  3. Plugins
  4. iPhoneLocator: Alternate Map Servers
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
38 Posts 5 Posters 17.7k Views 5 Watching
    sebby
    I'm going to uninstall iphone locator and start from scratch. i guess my confusion is that if i pull it from the alt app store, i have two options 2.43 or 2.master. i assumed that since 2.43 was selected it was the latest version.
      sebby
      i uninstalled and installed the 2.master version and the googlemapkey shows up. When i replace all the files from @fadale77 repository, reload luup and do a hard refresh of the browser it still only shows me the googlemapkey and not the here maps details. i installed openLuup in /etc/cmh-ludl/ and i am copying the files into the /files directory in there. Not sure what else to try now?
        #29
        Good that you already got the googlemapkey variable. Now I am not sure whether I autocreated the other keys. I think I left the instructions in the old place and it's been so long that I forgot. I may have missed adding the function to autocreate the variables. Will get back to you.
        Edit: Just looked at my old code and yep they are there. Upon luup reload, if you dropped in the files from my repo, you should see the new variables. Look at the very end of this file:
        IPhoneLocator/L_IPhone.lua at HEREversion · rafale77/IPhoneLocator
        IPhone Locator plugin for Micasaverde VERA and openLuup - rafale77/IPhoneLocator
        Is it the branch you got your file from?
          sebby
          when i cat /etc/cmh-ludl/files/L_IPhone.lua i see the code from your repo. Just strange that it is not loading them.
          function initstatus(lul_device)
          lul_device = tonumber(lul_device)
          UserMessage("starting version "..version.." lul_device:"..lul_device)
          checkVersion(lul_device)
          local delay = 2 -- delaying first refresh by x seconds
          if (getParent(lul_device)==0) then
          debug("initstatus("..lul_device..") startup for Root device, delay:"..delay)
          getSetVariable(service, "AppID", lul_device, "")
          getSetVariable(service, "AppCode", lul_device, "")
          getSetVariable(service, "APIkey", lul_device, "")
          getSetVariable(service, "IconURL", lul_device,defIconURL)
          else
          	debug("initstatus("..lul_device..") startup for Child device, delay:"..delay)
          luup.call_delay("startupDeferred", delay, tostring(lul_device))
          -- do not delete, last line must be a CR according to MCV wiki page
            What errors are in the startup log, and the startup phase of the main log?
              sebby
              logs don't really show anything that i can see as obviously wrong. i am completely stumped. ei've uninstalled everything, reinstalled, rebooted, refreshed, scratched my head, all to no avail. i definitely know it is some sort of user error on my end, i just can't seem to figure out what it is. really appreciate the attempt at help though.
                Just in case... what json library did you load? I am not sure why your openluup doesn't seem to be executing the lua code. Some error must be preventing it.
                • S sebby
                  @sebby said in iPhoneLocator: Alternate Map Servers:
                  You really don’t have to do that... this isn’t Vera, you know. 😉
                  There must be something basic here wrong. Can I see the startup log?
                    sebby
                    Certainly.
                    ===log===
                    2020-10-01 02:47:58.492 :: openLuup STARTUP :: /etc/cmh-ludl
                    2020-10-01 02:47:58.492 openLuup.init:: version 2020.05.01 @akbooer
                    2020-10-01 02:47:58.541 openLuup.scheduler:: version 2020.01.25 @akbooer
                    2020-10-01 02:47:58.585 openLuup.wsapi:: version 2019.08.12 @akbooer
                    2020-10-01 02:47:58.585 openLuup.servlet:: version 2020.01.29 @akbooer
                    2020-10-01 02:47:58.585 openLuup.client:: version 2019.10.14 @akbooer
                    2020-10-01 02:47:58.589 openLuup.io:: version 2019.11.29 @akbooer
                    2020-10-01 02:47:58.589 openLuup.server:: version 2020.03.20 @akbooer
                    2020-10-01 02:47:58.601 openLuup.scenes:: version 2020.03.16 @akbooer
                    2020-10-01 02:47:58.608 openLuup.chdev:: version 2020.03.07 @akbooer
                    2020-10-01 02:47:58.608 openLuup.userdata:: version 2020.03.31 @akbooer
                    2020-10-01 02:47:58.609 openLuup.requests:: version 2020.04.15 @akbooer
                    2020-10-01 02:47:58.610 openLuup.gateway:: version 2020.03.08 @akbooer
                    2020-10-01 02:47:58.616 openLuup.smtp:: version 2018.04.12 @akbooer
                    2020-10-01 02:47:58.625 openLuup.historian:: version 2020.02.12 @akbooer
                    2020-10-01 02:47:58.625 openLuup.luup:: version 2020.03.21 @akbooer
                    2020-10-01 02:47:58.628 openLuup.pop3:: version 2018.04.23 @akbooer
                    2020-10-01 02:47:58.629 openLuup.compression:: version 2016.06.30 @akbooer
                    2020-10-01 02:47:58.629 openLuup.timers:: version 2019.05.03 @akbooer
                    2020-10-01 02:47:58.629 openLuup.logs:: version 2018.03.25 @akbooer
                    2020-10-01 02:47:58.629 openLuup.json:: version 2020.05.20 @akbooer
                    2020-10-01 02:47:58.629 openLuup.init:: using Cjson 2.1.0 for fast decoding
                    2020-10-01 02:47:58.746 luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                    2020-10-01 02:47:58.777 luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json (openLuup)
                    2020-10-01 02:47:58.777 openLuup.init:: loading configuration user_data.json
                    2020-10-01 02:47:58.791 openLuup.userdata:: loading user_data json...
