  3. Plugins
  4. upnp event proxy
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
upnp event proxy
11 Posts 4 Posters 2.8k Views 4 Watching
    I've made some mods to Futzle's upnp event proxy and placed it in the AltApp store (with her permission). ie it's here in GitHub.
    Now it seems some people say it works with openLuup already. However the version released by Futzle required two things in order to function:
    1. the file L_UPnPProxy1.lua was expected to be compressed, as it would be on a Vera eg: L_UPnPProxy1.lua.lzo
    2. the hardware needs to be running OpenWrt; ie as per Vera does.
    I modified the code to fix point 1) (see the script below) but I would like to see point 2) resolved, so a RasPi can be used. That is modify the script to allow a deamon to be run on a RasPi without fiddling around with say "/etc/rc.local".
    So has any one got the proxy going on any hardware that is NOT using OpenWrt ? I'm unsure how to do it.
    Basically this script and/or the script it includes needs to be modified or even merged to suit. You'll note that after the shebang, it requires the file "etc/rc.common" (reproduced further below). The latter appears to be some sort of template file that is overriden as required by the first script. It cites "$IPKG_INSTROOT", whatever that is. However it may be possible to make use of it somehow on a RasPi?
    #!/bin/sh /etc/rc.common
    # Copyright (C) 2007 OpenWrt.org
    START=80
    PID_FILE=/var/run/upnp-event-proxy.pid
    PROXY_DAEMON=/tmp/upnp-event-proxy.lua
    start() {
    	if [ -f "$PID_FILE" ]; then
    		# May already be running.
    		PID=$(cat "$PID_FILE")
    		if [ -d "/proc/$PID" ]; then
    			COMMAND=$(readlink "/proc/$PID/exe")
    			if [ "$COMMAND" = "/usr/bin/lua" ]; then
    				echo "Daemon is already running"
    				return 1
    			fi
    		fi
    	fi
        # openLuup: Look for the uncompressed proxy daemon Lua source.
        if [ -f /etc/cmh-ludl/L_UPnPProxyDaemon.lua ]; then
            PROXY_DAEMON_UC=/etc/cmh-ludl/L_UPnPProxyDaemon.lua
        elif [ -f /etc/cmh-ludl/files/L_UPnPProxyDaemon.lua ]; then
            PROXY_DAEMON_UC=/etc/cmh-ludl/files/L_UPnPProxyDaemon.lua
        # Vera 3: Else look for the compressed proxy daemon Lua source.
        elif [ -f /etc/cmh-ludl/L_UPnPProxyDaemon.lua.lzo ]; then
            PROXY_DAEMON_LZO=/etc/cmh-ludl/L_UPnPProxyDaemon.lua.lzo
        elif [ -f /etc/cmh-lu/L_UPnPProxyDaemon.lua.lzo ]; then
            PROXY_DAEMON_LZO=/etc/cmh-lu/L_UPnPProxyDaemon.lua.lzo
        fi
        if [ -n "$PROXY_DAEMON_UC" ]; then
            cp "$PROXY_DAEMON_UC" "$PROXY_DAEMON"
        elif [ -n "$PROXY_DAEMON_LZO" ]; then
            /usr/bin/pluto-lzo d "$PROXY_DAEMON_LZO" "$PROXY_DAEMON"
        fi
    	# Close file descriptors.
    	for fd in /proc/self/fd/*; do
    		fd=${fd##*/}
    		case $fd in
    			0|1|2) ;;
    			*) eval "exec $fd<&-"
