  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 39.4k Views 8 Watching
    There is a new little light bulb icon in the top menu. Try it!
    • DesTD Offline
      DesTD Offline
      DesT
      • HSD99H Offline
        HSD99H Offline
        HSD99
        I've seen the light! Thanks!
          Hard refresh removes the spinner. But it did that yesterday as well....
          I shall report back
          And I have cleared all cookies and logged out to test the last read issue.
          • DesTD Offline
            DesTD Offline
            DesT
            The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
              Just tried to post a couple of images and the forum throws an error
              Error
              Something went wrong while parsing server response
              This has worked before. It worked earlier today! Have I hit some sort of limit?
              • DesTD Offline
                DesTD Offline
                DesT
                • DesTD Offline
                  DesTD Offline
                  DesT
                  @akbooer it's working...
                  Are you using the "Quick reply" or the "Reply" button ?
                    Both, and drag and drop. As I say, it worked earlier! I’ll try again later.
                    Loved your cartoon!
                      C'est bon... images attaching to posts again.
                        Still don't get the last post 😞
                        • DesTD Offline
                          DesTD Offline
                          DesT
                          @CatmanV2 didn't have a chance to check that again, a little bit busy outside the forum 😞
                            De nada, chap
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              Thanks to Google Translate 😉
                                Ca fait rien? 😉
                                  "De rien!" is a better translation... 😛
                                    Tant pis??
                                      Tant pis??
                                      @akbooer Harsh, chap 😉
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        yeah it's "De rien" or you can use "Ya pas de probleme"
                                        • DesTD DesT
                                          @DesT said in Other Forum feedback:
                                          But but but! You're Canadian, aren't you? 😄
                                          DesTD 1 Reply Last reply
                                            155.1k