                    2020-10-01 02:47:58.881 luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                    2020-10-01 02:47:58.882 openLuup.userdata:: loading rooms...
                    2020-10-01 02:47:58.882 openLuup.userdata:: room#1 'MiOS-50001615'
                    2020-10-01 02:47:58.882 openLuup.userdata:: room#101 'Room 101'
                    2020-10-01 02:47:58.882 openLuup.userdata:: ...room loading completed
                    2020-10-01 02:47:58.882 openLuup.userdata:: loading devices...
                    2020-10-01 02:47:58.889 luup.create_device:: [1] D_ZWaveNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                    2020-10-01 02:47:59.079 openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
                    2020-10-01 02:47:59.080 openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
                    2020-10-01 02:47:59.080 openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
                    2020-10-01 02:47:59.080 openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
                    2020-10-01 02:47:59.081 luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1)
                    2020-10-01 02:47:59.098 luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json (urn:schemas-upnp-org:device:AltAppStore:1)
                    2020-10-01 02:47:59.122 luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json (VeraBridge)
                    2020-10-01 02:47:59.233 luup.create_device:: [6] D_Reactor.xml / I_Reactor.xml / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1)
                    2020-10-01 02:47:59.299 luup.create_device:: [8] D_DeusExMachinaII1.xml / I_DeusExMachinaII1.xml / D_DeusExMachinaII1_UI7.json (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                    2020-10-01 02:47:59.363 luup.create_device:: [9] D_SiteSensor1.xml / I_SiteSensor1.xml / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:47:59.366 luup.create_device:: [10] D_BroadLink_Mk2_1.xml / / ()
                    2020-10-01 02:47:59.366 openLuup.chdev:: ERROR: unable to read XML file D_BroadLink_Mk2_1.xml
                    2020-10-01 02:47:59.437 luup.create_device:: [11] D_Switchboard1.xml / I_Switchboard1.xml / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1)
                    2020-10-01 02:47:59.476 luup.create_device:: [12] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:47:59.549 openLuup.scheduler.sandbox:: device 24 defined 'string.mytemplate' (a function value)
                    2020-10-01 02:47:59.549 openLuup.scheduler.sandbox:: device 24 defined 'string.trim' (a function value)
                    2020-10-01 02:47:59.549 luup.create_device:: [24] D_IPhone.xml / I_IPhone.xml / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                    2020-10-01 02:47:59.588 luup.create_device:: [10002] D_ZigbeeNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZigbeeNetwork:1)
                    2020-10-01 02:47:59.602 luup.create_device:: [10003] D_BluetoothNetwork.xml / X / (urn:schemas-micasaverde-com:device:BluetoothNetwork:1)
                    2020-10-01 02:47:59.614 luup.create_device:: [10004] D_SceneController1.xml / X / D_SceneController1.json (urn:schemas-micasaverde-com:device:SceneController:1)
                    2020-10-01 02:47:59.617 luup.create_device:: [10005] D_SmartHomeHelper.xml / X / (urn:schemas-upnp-org:device:GoogleHome:1)
                    2020-10-01 02:47:59.732 luup.create_device:: [10006] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.745 luup.create_device:: [10007] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:47:59.755 luup.create_device:: [10008] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.765 luup.create_device:: [10009] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:47:59.776 luup.create_device:: [10012] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.785 luup.create_device:: [10013] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:47:59.799 luup.create_device:: [10017] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.811 luup.create_device:: [10018] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.820 luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:47:59.831 luup.create_device:: [10021] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.844 luup.create_device:: [10023] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.853 luup.create_device:: [10025] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                    2020-10-01 02:47:59.862 luup.create_device:: [10026] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                    2020-10-01 02:47:59.874 luup.create_device:: [10028] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:47:59.886 luup.create_device:: [10029] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:00.079 luup.create_device:: [10030] D_HVAC_ZoneThermostat1.xml / X / D_HVAC_ZoneThermostat2.json (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
                    2020-10-01 02:48:00.089 luup.create_device:: [10031] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                    2020-10-01 02:48:00.113 luup.create_device:: [10032] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                    2020-10-01 02:48:00.132 luup.create_device:: [10034] D_HVAC_ZoneThermostat1.xml / X / D_HVAC_ZoneThermostat2.json (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
