watch:: callback=variableWatchCallback, watching=20107.urn:micasaverde-com:serviceId:AlarmPartition2.ArmMode
                        Just update from github! And I can see all my child devices now!
                        • DesTD Offline
                          DesTD Offline
                          DesT
                          It will be nice to be able to choose in the config somewhere, which zone to use.
                          I'm using Zone 1, 2, 3, 4, 8, 9 and 16!
                            You should be able to hide zone/programs you don’t want to use.
                            Glad it’s working now!
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              Don't know why. I'm having a loop
                              Thu May 21 12:00:24 2020 device 813 'OpenSprinkler' requesting reload
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                I just upgrade my z-way from 3.0.0 to 3.0.6 and of course I reload openLuup to reconnect it to zway and since that, OpenSprinkler is in a loop!
                                  Can you please provide some logs?
                                    Also, enable verbose mode. Thanks.
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      @therealdb
                                      The only thing that came out just before the reload it's
                                      2020-05-24 08:02:00.939   luup_log:813: VeraOpenSprinkler[1.3.0](findChild@213): Cannot find child: 813 - "OS-WL-0"
                                      2020-05-24 08:02:00.939   luup_log:813: VeraOpenSprinkler[1.3.0](discovery@407): Device to be added
                                      2020-05-24 08:02:00.941   luup.chdev.sync:: [813] OpenSprinkler, syncing children
                                      2020-05-24 08:02:00.942   openLuup.luup:: device 813 'OpenSprinkler' requesting reload
                                      • DesTD DesT
                                        @therealdb
                                        @DesT ok, working on a fix. I will provide it soon.
                                          So, the problem is that it's missing the Water Level Device. @DesT, can you tell me if the there's a device, and if present, report its variables/attributes?
                                          Also, can you report Configured variable on the master? This should be 1 and the aforementioned code should not run. Maybe there's something setting it to 0 again. I can provide a new version using a proprietary variable service in order to prevent the Vera/Openluup subsystem from overriding it.
                                            152.5k
