  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 39.4k Views 8 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    The spinner at the top right it's about the connection to the forum. It should appear only one time and disappear after!
    • DesTD DesT
      @DesT it's not 🙂
      WiFi is maxing out at 70M on my 200M cable 🙂
      • HSD99H Offline
        HSD99H Offline
        HSD99
        Same here. The spinner is constant, and I'm on wireline at 150 Mb/s.
        • HSD99H Offline
          HSD99H Offline
          HSD99
          Something has changed. The spinner now spins for a fraction of a second during the update only, which is the desired behavior.
          DesTD 1 Reply Last reply
          • HSD99H HSD99
            DesTD Offline
            DesTD Offline
            DesT
            @HSD99 We just disable on plugin in the forum that got an update this morning causing this issue! We just send a note to the plugin's dev!
            HSD99H 1 Reply Last reply
              Yeah it's not just the website that is fast... the response to feedback is too...
              • DesTD DesT
                HSD99H Offline
                HSD99H Offline
                HSD99
                @DesT Thanks for the quick response!
                  Need to be able to upvote >1 😄
                  Next can we get rid of the auto insert emojies? After 20+ years of typing colon-uppercase-D to denote a smiling face, I find that I'm being told I actually want to send a dog.
                  What the duck? (autocorrect fail) 😉
                    When posting a reply the text input box does not clear its self after posting. Is this by design?
                    • ElcidE Elcid
                      DesTD Offline
                      DesTD Offline
                      DesT
                      @Elcid it's a bug in the forum. Need to check that too!
                        DesTD Offline
                        DesTD Offline
                        DesT
                        @CatmanV2 said in Other Forum feedback:
                        I don't mind disabling auto-emoji replacement!
                          Link on the dark them are too dark 🙂
                            #35
                            @DesT Dark Mode color scheme is work in progress: Here is a couple of things which may need some attention.
                            Either font or background color...
                            Ohh and do we need 2 search fields? There is already one in the menu bar at the top.
                              Spinner is back and the 'not going to the first unread'
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                @CatmanV2 the spinner is not back, we tested it! Can you try just to force a refresh on your browser tab.
                                For the first "unread" I think it's an issue with the cookie/session. I would need to investigate a little bit more!
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  @CatmanV2 we change the entire theme/css this morning while also upgrading the plugin that give you the spinner yesterday!
                                  • HSD99H Offline
                                    HSD99H Offline
                                    HSD99
                                    No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
                                      There is a new little light bulb icon in the top menu. Try it!
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        • HSD99H Offline
                                          HSD99H Offline
                                          HSD99
                                          I've seen the light! Thanks!
                                            155.1k