                    2020-10-01 02:48:00.141 luup.create_device:: [10035] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                    2020-10-01 02:48:00.146 luup.create_device:: [10036] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                    2020-10-01 02:48:00.154 luup.create_device:: [10039] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.161 luup.create_device:: [10107] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.171 luup.create_device:: [10108] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.178 luup.create_device:: [10109] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.186 luup.create_device:: [10110] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.261 luup.create_device:: [10118] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                    2020-10-01 02:48:00.268 luup.create_device:: [10119] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                    2020-10-01 02:48:00.276 luup.create_device:: [10121] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                    2020-10-01 02:48:00.286 luup.create_device:: [10122] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:48:00.298 luup.create_device:: [10123] D_Switchboard1.xml / X / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1)
                    2020-10-01 02:48:00.306 luup.create_device:: [10125] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:48:00.317 luup.create_device:: [10126] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:48:00.328 luup.create_device:: [10131] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.336 luup.create_device:: [10132] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.344 luup.create_device:: [10133] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.353 luup.create_device:: [10134] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:48:00.365 luup.create_device:: [10135] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                    2020-10-01 02:48:00.374 luup.create_device:: [10158] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.382 luup.create_device:: [10159] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.389 luup.create_device:: [10160] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.396 luup.create_device:: [10162] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.404 luup.create_device:: [10163] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.413 luup.create_device:: [10164] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.421 luup.create_device:: [10165] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.429 luup.create_device:: [10166] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.439 luup.create_device:: [10167] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:00.447 luup.create_device:: [10173] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.459 luup.create_device:: [10174] D_LightSensor1.xml / X / D_LightSensor1.json (urn:schemas-micasaverde-com:device:LightSensor:1)
                    2020-10-01 02:48:00.466 luup.create_device:: [10175] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.474 luup.create_device:: [10181] D_Reactor.xml / X / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1)
                    2020-10-01 02:48:00.484 luup.create_device:: [10182] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.495 luup.create_device:: [10183] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.505 luup.create_device:: [10184] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.515 luup.create_device:: [10185] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.525 luup.create_device:: [10186] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.535 luup.create_device:: [10187] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.547 luup.create_device:: [10188] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.557 luup.create_device:: [10189] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.567 luup.create_device:: [10190] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.577 luup.create_device:: [10191] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.588 luup.create_device:: [10192] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:00.598 luup.create_device:: [10196] D_DoorSensor1.xml / X / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1)
                    2020-10-01 02:48:00.605 luup.create_device:: [10198] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.616 luup.create_device:: [10199] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:00.625 luup.create_device:: [10203] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:00.632 luup.create_device:: [10204] D_SmokeSensor1.xml / X / D_SmokeSensor1.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                    2020-10-01 02:48:00.639 luup.create_device:: [10205] D_SmokeSensor1.xml / X / D_COSensor1_FirstAlert.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                    2020-10-01 02:48:00.675 luup.create_device:: [10206] D_SonosSystem1.xml / X / D_SonosSystem1.json (urn:schemas-toggledbits-com:device:SonosSystem:1)
