  4. Where is the package-lock.json file meant to be ?
6 Posts 2 Posters 1.0k Views 2 Watching
    To update packages, you must first remove any existing package-lock.json file from your Reactor install directory, and then run npm i --no-save --omit dev
    I can't see one in the main Reactor folder.
    So I searched the whole system, which found some of those files in various directories.
    Please advise.
    Thank you.
      The only package-lock.json file you should ever remove, unless told do so elsewhere, is the one in the Reactor install directory. And in fact, if you are doing the updates, correctly, that file will never be created in the Reactor install directory. If you omit the --no-save option, however, it will be created, so I give that instruction as a backup in case it has happened in the past.
      For other directories, the respective app/package maintainers will guide you on the lockfile.
        Thanks Yes I have been using the --no -save as per your previous instructions, so that must be why I don't have one in the Reactor install dir.
        I assume I am OK updating from my current version 22004-6d6c6b7 to Build 22025 also ?
          There is a package.json file in /home/stuart/reactor which is 2kb in size.
            Yes. It seems the teething pains caused by my refactoring of predicates have settled down.
            The package.json is a necessary file that tells npm what Reactor's dependencies are, so don't remove that one, just the one with -lock in its name.
              It seems to have updated OK, its now version 22025-26435e3
                157.7k
