  3. Plugins
  4. iPhoneLocator: Alternate Map Servers
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
38 Posts 5 Posters 8.7k Views 5 Watching
    Replacing Google Map with
    1. Bing Map
      GitHub - rafale77/IPhoneLocator: IPhone Locator plugin for Micasaverde VERA and openLuup
      IPhone Locator plugin for Micasaverde VERA and openLuup - rafale77/IPhoneLocator
    2. Here Map
      GitHub - rafale77/IPhoneLocator at HEREversion
      IPhone Locator plugin for Micasaverde VERA and openLuup - GitHub - rafale77/IPhoneLocator at HEREversion
    Both tested on openLuup
      Slight issue I'm seeing with the Here map version on Openluup that the tabs are not all visible in settings. I have home, but nothing else.
      They come up sometimes but seems pretty random
      Also when I go into the map, it often does not load, or only loads part of the images.
      Any thoughts?
        I run this on openLuup/ALTUI and don't have this problem so I am not sure. Given your problems with icon, I am also suspecting you have some javascript problems. Maybe open a browser console and look for errors?
          Cheers
          So the maps appears to be an issue with Cross site origin
          A cookie associated with a cross-site resource at http://here.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
          VM1158 data_request:1 Access to XMLHttpRequest at 'http://signature.venue.maps.api.here.com/venues/signature/v1?xnlp=CL_JSMv3.0.17.0&app_id=false&app_code=false' from origin 'http://192.168.70.249:3480' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
          mapsjs-core.js:164 GET http://signature.venue.maps.api.here.com/venues/signature/v1?xnlp=CL_JSMv3.0.17.0&app_id=false&app_code=false net::ERR_FAILED
          d @ mapsjs-core.js:164
          $h @ mapsjs-core.js:165
          application/json @ mapsjs-core.js:169
          Gh.De @ mapsjs-core.js:168
          Th @ mapsjs-core.js:37
          (anonymous) @ mapsjs-core.js:38
          eg @ mapsjs-core.js:38
          add @ mapsjs-core.js:38
          td @ mapsjs-core.js:36
          Gh @ mapsjs-core.js:168
          wn.b @ VM1237:47
          wn.W @ VM1237:46
          U.W @ VM1237:11
          U.m @ VM1237:49
          U.F @ VM1237:69
          handleApiReady @ J_Phone.js:238
          (anonymous) @ VM1248:1
          setTimeout (async)
          iphone_Map @ J_Phone.js:439
          eval @ VM1232:1
          _deviceDrawControlPanelJSTab @ J_ALTUI_uimgr.js:3024
          _deviceDrawControlPanelOneTabContent @ J_ALTUI_uimgr.js:3719
          _displayActiveDeviceTab @ J_ALTUI_uimgr.js:3746
          (anonymous) @ J_ALTUI_uimgr.js:7038
          dispatch @ jquery.min.js:2
          v.handle @ jquery.min.js:2
          trigger @ jquery.min.js:2
          (anonymous) @ jquery.min.js:2
          each @ jquery.min.js:2
          l @ bootstrap.min.js:6
          t._transitionComplete @ bootstrap.min.js:6
          i @ bootstrap.min.js:6
          i @ jquery.min.js:2
          handle @ bootstrap.min.js:6
          triggerTransitionEnd @ bootstrap.min.js:6
          (anonymous) @ bootstrap.min.js:6
          setTimeout (async)
          o @ bootstrap.min.js:6
          t._activate @ bootstrap.min.js:6
          t.show @ bootstrap.min.js:6
          i._jQueryInterface @ bootstrap.min.js:6
          VM1237:10 GET http://1.traffic.maps.api.here.com/maptile/2.1/info?xnlp=CL_JSMv3.0.17.0&app_id=false&app_code=false&output=json&callback_func=H.service.jsonp.handleResponse(2) net::ERR_ABORTED 401 (Unauthorized)
          That's when I go to the Map tab
          When I go to the Settings tab:
          http://192.168.70.249:3480/cmh/skins/default/images/cpanel/button_bg.png?*~BUILD_VERSION~* 404 (Not Found)
          Which I'm struggling to find on Vera as well
          Any help?
