  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 41.1k Views 8 Watching
    Yeah it's not just the website that is fast... the response to feedback is too...
    • DesTD DesT
      @HSD99 We just disable on plugin in the forum that got an update this morning causing this issue! We just send a note to the plugin's dev!
      HSD99H Offline
      HSD99H Offline
      HSD99
      @DesT Thanks for the quick response!
        Need to be able to upvote >1 😄
        Next can we get rid of the auto insert emojies? After 20+ years of typing colon-uppercase-D to denote a smiling face, I find that I'm being told I actually want to send a dog.
        What the duck? (autocorrect fail) 😉
        DesTD 1 Reply Last reply
          When posting a reply the text input box does not clear its self after posting. Is this by design?
          • ElcidE Elcid
            DesTD Offline
            DesTD Offline
            DesT
            @Elcid it's a bug in the forum. Need to check that too!
              DesTD Offline
              DesTD Offline
              DesT
              @CatmanV2 said in Other Forum feedback:
              I don't mind disabling auto-emoji replacement!
                Link on the dark them are too dark 🙂
                  #35
                  @DesT Dark Mode color scheme is work in progress: Here is a couple of things which may need some attention.
                  Either font or background color...
                  Ohh and do we need 2 search fields? There is already one in the menu bar at the top.
                    Spinner is back and the 'not going to the first unread'
                    • DesTD Offline
                      DesTD Offline
                      DesT
                      @CatmanV2 the spinner is not back, we tested it! Can you try just to force a refresh on your browser tab.
                      For the first "unread" I think it's an issue with the cookie/session. I would need to investigate a little bit more!
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        @CatmanV2 we change the entire theme/css this morning while also upgrading the plugin that give you the spinner yesterday!
                        • HSD99H Offline
                          HSD99H Offline
                          HSD99
                          No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
                            There is a new little light bulb icon in the top menu. Try it!
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              • HSD99H Offline
                                HSD99H Offline
                                HSD99
                                I've seen the light! Thanks!
                                  Hard refresh removes the spinner. But it did that yesterday as well....
                                  I shall report back
                                  And I have cleared all cookies and logged out to test the last read issue.
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
                                      Just tried to post a couple of images and the forum throws an error
                                      Error
                                      Something went wrong while parsing server response
                                      This has worked before. It worked earlier today! Have I hit some sort of limit?
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          @akbooer it's working...
                                          Are you using the "Quick reply" or the "Reply" button ?
                                            165.6k