                    2020-10-01 02:48:01.252 luup.create_device:: [10207] D_Sonos1.xml / X / D_Sonos1_S21.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.267 luup.create_device:: [10208] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.282 luup.create_device:: [10209] D_Sonos1.xml / X / D_Sonos1_S16.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.296 luup.create_device:: [10210] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.311 luup.create_device:: [10211] D_Sonos1.xml / X / D_Sonos1_S14.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.325 luup.create_device:: [10212] D_Sonos1.xml / X / D_Sonos1_S21.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.340 luup.create_device:: [10213] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.359 luup.create_device:: [10214] D_Sonos1.xml / X / D_Sonos1_S12.json (urn:schemas-micasaverde-com:device:Sonos:1)
                    2020-10-01 02:48:01.389 luup.create_device:: [10218] D_UPnPProxy1.xml / X / D_UPnPProxy1.json (urn:schemas-futzle-com:device:UPnPProxy:1)
                    2020-10-01 02:48:01.408 luup.create_device:: [10219] D_SceneControllerLED1.xml / X / D_SwitchboardSC_219.json (urn:schemas-micasaverde-com:device:SceneControllerLED:1)
                    2020-10-01 02:48:01.468 luup.create_device:: [10220] D_VirtualSensor1.xml / X / D_VirtualSensor1.json (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                    2020-10-01 02:48:01.477 luup.create_device:: [10221] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1)
                    2020-10-01 02:48:01.483 luup.create_device:: [10223] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1)
                    2020-10-01 02:48:01.491 luup.create_device:: [10224] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.502 luup.create_device:: [10225] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.513 luup.create_device:: [10226] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.525 luup.create_device:: [10227] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.563 luup.create_device:: [10229] D_VeraAlexa1.xml / X / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1)
                    2020-10-01 02:48:01.570 luup.create_device:: [10233] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.578 luup.create_device:: [10234] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.586 luup.create_device:: [10235] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.596 luup.create_device:: [10237] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.606 luup.create_device:: [10238] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.614 luup.create_device:: [10239] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.627 luup.create_device:: [10240] D_DimmableRGBLight1.xml / X / D_DimmableRGBLight1.json (urn:schemas-upnp-org:device:DimmableRGBLight:1)
                    2020-10-01 02:48:01.630 luup.create_device:: [10241] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:01.630 luup.create_device:: [10242] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:01.631 luup.create_device:: [10243] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:01.638 luup.create_device:: [10246] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:01.646 luup.create_device:: [10247] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                    2020-10-01 02:48:01.653 luup.create_device:: [10248] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.664 luup.create_device:: [10249] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.674 luup.create_device:: [10250] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.684 luup.create_device:: [10251] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.693 luup.create_device:: [10252] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.698 luup.create_device:: [10253] D_SmokeSensor1.xml / X / D_SmokeSensor1.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                    2020-10-01 02:48:01.705 luup.create_device:: [10254] D_SmokeSensor1.xml / X / D_COSensor1_FirstAlert.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                    2020-10-01 02:48:01.717 luup.create_device:: [10255] D_DeusExMachinaII1.xml / X / D_DeusExMachinaII1_UI7.json (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                    2020-10-01 02:48:01.723 luup.create_device:: [10256] D_DoorSensor1.xml / X / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1)
                    2020-10-01 02:48:01.732 luup.create_device:: [10257] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                    2020-10-01 02:48:01.744 luup.create_device:: [10259] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.753 luup.create_device:: [10260] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.760 luup.create_device:: [10261] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.771 luup.create_device:: [10262] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.782 luup.create_device:: [10263] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                    2020-10-01 02:48:01.791 luup.create_device:: [10264] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.800 luup.create_device:: [10265] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.807 luup.create_device:: [10266] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.814 luup.create_device:: [10267] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.821 luup.create_device:: [10268] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                    2020-10-01 02:48:01.823 openLuup.userdata:: loading scenes...
                    2020-10-01 02:48:01.823 openLuup.userdata:: number of scenes = 0
                    2020-10-01 02:48:01.823 openLuup.userdata:: ...scene loading completed
                    2020-10-01 02:48:01.823 openLuup.userdata:: loading installed plugin info...
