  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 41.1k Views 8 Watching
    Spinner is back and the 'not going to the first unread'
    • DesTD Offline
      DesTD Offline
      DesT
      @CatmanV2 the spinner is not back, we tested it! Can you try just to force a refresh on your browser tab.
      For the first "unread" I think it's an issue with the cookie/session. I would need to investigate a little bit more!
      • DesTD Offline
        DesTD Offline
        DesT
        @CatmanV2 we change the entire theme/css this morning while also upgrading the plugin that give you the spinner yesterday!
        • HSD99H Offline
          HSD99H Offline
          HSD99
          No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
            There is a new little light bulb icon in the top menu. Try it!
            • DesTD Offline
              DesTD Offline
              DesT
              • HSD99H Offline
                HSD99H Offline
                HSD99
                I've seen the light! Thanks!
                  Hard refresh removes the spinner. But it did that yesterday as well....
                  I shall report back
                  And I have cleared all cookies and logged out to test the last read issue.
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
                      Just tried to post a couple of images and the forum throws an error
                      Error
                      Something went wrong while parsing server response
                      This has worked before. It worked earlier today! Have I hit some sort of limit?
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        • DesTD Offline
                          DesTD Offline
                          DesT
                          @akbooer it's working...
                          Are you using the "Quick reply" or the "Reply" button ?
                            Both, and drag and drop. As I say, it worked earlier! I’ll try again later.
                            Loved your cartoon!
                              C'est bon... images attaching to posts again.
                                Still don't get the last post 😞
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  @CatmanV2 didn't have a chance to check that again, a little bit busy outside the forum 😞
                                    De nada, chap
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      Thanks to Google Translate 😉
                                        Ca fait rien? 😉
                                          "De rien!" is a better translation... 😛
                                            165.6k
