  4. MSR Telegram Messages Stopped Working
5 Posts 4 Posters 1.9k Views 4 Watching
    Talisker
    wrote on last edited by Talisker
    My MSR has been working flawlessly until a couple of days ago when it stopped sending Telegram Messages (or should I say they stopped getting through!). I have updated to MSR version 22004. The reactor.log is updating and is showing no errors:
    [latest-22004]2022-05-15T17:52:31.417Z Engine:NOTICE Starting reaction Message Test (re-l37h2fkj)
    [latest-22004]2022-05-15T17:52:31.417Z Engine:INFO Message Test all actions completed.
    [latest-22004]2022-05-15T17:52:31.704Z Engine:INFO Enqueueing "Message Test" (re-l37h2fkj)
    [latest-22004]2022-05-15T17:52:31.735Z Engine:NOTICE Starting reaction Message Test (re-l37h2fkj)
    [latest-22004]2022-05-15T17:52:31.736Z Engine:INFO Message Test all actions completed.
    [latest-22004]2022-05-15T17:52:32.007Z Engine:INFO Enqueueing "Message Test" (re-l37h2fkj)
    [latest-22004]2022-05-15T17:52:32.035Z Engine:NOTICE Starting reaction Message Test (re-l37h2fkj)
    [latest-22004]2022-05-15T17:52:32.036Z Engine:INFO Message Test all actions completed.
    [latest-22004]2022-05-15T17:52:41.324Z Engine:INFO Enqueueing "Variable Telegram Test" (re-kvnm57c3)
    If I use the following in my web browser the telegram message gets through:
    https://api.telegram.org/botxxxxx......./sendMessage?chat_id=xxxxx......&text=Test Message HTTPS
    I am running MSR on my QNAP network attached storage. Any assistance would be appreciated.
    Just another question...... I would like to post in the HOME HARDWARE VERA section of Smarthome, but I do not have the option to set up a new post. Do I need to request access for this?
    MSR user on Raspberry PI 4. Running MSR version 26011 in Docker
    G CrilleC toggledbitsT 3 Replies Last reply
    • T Talisker
      @talisker So it used to work but now it doesn't?
      What changed?
      It always comes back to those two words.
      • Did it stop working before you bumped up to 22004?
      • list itemWhat version did it last work on?
      • list itemAny systemic updates happen on or near when it stopped working?
      • list itemWhat is your install like other than "on my QNAO NAS"?
      Please read this and provide more detail - no one can help if they don't know all the pieces to the puzzle.
      • T Talisker
        @talisker I would also change the logging level for Telegram by adding this to your logging.yaml, while trobleshooting, and restart Reactor. Add it in the same section as Engine:
        NotifyTelegram:
          level: 7
        The logs should now tell you a bit more and when done you can change it back to level 4.
        • T Talisker
          @talisker said in MSR Telegram Messages Stopped Working:
          All of the above recommendations by others are good. I would also recommend updating to the current version of Reactor. That 22004 version is five months old.
          Telegram is working for me, so if the upgrade doesn't address the issue, then the logs suggested by @crille are needed, and a review of the posting policy suggested by @gwp1 is a good idea before you post any part of the logs (there is specific advice on posting log snippets, as well as general posting requirements).
            Talisker
            Thank you all for your suggestions and support. It turned out that it was a problem with my QNAP Container install. I have to re-install it and then re-install the (latest) MSR version. Anyhow, I'm up an running again.
              162.2k
              1.3k