                    2020-10-01 02:48:01.824 openLuup.userdata:: [openLuup] openLuup (20.5.22)
                    2020-10-01 02:48:01.824 openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                    2020-10-01 02:48:01.824 openLuup.userdata:: [VeraBridge] VeraBridge (20.4.30)
                    2020-10-01 02:48:01.824 openLuup.userdata:: [8246] Alternate UI (2.50.)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [Z-Way] Z-Way (not.installed)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [Arduino] MySensors (not.installed)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [9086] Reactor (GitHub.master)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [8702] DeusExMachinaII (2.9)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [8942] SiteSensor (1.15)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [5665def1-9e1b-415b-97c8-7b75565f64c0] BroadLink-Mk2 (1.0)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [9194] Switchboard (1.7)
                    2020-10-01 02:48:01.825 openLuup.userdata:: [4686] IPhone Locator (2.master)
                    2020-10-01 02:48:01.825 openLuup.userdata:: ...user_data loading completed
                    2020-10-01 02:48:01.825 openLuup.init:: running openLuup_STARTUP
                    2020-10-01 02:48:01.826 luup_log:0: startup code completed
                    2020-10-01 02:48:01.826 openLuup.init:: init phase completed
                    2020-10-01 02:48:01.826 :: openLuup LOG ROTATION :: (runtime 0.0 days)
                      sebby
                      the previous log was with the standard iphone locator plugin enabled, i removed it, re-copied the files from rafale's repo and this is the new startup after those changes
                      2020-10-01 13:06:54.633 :: openLuup STARTUP :: /etc/cmh-ludl
                      2020-10-01 13:06:54.633 openLuup.init:: version 2020.05.01 @akbooer
                      2020-10-01 13:06:54.682 openLuup.scheduler:: version 2020.01.25 @akbooer
                      2020-10-01 13:06:54.726 openLuup.wsapi:: version 2019.08.12 @akbooer
                      2020-10-01 13:06:54.726 openLuup.servlet:: version 2020.01.29 @akbooer
                      2020-10-01 13:06:54.727 openLuup.client:: version 2019.10.14 @akbooer
                      2020-10-01 13:06:54.731 openLuup.io:: version 2019.11.29 @akbooer
                      2020-10-01 13:06:54.731 openLuup.server:: version 2020.03.20 @akbooer
                      2020-10-01 13:06:54.742 openLuup.scenes:: version 2020.03.16 @akbooer
                      2020-10-01 13:06:54.749 openLuup.chdev:: version 2020.03.07 @akbooer
                      2020-10-01 13:06:54.749 openLuup.userdata:: version 2020.03.31 @akbooer
                      2020-10-01 13:06:54.750 openLuup.requests:: version 2020.04.15 @akbooer
                      2020-10-01 13:06:54.751 openLuup.gateway:: version 2020.03.08 @akbooer
                      2020-10-01 13:06:54.757 openLuup.smtp:: version 2018.04.12 @akbooer
                      2020-10-01 13:06:54.766 openLuup.historian:: version 2020.02.12 @akbooer
                      2020-10-01 13:06:54.766 openLuup.luup:: version 2020.03.21 @akbooer
                      2020-10-01 13:06:54.769 openLuup.pop3:: version 2018.04.23 @akbooer
                      2020-10-01 13:06:54.770 openLuup.compression:: version 2016.06.30 @akbooer
                      2020-10-01 13:06:54.770 openLuup.timers:: version 2019.05.03 @akbooer
                      2020-10-01 13:06:54.770 openLuup.logs:: version 2018.03.25 @akbooer
                      2020-10-01 13:06:54.770 openLuup.json:: version 2020.05.20 @akbooer
                      2020-10-01 13:06:54.770 openLuup.init:: using Cjson 2.1.0 for fast decoding
                      2020-10-01 13:06:54.887 luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                      2020-10-01 13:06:54.918 luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json (openLuup)
                      2020-10-01 13:06:54.919 openLuup.init:: loading configuration user_data.json
                      2020-10-01 13:06:54.932 openLuup.userdata:: loading user_data json...
                      2020-10-01 13:06:55.020 luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                      2020-10-01 13:06:55.021 openLuup.userdata:: loading rooms...
                      2020-10-01 13:06:55.021 openLuup.userdata:: room#1 'MiOS-50001615'
                      2020-10-01 13:06:55.021 openLuup.userdata:: room#101 'Room 101'
                      2020-10-01 13:06:55.021 openLuup.userdata:: ...room loading completed
                      2020-10-01 13:06:55.021 openLuup.userdata:: loading devices...
