  2. Hardware
  3. Vera
  4. (Problem) Migration Z-Wave NW from Vera to UZB1 dongle
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
50 Posts 7 Posters 25.5k Views 7 Watching
    I think one version back of the UZB should suffice. Probably 5.36 or 5.32 but I was more thinking about downgrading the vera.
      Trexx
      I was able to piece together the URL structure to download the mt621 versions of 7.31 (current), 7.30 & 7.29. Which do you want to target.
        7.29 should work.
          Trexx
          Tried 7.29, reset to factory, restore backup config w/zwave. All came up good, failed on dongle.restore (luup) phase. Tried doing a touch "dongle.restore.go" and reboot even.. no go.
            This is really very strange. And I suppose the file you created is still there? There must be something else going on. It seems like your luup engine is not even trying to do the dongle restore.
              Trexx
              Yup... file still there.
                Last resort is to downgrade the Uzb stick as well but this is rather bizarre. Something must be blocking. I just can't figure out what.
                I just realized I have been seeing your posts on the QNAP forum. 🙂
                  Trexx
                  To which version of UZB are you thinking? And yes I have been on the QNAP forums for many years 🙂
                    just one prior. 5.35 or 5.36 I believe?
                      Trexx
                      At this point it isn't worth the headache and time to potentially solve this. The "all" access token which used to work on v3.06 to be able to access via the gui the firmware downgrade option doesn't work anymore. I initially thought it was related to upgrading to v3.10 of SmartHome so I rolled back, but still it didn't work. Looks like they shut that one down.
                        Trexx
                        I think I figured out part of my problem... in looking closer at the controller information in SmartHome app, it looks like I got an EU version instead of a US version of the dongle so it was on the wrong frequencies. I am sending it back to Amazon and re-ordered the chip off of your recommended eBay seller.
                          hmm interesting and weird... You know you can recode the dongle to US frequency right? I am just not sure if the embedded antenna was calibrated properly for it. The difference is in the number of channels and how they are optimized for their specific frequencies. The US use only two channels while 3 are used in other regions.
                            Trexx
                            wrote on last edited by Trexx
                            #31
                            I was having issues where using OZWD I would try and add a node (inclusion) and it wouldn't register the device even if was almost on top of it.. so that eventually led me there.
                            I looked on the sticker on the dongle which claims it is the US version (ZMEUUZB1).
                            In Z-way app, it shows EU and only options that appear to be for the ZMEEUZB version (EU) dongle for changing frequency.
                            I tried changing frequency via shell script to US, which says it does, but Z-way still showed EU even after that.
                              Trexx
                              I received the new USB dongle from e-bay seller. Shows US frequency in Zwave SW (5.27 release) and connected into OZWD in Home Assistant fine. Was able to successfully pair a Fibaro Dongle with it (which I couldn't get anything to pair with old dongle). So I think we have a winner 🙂
                                Congrats! Cheers.
                                • C Offline
                                  C Offline
                                  cubs2b23
                                  Looks like I'm running into the same things @Trexx in migrating things over from the Vera. Stuck at the dongle.restore not being removed upon engine reload. I'm not sure if I saw if there was a resolution.
                                    My wild guess is that there is a problem with the SDK version between the vera and the uzb. When I did this, my uzb was running version 6.81.05, the same version I was running on the vera, so I had no problems at all. The latest uzb firmware runs on 6.82.01. The vera also officially only supported 6.81.01 so I was already being very adventurous.
                                    My advice would be to check what SDK your vera is running and then downgrade your uzb to a firmware version supporting this same SDK so that the zwave serial API program on the vera doesn't need to do an SDK translation. There are so many people who did this, including on the HA forum that if it isn't working anymore, probably something changed on the vera which I am not aware of.
                                    • C Offline
                                      C Offline
                                      cubs2b23
                                      I might try the whole thing again. I just did a restore because at some point after I thought that none of it worked all my devices names were reset and all sitting in 'No Room'. Of course this was after I had switched the port back to the default Vera device. So something was happening maybe just at a snail's pace? Also how do I check the Vera's SDK version?
                                      • C Offline
                                        C Offline
                                        cubs2b23
                                        No go on the second attempt. So what are my other options if I don’t want to exclude/include everything?
                                          #38
                                          Sorry for not responding sooner, I was busy with work today. The SDK version of the vera should be shown in the advanced page under the z-wave submenu. You should see something like 6.1 or 6.01. which is the version of the serial API corresponding to 6.71. The point is to downgrade the firmware of the uzb to a version old enough that the vera can support. Not much more you can do on the vera.
                                          https://www.silabs.com/documents/public/user-guides/INS12350-Serial-API-Host-Appl.-Prg.-Guide.pdf
                                          https://www.silabs.com/documents/public/release-notes/SRN14615-6.82.01.pdf
                                            155.0k
