  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 41.1k Views 8 Watching
  • ElcidE Elcid
    When posting a reply the text input box does not clear its self after posting. Is this by design?
    DesTD Offline
    DesTD Offline
    DesT
    @Elcid it's a bug in the forum. Need to check that too!
      Need to be able to upvote >1 😄
      Next can we get rid of the auto insert emojies? After 20+ years of typing colon-uppercase-D to denote a smiling face, I find that I'm being told I actually want to send a dog.
      What the duck? (autocorrect fail) 😉
      DesTD Offline
      DesTD Offline
      DesT
      @CatmanV2 said in Other Forum feedback:
      I don't mind disabling auto-emoji replacement!
        Link on the dark them are too dark 🙂
          #35
          @DesT Dark Mode color scheme is work in progress: Here is a couple of things which may need some attention.
          Either font or background color...
          Ohh and do we need 2 search fields? There is already one in the menu bar at the top.
            Spinner is back and the 'not going to the first unread'
            • DesTD Offline
              DesTD Offline
              DesT
              @CatmanV2 the spinner is not back, we tested it! Can you try just to force a refresh on your browser tab.
              For the first "unread" I think it's an issue with the cookie/session. I would need to investigate a little bit more!
              • DesTD Offline
                DesTD Offline
                DesT
                @CatmanV2 we change the entire theme/css this morning while also upgrading the plugin that give you the spinner yesterday!
                • HSD99H Offline
                  HSD99H Offline
                  HSD99
                  No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
                    There is a new little light bulb icon in the top menu. Try it!
                    • DesTD Offline
                      DesTD Offline
                      DesT
                      • HSD99H Offline
                        HSD99H Offline
                        HSD99
                        I've seen the light! Thanks!
                          Hard refresh removes the spinner. But it did that yesterday as well....
                          I shall report back
                          And I have cleared all cookies and logged out to test the last read issue.
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
                              Just tried to post a couple of images and the forum throws an error
                              Error
                              Something went wrong while parsing server response
                              This has worked before. It worked earlier today! Have I hit some sort of limit?
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  @akbooer it's working...
                                  Are you using the "Quick reply" or the "Reply" button ?
                                    Both, and drag and drop. As I say, it worked earlier! I’ll try again later.
                                    Loved your cartoon!
                                      C'est bon... images attaching to posts again.
                                        Still don't get the last post 😞
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          @CatmanV2 didn't have a chance to check that again, a little bit busy outside the forum 😞
                                            165.6k