                      2020-10-01 13:06:55.028 luup.create_device:: [1] D_ZWaveNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                      2020-10-01 13:06:55.218 openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
                      2020-10-01 13:06:55.218 openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
                      2020-10-01 13:06:55.218 openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
                      2020-10-01 13:06:55.219 openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
                      2020-10-01 13:06:55.219 luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1)
                      2020-10-01 13:06:55.236 luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json (urn:schemas-upnp-org:device:AltAppStore:1)
                      2020-10-01 13:06:55.260 luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json (VeraBridge)
                      2020-10-01 13:06:55.370 luup.create_device:: [6] D_Reactor.xml / I_Reactor.xml / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1)
                      2020-10-01 13:06:55.437 luup.create_device:: [8] D_DeusExMachinaII1.xml / I_DeusExMachinaII1.xml / D_DeusExMachinaII1_UI7.json (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                      2020-10-01 13:06:55.501 luup.create_device:: [9] D_SiteSensor1.xml / I_SiteSensor1.xml / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:55.504 luup.create_device:: [10] D_BroadLink_Mk2_1.xml / / ()
                      2020-10-01 13:06:55.504 openLuup.chdev:: ERROR: unable to read XML file D_BroadLink_Mk2_1.xml
                      2020-10-01 13:06:55.575 luup.create_device:: [11] D_Switchboard1.xml / I_Switchboard1.xml / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1)
                      2020-10-01 13:06:55.614 luup.create_device:: [12] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:55.686 openLuup.scheduler.sandbox:: device 25 defined 'string.mytemplate' (a function value)
                      2020-10-01 13:06:55.686 openLuup.scheduler.sandbox:: device 25 defined 'string.trim' (a function value)
                      2020-10-01 13:06:55.687 luup.create_device:: [25] D_IPhone.xml / I_IPhone.xml / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                      2020-10-01 13:06:55.725 luup.create_device:: [10002] D_ZigbeeNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZigbeeNetwork:1)
                      2020-10-01 13:06:55.740 luup.create_device:: [10003] D_BluetoothNetwork.xml / X / (urn:schemas-micasaverde-com:device:BluetoothNetwork:1)
                      2020-10-01 13:06:55.751 luup.create_device:: [10004] D_SceneController1.xml / X / D_SceneController1.json (urn:schemas-micasaverde-com:device:SceneController:1)
                      2020-10-01 13:06:55.755 luup.create_device:: [10005] D_SmartHomeHelper.xml / X / (urn:schemas-upnp-org:device:GoogleHome:1)
                      2020-10-01 13:06:55.870 luup.create_device:: [10006] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.883 luup.create_device:: [10007] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:55.893 luup.create_device:: [10008] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.903 luup.create_device:: [10009] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:55.913 luup.create_device:: [10012] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.923 luup.create_device:: [10013] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:55.936 luup.create_device:: [10017] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.948 luup.create_device:: [10018] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.958 luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:55.969 luup.create_device:: [10021] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.981 luup.create_device:: [10023] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:55.990 luup.create_device:: [10025] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                      2020-10-01 13:06:56.000 luup.create_device:: [10026] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                      2020-10-01 13:06:56.012 luup.create_device:: [10028] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:56.023 luup.create_device:: [10029] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:56.216 luup.create_device:: [10030] D_HVAC_ZoneThermostat1.xml / X / D_HVAC_ZoneThermostat2.json (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
                      2020-10-01 13:06:56.226 luup.create_device:: [10031] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                      2020-10-01 13:06:56.236 luup.create_device:: [10032] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                      2020-10-01 13:06:56.255 luup.create_device:: [10034] D_HVAC_ZoneThermostat1.xml / X / D_HVAC_ZoneThermostat2.json (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
                      2020-10-01 13:06:56.264 luup.create_device:: [10035] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                      2020-10-01 13:06:56.269 luup.create_device:: [10036] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                      2020-10-01 13:06:56.276 luup.create_device:: [10039] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.284 luup.create_device:: [10107] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.293 luup.create_device:: [10108] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.301 luup.create_device:: [10109] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.309 luup.create_device:: [10110] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.384 luup.create_device:: [10118] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                      2020-10-01 13:06:56.391 luup.create_device:: [10119] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                      2020-10-01 13:06:56.399 luup.create_device:: [10121] D_DoorLock1.xml / X / D_DoorLock1.json (urn:schemas-micasaverde-com:device:DoorLock:1)