    		esac
    	done
    	# Run daemon.
    	/usr/bin/lua "$PROXY_DAEMON" </dev/null >/dev/null 2>&1 &
    	echo "$!" > "$PID_FILE"
    stop() {
    				/bin/kill -KILL "$PID" && /bin/rm "$PID_FILE"
    				return 0
    			fi
    		fi
    	fi
    	echo "Daemon is not running"
    	return 1
    And here is "etc/rc.common" as found in OpenWrt initscripts. Note the command actions it implements - in particular disable & enable, which set up Sxxy (start) & Kxxy (stop) files in the directory "etc/rc.d", which is not found in the RasPi directory structure:
    #!/bin/sh
    # Copyright (C) 2006-2009 OpenWrt.org
    . $IPKG_INSTROOT/etc/functions.sh
    initscript=$1
    action=${2:-help}
    shift 2
    start() {
    	return 0
    stop() {
    	return 0
    reload() {
    	return 1
    restart() {
    	trap '' TERM
    	stop "$@"
    	start "$@"
    boot() {
    	start "$@"
    shutdown() {
    	stop
    disable() {
    	name="$(basename "${initscript}")"
    	rm -f "$IPKG_INSTROOT"/etc/rc.d/S??$name
    	rm -f "$IPKG_INSTROOT"/etc/rc.d/K??$name
    enable() {
    	disable
    	[ "$START" ] && ln -s "../init.d/$name" "$IPKG_INSTROOT/etc/rc.d/S${START}${name##S[0-9][0-9]}"
    	[ "$STOP"  ] && ln -s "../init.d/$name" "$IPKG_INSTROOT/etc/rc.d/K${STOP}${name##K[0-9][0-9]}"
    enabled() {
    	[ -x "$IPKG_INSTROOT/etc/rc.d/S${START}${name##S[0-9][0-9]}" ]
    depends() {
    	return 0
    help() {
    	cat <<EOF
    Syntax: $initscript [command]
    Available commands:
    	start	Start the service
    	stop	Stop the service
    	restart	Restart the service
    	reload	Reload configuration files (or restart if that fails)
    	enable	Enable service autostart
    	disable	Disable service autostart
    $EXTRA_HELP
    EOF
    . "$initscript"
    ALL_COMMANDS="start stop reload restart boot shutdown enable disable enabled depends ${EXTRA_COMMANDS}"
    list_contains ALL_COMMANDS "$action" || action=help
    [ "$action" = "reload" ] && action='eval reload "$@" || restart "$@" && :'
    $action "$@"
      Can’t you just install ubuntu (it’s easy with windows subsystem for Linux , if you’re a windows user) and try it?
      I will just remove this part completely and give instructions to manually install the daemon. People using openluup are usually able to do it and I’ll prefer this any day over a script messing with my config files.
        For this sort of thing (also like mounting file systems) I do this in Lua Startup. Should be easy enough to check whether it’s already running (eg. Is the socket in use.)
          @therealdb said in upnp event proxy:
          Totally in agreement as per:
          ..run on a RasPi without fiddling around with say "/etc/rc.local"
          This makes some sense also:
          ... I do this in Lua Startup
          Well it would obviously require a major rework of some of the code but some users do find installing stuff manually not so easy - including me at times! Something to perhaps think about.I really want my Sonos stuff running under openLuup.
            You don’t need the proxy in order to run the Sonos plugin...?
              No you don't need it but it helps makes the Sonos plugin more responsive. Speaking of which, it would be good to see the Sonos plugin in GitHub and in the AltApp store.
                Isn't rigpapa new version already on Github?
                  Yep - you're right - it's in GitHub. My memory is playing tricks on me again. I read that rigpapa had it available in the AltApp store but I can't see it there - that's the bit that's missing.
                    Ping him, it's been very critical about Ezlo lately, so maybe it's willing to fix it, if necessary.
                    • A a-lurker
                      @a-lurker said in upnp event proxy:
                      Speaking of this, you can just detect openluup and stop doing the magical thing. Remember openluup can run on windows and Macos too and I'm not sure daemon could be so generalized.
                      • A a-lurker
                        @a-lurker
                        In response to your question on another thread, you can start the upnp proxy from any lua platform in reality. The specific script you have for openWRT is specific only because it uses init.d and specific paths to find the daemon.
                        For my installation the first step was to install lxp:
                        sudo luarocks install LuaExpat
                        This assumes you already have luarocks installed. Now I run luajit instead of lua5.1 but you can run either:
                        luajit /etc/cmh-ludl/L_UPnPProxyDaemon.lua
                        or
                        lua5.1 /etc/cmh-ludl/L_UPnPProxyDaemon.lua
                        This will start another instance of lua and the proxy daemon. You could even start it within openLuup as part of the startup lua I believe.
                        To autostart it as a service you can just create the following service file in the /etc/systemd/system folder:
                        [Unit]
                        Description=upnp
                        Wants=network.target
                        After=network.target
                        Before=screen.service
                        [Service]
                        Type=oneshot
                        WorkingDirectory=/etc/cmh-ludl
                        ExecStart=luajit /etc/cmh-ludl/L_UPnPProxyDaemon.lua -d
                        Restart=on-failure
                        [Install]
                        WantedBy=multi-user.target
                        I called this file upnp.service
                        You then just have to enable it and start it.
                        sudo systemctl daemon-reload
                        sudo systemctl enable upnp && sudo systemctl start upnp
                        checking status:
                        Screen Shot 2021-03-22 at 21.36.10.png Screen Shot 2021-03-22 at 21.35.27.png
                        Edit: As expected, the UPnP proxy replaced the the polling mechanism of the plugin and thereby dropped openLuup's CPU utilization by 0.1% from 1.4% to 1.3%.
                          2.0k
                          3.8k
                          3.3k
