  2. Hardware
  3. Vera
  4. (Problem) Migration Z-Wave NW from Vera to UZB1 dongle
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
50 Posts 7 Posters 25.5k Views 7 Watching
    wow... so it did recognize the UZB just fine and can read the network ID from it. It is purely about triggering the recovery from your backup to the Uzb dongle then. I am a bit surprised that it didn't work.
    So the "/etc/cmh/dongle.restore" file never got replaced?... I wonder if the script has changed. Unfortunately I wiped my vera from anything mios so I can't test with this firmware. The nuclear option would be to edit the user-data.json from a backup and recover from it.... You are sure you have all your dongle files in the etc/cmh folder right?
    extract from my own old posting:
    Just for documentation purpose, I also found how to restore only the onboard zwave dongle:
    -move your desired dongle file (example: “dongle.6.1.dump.0”) to /etc/cmh,
    -rename it “dongle.restore”,
    -run Stop_cmh.sh
    -run Start_cmh.sh
    -run Reboot
    Trexx
    @rafale77 Yup... dongle.restore never got changed and dongle.dumps's all accounted for (see below)
    root@MiOS_50013148:~# ls -al /etc/cmh/dongle*
    -rw-r--r--    1 root     root         16383 Aug 22 20:26 /etc/cmh/dongle.6.1.dump.0
    -rw-r--r--    1 root     root         16383 Aug 22 20:26 /etc/cmh/dongle.6.1.dump.1
    -rw-r--r--    1 root     root         16383 Aug 22 20:25 /etc/cmh/dongle.6.1.dump.2
    -rw-r--r--    1 root     root         16383 Aug 22 20:25 /etc/cmh/dongle.6.1.dump.3
    -rw-r--r--    1 root     root         16383 Aug 20 14:05 /etc/cmh/dongle.6.1.dump.4
    -rw-r--r--    1 root     root         16383 Aug 20 13:57 /etc/cmh/dongle.6.1.dump.5
    If you wanted, I could send you a dump file so you could try flashing it via ZMESerialUpdater to see if that even works 🙂
    As for the onboard restore, I assume I still have to remap the to the internal /dev/ttyS0 first prior to those commands.
    • T Trexx
      Indeed. You would have to do that before restoring to the onboard zwave controller. I am a bit stunned. This has never happened to me.
      Is your dongle.restore file removed though?
      I have been looking at a couple of other tools on the vera to try to figure out what the luup engine actually triggers when it restores and found both the zwaveserial tool and the zwave firmware tool but neither seem to generate a 16KB file as a backup.
        Trexx
        I have been having to manually delete the dongle.restore file
          Could you maybe try downgrading the firmware and trying this again? I thought I tested 4955 but maybe not. It doesn't look like a compatibility issue from the dongle itselfl but more likely a change in how the firmware triggers a dongle restore. The other possibility is the translation from one SDK from the other is not working because... you already upgraded your uzb firmware. If that is the case though, you could downgrade the UZB firmware back, do the restore and then re-upgrade it. The restore works better with an SDK the vera knows. In truth I have actually transitioned my vera to an external usb stick a long time back, though it was not an uzb so when I did this, I actually moved from a silabs usb stick to a zwave-me uzb all on the vera. Others have done this though (@DesT for example).
          I am baffled because when it is an sdk failure, it still goes and triggers the dongle.restore.go file. Maybe try to do a "touch dongle.restore.go" and run a luup reload instead?
            Trexx
            wrote on last edited by Trexx
            @rafale77 Which Vera FW version are you thinking and do you have a link to it 🙂
            Which zwave-me version would I need to be on to to test that portion?
              I think one version back of the UZB should suffice. Probably 5.36 or 5.32 but I was more thinking about downgrading the vera.
                Trexx
                I was able to piece together the URL structure to download the mt621 versions of 7.31 (current), 7.30 & 7.29. Which do you want to target.
                  7.29 should work.
                    Trexx
                    Tried 7.29, reset to factory, restore backup config w/zwave. All came up good, failed on dongle.restore (luup) phase. Tried doing a touch "dongle.restore.go" and reboot even.. no go.
                      This is really very strange. And I suppose the file you created is still there? There must be something else going on. It seems like your luup engine is not even trying to do the dongle restore.
                        Trexx
                        Yup... file still there.
                          Last resort is to downgrade the Uzb stick as well but this is rather bizarre. Something must be blocking. I just can't figure out what.
                          I just realized I have been seeing your posts on the QNAP forum. 🙂
                            Trexx
                            To which version of UZB are you thinking? And yes I have been on the QNAP forums for many years 🙂
                              just one prior. 5.35 or 5.36 I believe?
                                Trexx
                                At this point it isn't worth the headache and time to potentially solve this. The "all" access token which used to work on v3.06 to be able to access via the gui the firmware downgrade option doesn't work anymore. I initially thought it was related to upgrading to v3.10 of SmartHome so I rolled back, but still it didn't work. Looks like they shut that one down.
                                  Trexx
                                  I think I figured out part of my problem... in looking closer at the controller information in SmartHome app, it looks like I got an EU version instead of a US version of the dongle so it was on the wrong frequencies. I am sending it back to Amazon and re-ordered the chip off of your recommended eBay seller.
                                    hmm interesting and weird... You know you can recode the dongle to US frequency right? I am just not sure if the embedded antenna was calibrated properly for it. The difference is in the number of channels and how they are optimized for their specific frequencies. The US use only two channels while 3 are used in other regions.
                                      Trexx
                                      #31
                                      I was having issues where using OZWD I would try and add a node (inclusion) and it wouldn't register the device even if was almost on top of it.. so that eventually led me there.
                                      I looked on the sticker on the dongle which claims it is the US version (ZMEUUZB1).
                                      In Z-way app, it shows EU and only options that appear to be for the ZMEEUZB version (EU) dongle for changing frequency.
                                      I tried changing frequency via shell script to US, which says it does, but Z-way still showed EU even after that.
                                        Trexx
                                        I received the new USB dongle from e-bay seller. Shows US frequency in Zwave SW (5.27 release) and connected into OZWD in Home Assistant fine. Was able to successfully pair a Fibaro Dongle with it (which I couldn't get anything to pair with old dongle). So I think we have a winner 🙂
                                          Congrats! Cheers.
                                            155.0k