                      2020-10-01 13:06:56.409 luup.create_device:: [10122] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:56.421 luup.create_device:: [10123] D_Switchboard1.xml / X / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1)
                      2020-10-01 13:06:56.428 luup.create_device:: [10125] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:56.440 luup.create_device:: [10126] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:56.450 luup.create_device:: [10131] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.458 luup.create_device:: [10132] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.467 luup.create_device:: [10133] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.476 luup.create_device:: [10134] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:56.488 luup.create_device:: [10135] D_SiteSensor1.xml / X / D_SiteSensor1.json (urn:schemas-toggledbits-com:device:SiteSensor:1)
                      2020-10-01 13:06:56.497 luup.create_device:: [10158] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.504 luup.create_device:: [10159] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.512 luup.create_device:: [10160] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.519 luup.create_device:: [10162] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.527 luup.create_device:: [10163] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.536 luup.create_device:: [10164] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.544 luup.create_device:: [10165] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.552 luup.create_device:: [10166] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.562 luup.create_device:: [10167] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:56.570 luup.create_device:: [10173] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.582 luup.create_device:: [10174] D_LightSensor1.xml / X / D_LightSensor1.json (urn:schemas-micasaverde-com:device:LightSensor:1)
                      2020-10-01 13:06:56.589 luup.create_device:: [10175] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.597 luup.create_device:: [10181] D_Reactor.xml / X / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1)
                      2020-10-01 13:06:56.607 luup.create_device:: [10182] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.618 luup.create_device:: [10183] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.628 luup.create_device:: [10184] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.638 luup.create_device:: [10185] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.648 luup.create_device:: [10186] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.658 luup.create_device:: [10187] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.670 luup.create_device:: [10188] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.679 luup.create_device:: [10189] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.689 luup.create_device:: [10190] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.700 luup.create_device:: [10191] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.711 luup.create_device:: [10192] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:56.720 luup.create_device:: [10196] D_DoorSensor1.xml / X / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1)
                      2020-10-01 13:06:56.728 luup.create_device:: [10198] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.739 luup.create_device:: [10199] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:56.747 luup.create_device:: [10203] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:56.755 luup.create_device:: [10204] D_SmokeSensor1.xml / X / D_SmokeSensor1.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                      2020-10-01 13:06:56.762 luup.create_device:: [10205] D_SmokeSensor1.xml / X / D_COSensor1_FirstAlert.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                      2020-10-01 13:06:56.798 luup.create_device:: [10206] D_SonosSystem1.xml / X / D_SonosSystem1.json (urn:schemas-toggledbits-com:device:SonosSystem:1)
                      2020-10-01 13:06:57.374 luup.create_device:: [10207] D_Sonos1.xml / X / D_Sonos1_S21.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.389 luup.create_device:: [10208] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.404 luup.create_device:: [10209] D_Sonos1.xml / X / D_Sonos1_S16.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.418 luup.create_device:: [10210] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.433 luup.create_device:: [10211] D_Sonos1.xml / X / D_Sonos1_S14.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.447 luup.create_device:: [10212] D_Sonos1.xml / X / D_Sonos1_S21.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.462 luup.create_device:: [10213] D_Sonos1.xml / X / D_Sonos1_S1.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.481 luup.create_device:: [10214] D_Sonos1.xml / X / D_Sonos1_S12.json (urn:schemas-micasaverde-com:device:Sonos:1)
                      2020-10-01 13:06:57.510 luup.create_device:: [10218] D_UPnPProxy1.xml / X / D_UPnPProxy1.json (urn:schemas-futzle-com:device:UPnPProxy:1)
                      2020-10-01 13:06:57.530 luup.create_device:: [10219] D_SceneControllerLED1.xml / X / D_SwitchboardSC_219.json (urn:schemas-micasaverde-com:device:SceneControllerLED:1)
                      2020-10-01 13:06:57.591 luup.create_device:: [10220] D_VirtualSensor1.xml / X / D_VirtualSensor1.json (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                      2020-10-01 13:06:57.599 luup.create_device:: [10221] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1)
                      2020-10-01 13:06:57.606 luup.create_device:: [10223] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1)
                      2020-10-01 13:06:57.613 luup.create_device:: [10224] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.624 luup.create_device:: [10225] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.636 luup.create_device:: [10226] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.648 luup.create_device:: [10227] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.685 luup.create_device:: [10229] D_VeraAlexa1.xml / X / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1)
