  2. Hardware
  3. Vera
  4. (Problem) Migration Z-Wave NW from Vera to UZB1 dongle
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
50 Posts 7 Posters 18.4k Views 7 Watching
    Trexx
    wrote on last edited by Trexx
    Current setup:
    Future Target:
    • Updated UZB1 dongle (via RPi SmartHome) to latest 5.39 Firmware
    Problem:
    • Steps 1-3: went fine (although the dumps are labeled as dongle.6.1.dump.x)
    • Step 4: went fine and the UZB1 was recognized as it should be (per dmesg)
    • Step 5: updating the port to /dev/ttyACM0 went fine, although I didn't see any indication of luup reload (or a save button for that matter when updating the port mapping)
    • Step 6: I did the touch for dongle.restore, but wasn't sure where to trigger a luup reload (I assumed it was Z-Wave Settings > Advanced > Reload Engine). I believe I got an error message when trying to do that step
    • Step 7: verify dongle.restore.go I don't recall being in the directions when I was going the test, but I rebooted
    • Post Reboot: None of my previous z-wave devices were listed. I also checked dmesg via ssh and noticed the following items:
      Step 5: This is pretty comical as luup reloads itself due to frequent crashes but they almost "hide" it from you when you actually need to do it. I honestly forgot how the vera UI looks like but I vaguely remember doing luup reloads by either going into the z-wave menu where you have a reload engine button or to the apps menu under the serial device something where the button basically runs a luup reload.
      Step 6: cf step 5 for the luup reload.
      I have never seen that unsupported device thing but I never really looked for it so you maybe right that they broke something.
      I don't recognize neither the vendor nor the ProdID as being the uzb so I doubt that's what it is.
      It is also very possible that you did not luup reload appropriately and did not go through all the checks.
        Trexx
        In googling, it looks like one way to do a Luup reload is the following in UI7 via Apps > Develop Apps
         luup.reload()
        @rafale77 That might be something you want to add to your directions for users who are not as deep into the weeds as you are 🙂
        Another option is via ALTUI > MISC > Reload Luup Engine
          Yes for those who use ALTUI!
          I will go edit to add the reload step later today. Thanks!
            Trexx
            I re-ran the testing today. Step 6 is where things are breaking. I did the touch dongle.restore command, reloaded luup, etc. The dongle.restore.go file never appears.
              So the dongle.restore file is still there?
              The process goes like this:
              Upon luup reload, the luup engine deletes the "dongle.restore" file and replaces it with a "dongle.restore.go" file while it is preparing the engine to do the restore. Then a vera reboot, gets the zwave serial tool to upload the dongle data to the zwave device.
              There are other ways to do this but this is what I thought was the easiest. (The alternative is to edit your user.data.json which is very tricky and error prone). These mimic the steps of a zwave data restore from the UI.
                Trexx
                Yup.. the dongle.restore file was still there.
                I tried Luup.reload(), Z-wave engine restart, and via Device > Advanced > New Service > Reload Engine. No go for any of them causing the dongle.restore to delete and create the dongle.restore.go file.
                As for user_data.json files... those are now showing as .lzo files btw if under /etc/cmh
                  yes the user data file are always compressed with lzo on the vera.
                  This is strange that the dongle.restore remains there. I have never seen this happen. You did put it in the same folder (/etc/cmh) as the dongle backup files, right?
                    Trexx
                    Correct... in /etc/cmh
                      Could you post a snapshot of the zwave advanced page where it is supposed to show the controller network ID etc... after having switched to the uzb as the controller?
                        Trexx
                        @rafale77
                        Here you go.
                          wow... so it did recognize the UZB just fine and can read the network ID from it. It is purely about triggering the recovery from your backup to the Uzb dongle then. I am a bit surprised that it didn't work.
                          So the "/etc/cmh/dongle.restore" file never got replaced?... I wonder if the script has changed. Unfortunately I wiped my vera from anything mios so I can't test with this firmware. The nuclear option would be to edit the user-data.json from a backup and recover from it.... You are sure you have all your dongle files in the etc/cmh folder right?
