  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 41.1k Views 8 Watching
  • HSD99H Offline
    HSD99H Offline
    HSD99
    No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
      There is a new little light bulb icon in the top menu. Try it!
      • DesTD Offline
        DesTD Offline
        DesT
        • HSD99H Offline
          HSD99H Offline
          HSD99
          I've seen the light! Thanks!
            Hard refresh removes the spinner. But it did that yesterday as well....
            I shall report back
            And I have cleared all cookies and logged out to test the last read issue.
            • DesTD Offline
              DesTD Offline
              DesT
              The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
                Just tried to post a couple of images and the forum throws an error
                Error
                Something went wrong while parsing server response
                This has worked before. It worked earlier today! Have I hit some sort of limit?
                • DesTD Offline
                  DesTD Offline
                  DesT
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    @akbooer it's working...
                    Are you using the "Quick reply" or the "Reply" button ?
                      Both, and drag and drop. As I say, it worked earlier! I’ll try again later.
                      Loved your cartoon!
                        C'est bon... images attaching to posts again.
                          Still don't get the last post 😞
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            @CatmanV2 didn't have a chance to check that again, a little bit busy outside the forum 😞
                              De nada, chap
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                Thanks to Google Translate 😉
                                  Ca fait rien? 😉
                                    "De rien!" is a better translation... 😛
                                      Tant pis??
                                        Tant pis??
                                        @akbooer Harsh, chap 😉
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          yeah it's "De rien" or you can use "Ya pas de probleme"
                                            165.6k