          Just checked and I get the same errors in the console on Vera (same instance of Chrome) but no errors in the display.
          Cheers
            There seem to be something with CORS and API security. Are you running with CORS enabled on ALTUI? Are you using the same key which is currently active on the vera? If so, I would temporarily disable the plugin on the vera and disable the CORS functionality and start fresh maybe even with a new HERE key on openLuup.
            On the Settings tab,
            It also looks like not all the ALTUI files were moved over from the vera or installed on the openLuup installation or you may have a JS caching in your browser. As far as I know nothing in IPhoneLocator plugin calls out this button. It is an ALTUI command.
              Thanks, I'll give them a try, yes it's the same key
                And having said that, I'm not sure how I can do this.
                If I destroy the instances on the Vera, I'll lose them on the Openluup box.
                I've installed the AltUI version from Altmarket place on the Openluup box. This displays the tabs correctly but of course has reset everything to google.
                Above that, there seems to be no way to create another instance of the locator for my wife's phone.
                So I guess two questions remain? How do I create another phone instance under Altui / Openluup?
                And how do I get Openluup iPhone locator back on Here? I have SCPed the files from github into /etc/cmh-ludl and /etc/cmh-ludl/files, forced a reload and hard refreshed. They still load Google maps.
                Cheers!
                  Cheers!
                  @CatmanV2 said in iPhoneLocator: Alternate Map Servers:
                  Just like on the vera (or at least what the vera really does), create a new device and input the device and implementation files for the plugin. You will instantly get a second instance of the plugin. openLuup behaves very strictly like the vera in this area. kudos to @akbooer
                  The same way you did it on the vera, replace the one or two files which are different in the /etc/cmh-ludl folder and reload openLuup
                    @rafale77 said in iPhoneLocator: Alternate Map Servers:
                    Oh wow. Thanks!
                    Well I could have sworn blind I'd done that 😞
                    But apparently I was dreaming...
                      So close!
                      2020-06-22 18:03:17.917   luup_log:26: IPhoneLocator: Entering loop:26:1
                      2020-06-22 18:03:18.863   luup_log:26: IPhoneLocator: getPeriodForDevice(26) - Distance:0 Auto:0 Base:60==>60
                      2020-06-22 18:03:18.864   luup_log:26: IPhoneLocator: loop: an error occurred during execution of forceRefresh():[string "L_IPhone.lua"]:575: attempt to index local 'obj' (a nil value)
                      2020-06-22 18:03:18.864   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText was: 2020-06-22 18:02 / 60 s now: forceRefresh error, check logs / 60 s #hooks:0
                      Any thoughts?
                        This is a part of the plugin I did not touch: the iCloud API. Not sure what the error could be but definitely a connection with iCloud. Just to be sure, the device is seen and all setup right?
                          It eventually decided to work! (I did think that that was part of the original as it were. I suspect Apple just being picky.
                          Thanks, as ever
                            Annnnd finally got the maps to load properly with an extension blocking CORS
                              ArcherS
                              I thought I should give this a try on OpenLuup. I used iPhoneLocator on my Vera some years ago. It worked really well, but then I removed it due to the limitations in the Vera.
                              The problem I run into is that when I try to create credentials I do not understand how to create an "App code".
                              On here.com it says:
                              "App code credentials will continue to be supported for a few products and current Developer Portal accounts where App code credentials have already been generated for an App. New accounts will only be able to use App Code credentials for some legacy products. App code credentials are the least secure of the authentication credential types and we recommend the use of the API Key or OAuth 2.0 Token credentials instead for improved security."
                              Either it is me missing something very obvious or here.com have changed something.
                                I suspect it's the latter.....
                                • A ArcherS
                                  @ArcherS
                                  Thanks for reporting this. I will look at the API key authentication to modify the plugin when I get a few minutes.
                                  A CatmanV2C 2 Replies Last reply
                                    @ArcherS
                                    ArcherS
                                    @rafale77 Thanks! 🙂
                                      @ArcherS
                                      @rafale77 Cheers!
                                        To close this off: It helps if your wife signs into iCloud on her phone....
                                          In fact that wasn't it at all 😞
                                          iCloud knows exactly where she is
                                            3.6k
                                            3.2k
                                            707
                                          • Self test
