  4. [SOLVED] Help required updating nodejs on Raspberry Pi 4B - Bare Metal (without Docker)
3 Posts 2 Posters 786 Views 2 Watching
  • J Offline
    J Offline
    jsimmo
    wrote on last edited by jsimmo
    I've recently updated to latest build 21332 and notice in the Readme file that I should update nodejs to 16.13.0 or higher before end of March. I've had a go at doing this, but think I've not done it correctly as I get the following responses in the terminal:
    pi@raspberrypi:~ $ node -v
    v14.17.0
    pi@raspberrypi:~ $ nodejs -v
    v16.13.0
    Is this correct? If not then what steps do I need to carry out to update nodejs properly.
    Any help from the group would be much appreciated.
      Yeah, not correct. I don't know what procedure you followed, but the install script (in tools) for the RPi is safe to run any time and will install an updated version for you. Log out and back in after updating.
      If you're already running Reactor under systemd, you will need to modify the path to the node binary in your /etc/systemd/system/reactor.service file, or copy the updated reactor.service file from the tools subdirectory to /etc/systemd/system (either requires root permissions).
      Kudos on the excellent topic title.
      • J Offline
        J Offline
        jsimmo
        I ran the install script again and nodejs is now updated to the latest version.
        v16.13.0
        I also copied the reactor.service file as advised and MSR is working fine.
        Thanks for your help
          339
          151.1k
