  3. Plugins
  4. Telegram Plug-in to send text, images and video notifications
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
41 Posts 9 Posters 20.7k Views 10 Watching
  • PerHP PerH
    Will do, thanks! Any plans on getting this one into AltAppstore?
    @perh It should be ready to install from AltAppStore!
      FYI, Reactor's direct support for your plugin (in the Notify action) is now available in 3.9-20321, the stable branch release (so in AltUI, go to Plugins, and on the Reactor row enter "stable" as the version and click the update button).
        Contact! 🙂
        Had to make a new token to make it work, theres no expiry of them, i hope?
        Now i have to learn how to send "special" characters, it didnt even like "!".. But i don't intend to yell in my notifications anyway. 🙂
        Sent one from reactor too Patrick. 🙂
        To all you developer guys; Awesome job! thankyou for making this great HA system! Hope to join in on making some contributions myself. 🙂
          didn't find the Message function in this forum, and couldn't send pictures in "chat":
          @toggledbits , there's a small UI bug in the stable release:
          Other than that, its f**in awesome. 😉
            I can't reproduce it. What version of AltUI are you on? (see More > Plugins)
            D 1 Reply Last reply
            • PerHP PerH
              Contact! 🙂
              @perh said in Telegram Plug-in to send text, images and video notifications:
              It should work out of the box. I have emojis in my notifications and they are correctly encoded.
                Thats weird, this is the error i get with "Hello!" :
                luup_log:755: VeraTelegram(nil@194): executeCommand("curl -k -H 'Content-type: application/json' 'https://api.telegram.org/botXX:XX/sendMessage?parse_mode=MarkdownV2&chat_id=-362200779&text=Hello%21&disable_notification=false'"): "{\"ok\":false,\"error_code\":400,\"description\":\"Bad Request: can't parse entities: Character '!' is reserved and must be escaped with the preceding '\\\\'\"}"
                • PerHP PerH
                  #22
                  @perh Yep, I tracked it down on the other forum as well. As a temporary solution, set Format parameter to Markdown. I defaulted to MarkdownV2, but
                  _ * [ ] ( ) ~ > # + - = | { } . !
                  should be escaped and I didn't pay attention to this. Sorry, I'll push an update to GitHub very soon, to default to Markdown anyway.
                    D Offline
                    D Offline
                    dcmChrissy
                    I've got something similar. Running ALTUI 2.50.2549 (from the bottom banner)
                    Installed the Reactor.stable branch for the Pushover enhancements.
                    Oddly, although my Plugins tab for Reactor reads GitHub.stable, my Reactor Logic Summary page notes:
                    Version: 3.9develop-20318.1220 config 20263 cdata 20045 ui 20190 pluginDevice 98 LuaXP 1.0.2enh
                      That's correct. The stable branch is a development branch, so it will have development tagging on the versions. The stable branch is updated when work from development is tested and passes.
                      • C Offline
                        C Offline
                        cubs2b23
                        I'm seeing this as well with the dropdowns in both Firefox and Chrome. Running stable version of Reactor and v2.50 of ALTUI
                          The issue is resolved in the new "stable" version.
                          Perhaps this discussion should be moved from this Telegram thread? it's not really related. 🙂
                            <OT>hey @DesT, gimme the power to move and split threads! :D</OT>
                            DesTD D 2 Replies Last reply
                              DesTD Offline
                              DesTD Offline
                              DesT
                              @therealdb done 😉
                                D Offline
                                D Offline
                                dcmChrissy
                                @therealdb
                                Sorry db, thanks PerH - 'nuff said, properly chastened
                                  ArcherS
                                  I have set this up for some text notifications and it is working as it should, thanks for a very nice plugin! 🙂
                                  With the added support in Reactor it makes a nice pair!
                                  I also tested sending an image (in the format http://url/folder/image.jpg) and it works as specified in the users guide on github.
                                  What I cannot get to work however is when the url to the image contains user and login, which is required to get an image from my cameras.
                                  I.e. the url to the image is : http://user:passwd@192.168.x.y/jpg/image.jpg.
                                  I have tried encoding it with https://www.urlencoder.org/, but it does not seem to work.
                                  Any ideas on how to solve this?
                                  //ArcherS
                                  • A ArcherS
                                    //ArcherS
                                    @archers thanks!
                                    I'm using curl, so I'm not sure why it's not working, but I'll take a look. Is this basic Auth we're speaking about?
                                      @archers thanks!
                                      ArcherS
                                      @therealdb yes I think it should be basic authorisation to send credentials via http in the form of http://username:password@example.com/ to retreive an image from an Axis IP Camera and send it via Telegram.
                                      Maybe there is a better way to do it?
                                      I have used curl calling a .sh file from OpenLuup for sending a few commands to the camera (for enabling/disabling privacy mask) in the past.
                                      What I did try, but failed was to get the camera to send an image directly. It has support for sending images via http/https, but I didn't get that to work. So far I have done it via email instead since it supports that as well.
                                      I think however that quite a few cameras do not support sending themselves, so getting it to work in the plugin with basic auth would hopefully be of use anyway. 🙂
                                      //ArcherS
                                        Try with
                                        curl --user daniel:secret http://example.com/
                                        And if it's working, I'll try a patch.
                                          ArcherS
                                          #34
                                          Edit: I tested to modify mu curl from curl --digest -u daniel:secret... to curl --user daniel:secret... and that does not seem to work. It seems as if the Axis cameras require Digest mode for auth.
                                          Original post:
                                          @therealdb not sure how to test, I tried from the prompt on my OpenLuup PC running Ubuntu but it didn't seem to work, I got "This server could not verify that you are authorized...".
                                          But in the .sh file that I call from OpenLuup I have:
                                          curl --digest -u daniel:secret "http://192.168.x.x/axis-cgi/admin/param.cgi?action=update&root_Image_I0_Overlay_MaskWindows_M0_Enabled=no"
                                          (This is a cgi command to the camera.)
                                          And that curl works.
                                          Let me know if I should test something else!
                                          //ArcherS
                                            148.9k