                      2020-10-01 13:06:57.693 luup.create_device:: [10233] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.700 luup.create_device:: [10234] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.709 luup.create_device:: [10235] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.719 luup.create_device:: [10237] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.728 luup.create_device:: [10238] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.736 luup.create_device:: [10239] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.749 luup.create_device:: [10240] D_DimmableRGBLight1.xml / X / D_DimmableRGBLight1.json (urn:schemas-upnp-org:device:DimmableRGBLight:1)
                      2020-10-01 13:06:57.752 luup.create_device:: [10241] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:57.753 luup.create_device:: [10242] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:57.753 luup.create_device:: [10243] / X / (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:57.761 luup.create_device:: [10246] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:57.768 luup.create_device:: [10247] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                      2020-10-01 13:06:57.775 luup.create_device:: [10248] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.787 luup.create_device:: [10249] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.796 luup.create_device:: [10250] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.806 luup.create_device:: [10251] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.815 luup.create_device:: [10252] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.821 luup.create_device:: [10253] D_SmokeSensor1.xml / X / D_SmokeSensor1.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                      2020-10-01 13:06:57.827 luup.create_device:: [10254] D_SmokeSensor1.xml / X / D_COSensor1_FirstAlert.json (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                      2020-10-01 13:06:57.839 luup.create_device:: [10255] D_DeusExMachinaII1.xml / X / D_DeusExMachinaII1_UI7.json (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                      2020-10-01 13:06:57.846 luup.create_device:: [10256] D_DoorSensor1.xml / X / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1)
                      2020-10-01 13:06:57.854 luup.create_device:: [10257] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                      2020-10-01 13:06:57.866 luup.create_device:: [10259] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.875 luup.create_device:: [10260] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.882 luup.create_device:: [10261] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.893 luup.create_device:: [10262] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.905 luup.create_device:: [10263] D_DimmableLight1.xml / X / D_DimmableLight1.json (urn:schemas-upnp-org:device:DimmableLight:1)
                      2020-10-01 13:06:57.913 luup.create_device:: [10264] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.922 luup.create_device:: [10265] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.930 luup.create_device:: [10266] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.937 luup.create_device:: [10267] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.944 luup.create_device:: [10268] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1)
                      2020-10-01 13:06:57.946 openLuup.userdata:: loading scenes...
                      2020-10-01 13:06:57.946 openLuup.userdata:: number of scenes = 0
                      2020-10-01 13:06:57.946 openLuup.userdata:: ...scene loading completed
                      2020-10-01 13:06:57.946 openLuup.userdata:: loading installed plugin info...
                      2020-10-01 13:06:57.947 openLuup.userdata:: [openLuup] openLuup (20.5.22)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [VeraBridge] VeraBridge (20.4.30)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [8246] Alternate UI (2.50.)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [Z-Way] Z-Way (not.installed)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [Arduino] MySensors (not.installed)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [9086] Reactor (GitHub.master)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [8702] DeusExMachinaII (2.9)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [8942] SiteSensor (1.15)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [5665def1-9e1b-415b-97c8-7b75565f64c0] BroadLink-Mk2 (1.0)
                      2020-10-01 13:06:57.947 openLuup.userdata:: [9194] Switchboard (1.7)
                      2020-10-01 13:06:57.947 openLuup.userdata:: ...user_data loading completed
                      2020-10-01 13:06:57.947 openLuup.init:: running openLuup_STARTUP
                      2020-10-01 13:06:57.948 luup_log:0: startup code completed
                      2020-10-01 13:06:57.948 openLuup.init:: init phase completed
                      2020-10-01 13:06:57.948 :: openLuup LOG ROTATION :: (runtime 0.0 days)
                        sebby
                        could it be that it is getting confused because it is loading the iphone locator devices from the old vera?
                        2020-10-05 20:37:28.841 luup.create_device:: [10025] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                        2020-10-05 20:37:28.850 luup.create_device:: [10026] D_IPhone.xml / X / D_IPhone_UI7.json (urn:schemas-upnp-org:device:IPhoneLocator:1)
                          It could be. Should try with the vera unhooked. It looks like you are trying to run the plugin on both the vera and on openLuup. I would make a backup on the vera and delete the plugin from there and try again on openLuup.
                            163.8k