                          extract from my own old posting:
                          Just for documentation purpose, I also found how to restore only the onboard zwave dongle:
                          -move your desired dongle file (example: “dongle.6.1.dump.0”) to /etc/cmh,
                          -rename it “dongle.restore”,
                          -run Stop_cmh.sh
                          -run Start_cmh.sh
                          -run Reboot
                          T P 2 Replies Last reply
                            I am even wondering if this is worth trying:
                            https://z-wave.me/zmeserialupdater-manual/
        Z-WAVE Serial API Tool
        Version:LWE0.9
        by Z-WAVE>ME
                            usage: ZMESerialUpdater [-h]
                            {version,serialapi_boot,serialapi_firmware,serialapi_info,serialapi_readnvm,serialapi_writenvm,serialapi_cleannvm,serialapi_cap,serialapi_freq,serialapi_setvendor,serialapi_uzbupdate,serialapi_restorenvm,serialapi_ripnvm}
                            ZWave>ME tools for controllers. Welcome 🙂
                            positional arguments:
                            version Just only prints version.
                            serialapi_boot Adds ability to reflash bootloader of UZB.
                            serialapi_firmware Adds ability to reflash firmware of UZB.
                            serialapi_info Shows information packet of controller.
                            serialapi_readnvm Reads data from UZB NVM.
                            serialapi_writenvm Writes data to UZB NVM.
                            serialapi_cleannvm Writes data to UZB NVM.
                            serialapi_cap Set cap.
                            serialapi_freq Changes frequency.
                            serialapi_setvendor Changes vendor of UZB.
                            serialapi_uzbupdate Updates UZB.
                            serialapi_restorenvm. Writes hex or bin file directly to NVM.
                            serialapi_ripnvm Reads content of NVM to hex or bin file.
                            Just not sure if this would work with a dongle.dump from the vera.
                              -run Stop_cmh.sh
                              -run Start_cmh.sh
                              -run Reboot
                              Trexx
                              @rafale77 Yup... dongle.restore never got changed and dongle.dumps's all accounted for (see below)
                              root@MiOS_50013148:~# ls -al /etc/cmh/dongle*
                              -rw-r--r--    1 root     root         16383 Aug 22 20:26 /etc/cmh/dongle.6.1.dump.0
                              -rw-r--r--    1 root     root         16383 Aug 22 20:26 /etc/cmh/dongle.6.1.dump.1
                              -rw-r--r--    1 root     root         16383 Aug 22 20:25 /etc/cmh/dongle.6.1.dump.2
                              -rw-r--r--    1 root     root         16383 Aug 22 20:25 /etc/cmh/dongle.6.1.dump.3
                              -rw-r--r--    1 root     root         16383 Aug 20 14:05 /etc/cmh/dongle.6.1.dump.4
                              -rw-r--r--    1 root     root         16383 Aug 20 13:57 /etc/cmh/dongle.6.1.dump.5
                              If you wanted, I could send you a dump file so you could try flashing it via ZMESerialUpdater to see if that even works 🙂
                              As for the onboard restore, I assume I still have to remap the to the internal /dev/ttyS0 first prior to those commands.
                              • T Trexx
                                Indeed. You would have to do that before restoring to the onboard zwave controller. I am a bit stunned. This has never happened to me.
                                Is your dongle.restore file removed though?
                                I have been looking at a couple of other tools on the vera to try to figure out what the luup engine actually triggers when it restores and found both the zwaveserial tool and the zwave firmware tool but neither seem to generate a 16KB file as a backup.
                                  Trexx
                                  I have been having to manually delete the dongle.restore file
                                    Could you maybe try downgrading the firmware and trying this again? I thought I tested 4955 but maybe not. It doesn't look like a compatibility issue from the dongle itselfl but more likely a change in how the firmware triggers a dongle restore. The other possibility is the translation from one SDK from the other is not working because... you already upgraded your uzb firmware. If that is the case though, you could downgrade the UZB firmware back, do the restore and then re-upgrade it. The restore works better with an SDK the vera knows. In truth I have actually transitioned my vera to an external usb stick a long time back, though it was not an uzb so when I did this, I actually moved from a silabs usb stick to a zwave-me uzb all on the vera. Others have done this though (@DesT for example).
                                    I am baffled because when it is an sdk failure, it still goes and triggers the dongle.restore.go file. Maybe try to do a "touch dongle.restore.go" and run a luup reload instead?
                                      Trexx
                                      @rafale77 Which Vera FW version are you thinking and do you have a link to it 🙂
                                      Which zwave-me version would I need to be on to to test that portion?
                                        I think one version back of the UZB should suffice. Probably 5.36 or 5.32 but I was more thinking about downgrading the vera.
                                          Trexx
                                          I was able to piece together the URL structure to download the mt621 versions of 7.31 (current), 7.30 & 7.29. Which do you want to target.
                                            830
                                            3.7k
                                            3.2k
                                            820
